Revit keeps adding weight lines even though i desable them
3 REPLIES 3
rogerfast1
388 Views, 3 Replies
Hi, ive been working on a project and now that i want to export it to pdf. But the thing is that when i try to export it, the lines keeps their original line weight even though i disable them from the start. As you can see in the pictures, on the first try i have the line weight activated and the exported product is as it should be. But on the other pictures, you can see i disable the line  weight but even though , it is still been  exported with line weight activated.
I thought it was something to do with the template im using, but then i used the default template and the problem persist. Also i upgraded revit ( from 2021 to 2022) and  the problem still continues.
Also I edited the visibility graphics to one, but the export file still continues with the line weight activated
3 REPLIES 3
in reply to: rogerfast1
Thun line tool inly for displaying on screen. If you want to export as
thin lines, you need to go to VG and override line weights via categories
or filters.
RDAOU
@rogerfast1
  1. Create a View Template from View (required to reset your view after print)
  2. Create a View Template and Half Tone Everything in it
  3. Apply the Print ALL THIN LINES view template you created in step 2 to the view
  4. PRINT/EXPORT to PDF and (Check the box in print settings REPLACE HALF TONE WITH THIN LINES)
Forma Design Contest
Technology Administrators
