I have an issue related to open an IFC file in Revit 2018.
Please see the attached video and related file in the Attachments section.
My Sample.ifc file contains 4 components: Beam, Angle section, Tee section and Channels section with same custom data properties. However, Beam and Tee section component haven't shown theirs custom properties when I use Open an IFC file. They only show all their custom properties when I use Link IFC.
I also using other BIM application such as BIM Vision, Solibri to open the .ifc file and all data has been shown.
Could you help me check with this ifc file and figure out why custom data has not been displayed.
Thank you,
Thank you for your response. It was not exported as same as your captured screen.
However, I was asking for opening my IFC file which is exported from my application and I want to open it in Revit with the fully custom data properties. I don't know that Is your reply relevant with my topic, because I'm a newbie in Revit.
Any other idea that you can help me? Thank you once again.
Thank you for your reply.
I don't get your solution. Could you help me with more details?
Thank you very much!
