Alot of ungroup errors when exporting IFC
2 ANTWORTEN 2
Nachricht 1 von 3
Marcus.Isacsson
645 Aufrufe, 2 Antworten
Hi fellas!
Does anyone know why this happens when I export an IFC? (I have to temporarily ungroup to be able to export)
Seems pretty time consuming to fix(?)
Beschriftungen (1)
2 ANTWORTEN 2
Nachricht 2 von 3
it looks that Revit can not export Groups and Assemblies to IFC:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/sfdcarticles/sfdcarticles/E...
Constantin Stroescu
Nachricht 3 von 3
FAIR59
als Antwort auf: Marcus.Isacsson
In the IFC export setup, you've probably checked the [ store the IFC GUID in an element parameter after export ] option.
The program attempts to store the value in the [ IfcGUID ] instance parameter (BuiltinParameter_IFCGUID ). Unfortunately for this parameter the values can't vary by group instance, resulting in the errors.
