Problem with hatch on wall
hello,
I have a problem when drawing well that hatch pattern on my wall didn't showing.
if the problem came from view template , i don't know what should i fix it.
so how should i do
lucdoucet_msdl
@Anonymous
When the display level is set to coarse, the entire wall thickness will display the color and pattern set in the wall type properties. Currently your setting for the fill pattern is empty. To change it, edit the wall type properties, click in the coarse scale pattern box and select the drafting pattern you wish to apply.
Alternately, if you want the wall structure fill patterns (which are assign through the material properties) to appear, you must set the view detail level to medium or fine.
-luc
syman2000
Course material display as blank. You can add course material to make it show or you change your setting to Medium/fine to make the wall layers show up.
ennujozlagam
change your setting here.
Thanks guys, my problems is solved
icidesignbuild
Community Visitor
Community Visitor
I tried changing the detail level from coarse to medium at the bottom left of the screen; However, when I click on the square, it will not allow me to pick any selection. Medium or fine. Do I need to follow A certain procedure to change from coarse to medium or fine?
