Message 1 of 19
- Mute
- Permalink
- Report
When submitting a Revit Project to clients (either .rvt. or .rfa),
How do you make sure that clients working with older versions of Revit (ie.: Revit 2016), will be able open/work on your project/family files?
1 – You send the file and let the client do the workaround suggested by Autodesk (link) ?
2 – You do the workaround yourself and save the file in a version not older than 3 versions below the one you are currently using (ie.: if you are using Revit 2022 you will only be to save it back to Revit 2019)?
3 – Other (Leave your comment bellow)
