align sloped floor with other objects
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
Shay.Gaghe
140 Aufrufe, 1 Antwort
Hi
ive created a floor object and i gave it a slop,
the stairs (edit-in place component) won't follow the slopped floor
how can i align the floor with the stairs?
Using Autocad 2018, Autocad Architecture.
Please accept as solution if i solved your problem
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: Shay.Gaghe
If you want to align the stair with the sloped floor then create the stair as a blend or a swept blend.
