Hi everyone,
I'm modelling a half cow shaped topography for a school project. I exported my 3d topography lines from sketchup as dwg and then I imported it on Revit. I used the "select import instance" and it happened with extra lines. Is there any way I can delete these, or any other suggestion for this project?
Revit will try to close the topo to the nearest point. You have to use split surface and then delete the extra topo
