Hello all,
I have a structural project in Revit 2019 , the size of the file is 24.000 Ko. I have modeled only columns / walls and openings.
I also unloaded all the dwg files that I had linked.
When I change the thickness of a wall or its height it takes some time...
I downloaded all the new Revit's releases.
I purged the file.
What else I can do? I cannot work like this.
Thnak you in advance!
Is it possible for your computer hardware performance? I would recommend updating your graphic card driver as well and make sure the hardware acceleration is turn on in Revit options.
If it's not your computer (free hard drive space, too many programs open, long time since closing the project), try and un-check Analytical Model Categories in your VG.
