Revit Application Hang
4 REPLIES 4
ajuelich
558 Views, 4 Replies
We have several labs with Revit 2021 in them.  Intermittently we have students that experience slowness and an Application hang.  This is what I've done thus far:
  1. Applied the latest Hotfix/Patch
  2. Added the recommended Antivirus Exceptions
This is our environment:
  • Windows 10 1909 Education 64-bit
  • Dell Precision Workstations
  • SSD
  • 16GB Memory
  • AMD FirePro W5100 4GB Memory
Any ideas?  I have created a Support Ticket but they just keep sending me links.  Attaching screenshot of Event Viewer error.
Labels (1)
4 REPLIES 4
ennujozlagam
in reply to: ajuelich
you can try this update latest graphics card driver and switch off your use hardware acceleration from options and see if helps. thanks
ennujozlagam
another way is to run this program and see if helps. thanks
syman2000
Check and see if the firewall preventing Revit from accessing the website. Also do you have 3rd party plugin? Disable it and see if that helps
ajuelich
in reply to: syman2000
This is a lab full of students, on the same machines, starting the same project from scratch and we will randomly have a subset that start to struggle with slowness, hangs, and eventual crash of Revit.  Attached is the event in Event Viewer.
Forma Design Contest
Technology Administrators
