Revit to Autocad Default Paper Space
5 REPLIES 5
JordanBillingsley
1437 Views, 5 Replies
Posted to AutoCAD Forum - If there is a solution I believe it lies in CAD Land thought the Revit pool of expertise might have a solution:
Problem -
Client CAD standards specify that paper space be set to correct paper size for plotting and that the plotter is set to "none"
Seems reasonable to me but it doesn't seem that Revit's export options allow for this setting...
I am unsure how to set AutoCAD's default but did put forth a good hour of effort searching for the solution.
Thank you for your thoughts! This is a large set so manually changing these settings through ACAD page manager would be significant
5 REPLIES 5
in reply to: JordanBillingsley
- Create a dwt file with the pageseup that you need (correct paper size and "None" printer).  Name it REVIT.dwt.  Save it in a folder that AutoCAD can find (if you don't know this then let me know).
- In the dwt, create a pagesetup like you did in your screencast.  Name it 3042None.  Save the file.
- Create LISP file with notepad, copy paste the code below in.  Save it similar to step 1.
- Open you DWG.  Appload 3042.lsp and type in: 3042 at the command prompt.  It will import the 3042None pagesetup to the DWG.
- You can write a script to do it for multiple files. But I have forgotten how to do it so you have to ask someone else over AutoCAD forums.
This basically streamlines the process of importing a pagesetup from a template to a drawing.  It is a little quicker than doing it via the Page Setup Manager.  One thing that this cannot do is set the pagesetup as current.
To be honest, your client requirement is utterly ridiculous.  With Publish (formerly known as Batch Plot) and Sheet Set Manager, assign a pagesetup to every drawing is entirely unnecessary.
LISP code:
(defun C:3042 ()
(setq olecho (getvar "cmdecho"))
(setvar "cmdecho" 0)
(setq expert (getvar "EXPERT"))(setvar "EXPERT" 2)
(vl-load-com)
(vlax-for page_set (vla-get-plotconfigurations (vla-get-activedocument
(vlax-get-acad-object)))
(vla-delete page_set))
(command "-PSETUPIN" "REVIT.dwt" "3042None")
(setvar "EXPERT" expert)
(setvar "cmdecho" olecho)
(princ)
JordanBillingsley
in reply to: ToanDN
Thanks!
Might be pushing my luck here but the client also wants to have all xref bound. Similar problem since all of the exported sheets have views as xref... Again, don't see any option in Revit export dialog.
This one can be set when you export from Revit.
in reply to: ToanDN
thanks for the lisp, but do you think it is possible to also make it current as page setup.
after running the lisp i need to manually assign it by default
No.  But you can ask the LISP question over at AutoCAD forums.
Forma Design Contest
Technology Administrators
