Dear all
I seem to have a lot of issues with Revit 2019. I transformed the model from 2018 to 2019.
Walls seem missing in some plans.
When I go to my colleague who is worksharing can see them in the same views.
I already did:
- update to 2019.1 (waw, the delete button works in Dynamo now)
- audit
- update video driver (NVIDIA Quadro M2000)
- checked forums
Only option is to reinstall Revit, which I did a week ago for other issues.
Is there anything good in Revit 2019? Another patch please? Any ideas what to do? Is there a downgrade option to 2018?
hello. have you check your phasing and activate the bulb icon could be hidden or untick your use hardware acceleration and see if helps.. thanks
Is it a workshared file? Maybe the walls are in a workset which is hidden or closed in your local file.
Here's a useful list:
Checklist: 33 steps to being able to 'find stuff'
Check to see if:
1. The object or category is temporarily hidden
2. The object or category is hidden in the view
3. The object is being obscured by another element
4. The object's category or subcategory is hidden in the view
5. The object is outside the view's view range
6. The view's far clip depth is not sufficient to show the object
7. The object resides on a work set that is not loaded within the project
8. The object resides on a work set that is not visible in the view
9. The object resides on a work set that is not loaded in a linked file
10. The object resides on a work set that is not visible in a linked file
11. The object resides within a group (detail model) and it has been excluded from the group
12. The object is part of a design option that is not visible in the view
13. The object is part of a linked file that is not visible in the view
14. The object has one or more of its edges overridden to display as '<Invisible lines>'
15. The object is a family and none of its geometry is set to be visible in the view type
16. The object is a family and none of its geometry is set to be visible at the view's detail level
17. The object is set to not be visible at the category's detail level
18. The element has been placed outside the view's crop region (visible extents)
19. The element is an annotation object and does not reside entirely within the annotation crop region
20. The object's phase settings or the view's phase settings prevent the object from displaying in the view
21. The view's discipline is prohibiting the visibility of the object
22. The object is affected by a filter applied to the view
23. The object is subject to an element override, set to background color
24. The object is subject to a category override, set to background color
25. The object style is set to background color
26. The object is constrained to a scope boxes that is not visible in the view
27. The extents of the object itself don't permit it to be seen
28. The object is a mass, and 'Show Mass' is turned off
29. The object's host view has been deleted (area boundaries)
30. The view's scale is prohibiting the object's visibility
31. The object is a linked instance with coordinates too great for Revit to handle
32. The user has incorrectly identified the link instance to which the element belongs
33. The object is in a link that is not in its correct position
