Revit: cant close wall to a selected point
1 REPLY 1
198 Views, 1 Reply
I cant join my wall to selected point and wall want to join another wall but between both walls I created irregular wall by component. Hope someone can help me out with this.
Hi @Anonymous,
zsolt.varga has edited your subject line and embedded pictures for clarity and search engine optimization.
Original: "cant close wall to select point."
1 REPLY 1
Zsolt.Varga
Hi @RudolfsJo,
Thanks for the screenshot and the Revit file, you´d uploaded.
Please, take a look at my steps in the screencast video as follows:
https://autode.sk/2AKanAz
I believe they might take care of the issue that you are facing - You might however double-check the geometry in your model to make sure that it is accurate.
I hope this helps - Please, don´t forget to mark this post as an "Accepted solution" if it does.
Otherwise, just let me know what´s missing - I´d be happy to continue assisting you.
Thanks.
Zsolt Varga
Technical Support Specialist
Revit Ideas | Screencast | Revit Help | AKN
Forma Design Contest
