Grade 2:1 slope to toposolid
1 ANTWORT 1
Nachricht 1 von 2
qchenTPPXV
207 Aufrufe, 1 Antwort
Greeting,
I want to create a 2:1 slope on a toposolid. I would like to know how could you approach it. I know that I could use Graded Region tool to create it. Using this method I need to adjust the top and extend the toe of the slope to the deeper topo in case the grade is create.
Thank you for your ideas.
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: qchenTPPXV
Modify sub elements, add points or split lines and adjust their elevation.
