Hi
Are you looking for "Wall Width " in say Door Schedule?
what do you mean by exporting that property in IFC?
I think you mean you want a parameter that reports the wall "thickness". If so. this is possible through a Reporting Parameter in the door family. Simple pull a dimension between the exterior and interior faces of the "host wall" in the family, and label it with a Reporting Parameter. When placed in the project, the door properties will report the thickness of the wall it's hosted to.
@barthbradley I just learned something new. Then how will we be able to see the wall thickness in the door schedule?
PS - ignore me - here is the answer to my question -
Use a shared parameter for that reporting parameter in the door family.
