Revit Stair case: Extend below riser base
2 REPLIES 2
Rao_
235 Views, 2 Replies
Hello All,
I want to create a staircase with the base as seen in the attached image.
I have tried the option "Extend below riser base" but won't get the required dimension and shape as seen in the image.
Any suggestion on how to make it in stairs?  or do we have to use different options?
Note: The details are mentioned by pencil drawing in the attached image.
Thank you and good day.
Kind Regards,
Rao
Labels (3)
2 REPLIES 2
Lachlan-JWP
in reply to: Rao_
I would make the stair as normal and add a strip footing to the base of the stairs. If both families use the same material then you can join them together and it'll look they way you want.
Rao_
in reply to: Lachlan-JWP
Yes as of now I did it with beam and explained them it acts as a support. Had to use line work in views to hide the line since join geometry doesn't work.
Forma Design Contest
Technology Administrators
