Full-Auto Update Function
At this time, to update the path of travel, there are only few ways to make it happen including select the path of travel line and manually press ‘Update’ and change the start point/end point for path re-calculation. But, the practical situation is, design change is always producing the change of model elements rather than path of travel, we need a tool that it will follow the model change and auto-update the path when the model is keep changing.
Workability of Dimension
For the statutory submission, dimension is a functional tool to be used commonly to tag the length of travel distance and other information due to statutory requirement. At this moment, we can’t apply the angular dimension for path of travel to present the degree between two separated travel directions. I hope it will be solved in the future version of Revit.
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
You should take your ideas and post them on Revit Ideas forum...HERE +----> https://forums.autodesk.com/t5/revit-ideas/idb-p/302
On this forum, best case scenario would be people suggesting workarounds
