revit stairs
8 REPLIES 8
Message 1 of 9
Geoffrey.Denie
465 Views, 8 Replies
revit stairs
Hi everybody,
Im trying to model a certain kind of stair. Should be fairly simple but so far I can't seem to do it. Thats why im looking for some tips or guideline's.
Image of the stair in attachment.
thanks
best regards
8 REPLIES 8
Message 2 of 9
What kind of tips? As you said, it's a fairly simple construct.  If you are modeling it in a Project, Stairs and Railing tools will get you 99% there.
Message 3 of 9
I dont know how to extend the top tread.
thanks
Message 4 of 9
in reply to: Geoffrey.Denie
Draw it as a top landing by Sketch.
Message 5 of 9
Geoffrey.Denie
in reply to: ToanDN
thanks, but now the side's are in one length while I want them to corner like in the example.
Message 6 of 9
Edit Stair Type > Edit Support types > Play with Structural Depths
Message 7 of 9
Geoffrey.Denie
in reply to: ToanDN
only structural depth on run change's but when I change the value of structural depth on Landing nothing change's. I've tried different combinations.
Message 8 of 9
Share the model and indicate where you want the beam on an elevation view with drafting lines.
Message 9 of 9
Geoffrey.Denie
in reply to: ToanDN
I decided to model it seperate with beams and in place family since the revit stair family is very cumbersone to work with and to get things exactly like I want.
thanks for the replies, very much appreciated.
best regards
