Problems "liniar dimensions"
 Quote : "  Linear dimensions are placed between selected points. The dimensions are aligned to the horizontal or vertical axis of the view. The selected points are endpoints of elements or the intersection of references (for example, the join of 2 walls)."
QuestionWhy does the command "Linear Dimensionsnot work when you press the icon?
In architecture does not see the insertion points (perpendicular, intersectionfinaletc.), to the drawing of a quota between the false ceiling and the concrete slabPlease solve this problem.
Use the tab button to select the relevant point that you want to dimension to.
