Hello.. I was working successfully in Revit a few days ago and now the program will not open. The program banner comes up but keeps spiraling. I took these steps already: checked anti-virus, deleted memory dump files, completed all Revit updates. I believe the next step is to uninstall and reinstall Revit. I have seen some warnings about doing so can cause problems with the hard drive. Can anyone advise me at this point?
p.s. I have Revit on a temporary student license for school and confirmed that it shows my account is still active.
Thank you
Solved by ennujozlagam. Go to Solution.
can you share your file so we can check?thanks
Attached is the file I cannot open.... thank you
you already mark your self as accepted solution? anyways i managed to open see attached. thanks
did you managed to open your file? thanks
