Hi, ive been working on a project and now that i want to export it to pdf. But the thing is that when i try to export it, the lines keeps their original line weight even though i disable them from the start. As you can see in the pictures, on the first try i have the line weight activated and the exported product is as it should be. But on the other pictures, you can see i disable the line weight but even though , it is still been exported with line weight activated.
I thought it was something to do with the template im using, but then i used the default template and the problem persist. Also i upgraded revit ( from 2021 to 2022) and the problem still continues.
Also I edited the visibility graphics to one, but the export file still continues with the line weight activated
what can i do ?
