Revit Topography extra lines
3 REPLIES 3
492 Views, 3 Replies
Hi everyone,
I'm modelling a half cow shaped topography for a school project. I exported my 3d topography lines from sketchup as dwg and then I imported it on Revit. I used the "select import instance" and it happened with extra lines. Is there any way I can delete these, or any other suggestion for this project?
3 REPLIES 3
syman2000
Revit will try to close the topo to the nearest point. You have to use split surface and then delete the extra topo
in reply to: syman2000
Splitting is really not useful on this project. I've just gave up doing it with Revit.
Forma Design Contest
