Revit tags
26 REPLIES 26
Message 1 of 27
ikocev
1852 Views, 26 Replies
Revit tags
Hello guys, have you ever experienced a problem to tag properly a revit element?
What I am talking about is that- for instance I have a shared family with "mark" value set to 1, nevertheless when I try to tag this element the tag show a different number not 1. Please see attached screenshots for more information.
I have attached the family properties so you will see there the set value 1.
Thank you very much.
26 REPLIES 26
Message 21 of 27
ikocev
in reply to: ToanDN
Done.
Message 22 of 27
in reply to: ToanDN
I don't see any issues with the tag or family, but I can't replicate what you all are experiencing.
Every new instance I copy or place has a blank Mark.  But it is the Mark that is showing in the tag.
First: Please make sure there are no two copies of the family in the same place or nearby.
Step 2: In your model click on the placed tag (in the label portion) it should open a table of the parameters and values (see attached)
Message 23 of 27
in reply to: ikocev
Your nested family is not shown on Plan/RCP so obviously you are tagging the rack, not the equipment.  Check the box below and reload it, then TAB when tag to make sure you pick the equipment, not the rack.
Toan Nguyen
Message 24 of 27
ikocev
Thanks mate!!! That helped, I have completely forgotten that we can change the value from there.
Obviously when I am in a big hurry, some things get out of my head :))
That is the only way for me to change the mark value, change it from the nested family does not work for some reason.
Thanks again. Much appreciated.
Message 25 of 27
ikocev
in reply to: ToanDN
I want these tags on Elevation view. Plan/Rcp is off for a reason but thanks again.
Message 26 of 27
in reply to: ikocev
Be careful though, it seems that Mark is coming from another family or host.  Make sure changing the parameter from the tag doesn't mess up other things.
Message 27 of 27
ikocev
Yeah it says duplicate mark values but I suppose that is ok, I can ignore it.
Forma Design Contest
Technology Administrators
