hello. Guys,
I am using Dynamo with Revit 2019. But, I am not able to use the function Control+C and Delete by using my Key board.
someone told me that I can solve that issue if I update Revit but, I have no idea where and how I can update Revit. So, I havent update it yet. in addition, I like to know that updating revit is the way to solve the issue or not.
Could you please let me know the way to solve theissue I am facing now?
Hi @Anonymous,
zsolt.varga has edited your subject line for clarity and search engine optimization.
Original: "Key board is not working properly Dynamo 1.3.3 & Rvit 2019"
best,
Gelöst! Gehe zur Lösung
Gelöst von piotr.bocian. Gehe zur Lösung
Here you go information how to check your Revit build version: https://knowledge.autodesk.com/support/revit-products/getting-started/caas/screencast/Main/Details/6...
And then check if you need to update Revit: https://knowledge.autodesk.com/support/revit-products/downloads/caas/downloads/content/autodesk-revi...
Thasnk Piotr.Bocian
The version of Revit installed in the PC was Revit.0.0.
I have updated it ot Revit 0.2 and it is working well. Thanks!
best,
Hi @Anonymous and @piotr.bocian,
Thank you both for your participation and for sharing useful experiences and information with the Community.
Best regards,
