Changing the size of a family does not does not change the size of the family
ron_adst
Message 1 of 10
ron_adst
When I change the 1000 in 3600 the Apply button stays grey and after a few moments it changes back to 1000. Sometimes 1 time, sometimes 10 times. See the attached video. When I have Enscape open at the same time the opening changes in Enscape but still not in Revit....??? (it also happens when Enscape is not open, I crossed that off the list)
Also when I want to change one family into an other I can't select the new family. The pulldown closes before I can select. Again and again.
Closing Revit is the only solution. Restarting my PC an even better solution.
https://youtu.be/BjpfdC55SbI
Replies (9)
Message 2 of 10
AutoCAT95
  • Does it happen only in 1 particular project?
  • Does it happen in many different parameters in different families for you?
Message 3 of 10
ron_adst
It happens from time to time. Different projects. 3 weeks no problem, then days with a lot of frustration.
Mostly from the properties menu.
Different Families.
Materials I can't change from the Propertiesmenu. That wil almost always fail.
Message 4 of 10
AutoCAT95
I wonder if this might be not software, but hardware issue because it looks like lagging of processes. I heavn't experienced that problem before. Could you check in task manager if your system is not overloaded while this problem occured?
Message 5 of 10
ron_adst
We looked at it but that is not the problem.
Message 6 of 10
Make 'em Instance Parameters.
Message 7 of 10
ron_adst
they are
The problem is sometimes. For weeks no problem and then 2 days in a row complete frustration.
Message 8 of 10
ron_adst
We have 10+ Revit stations here at the office and none of my co-workers has the same problem.
That is an asnwer............. What is wrong with my PC?
Message 9 of 10
AutoCAT95
If the PC is guilty, have you tried bringing back default Revit settings or reinstal program?
Message 10 of 10
ron_adst
I have a new PC and still, from time to time I still have the problem.
Solution?... Closing outlook.... Why does that matter?
