Great forum.
Say, I'd like to create grids, where each square is uniquely labeled (can be any unique labels, really, such as "1", "2", "3", etc., or "a1", etc. below). How do I best do this. Is the best way?: View --> Guide Grid
Solved by syman2000. Go to Solution.
Solved by aaron_rumple. Go to Solution.
May I ask: What doe you actually want to do with this grid of unique cells? If you describe the end result / strategy you are wanting to achieve, we could work backwards and determine the best solution. There may be other options that don't involve Guide Grids?
Quick and dirty, since we don't know what you really want to do....
A square family - arrayed in your grid and then tag each family with Mark.
Use Dynamo to rename them with the letters and numbers based on location.
Good question. We label warehouses for determining forklift travel distances, and we look at each bin in the warehouse and assign an arbitrary unique zone that ("a1", "b3", "j5", etc.) to it. So I need to look at any point in the warehouse and say "that point is in zone b3". Does that help?
Then yes.
I'd make a family - it could just be some model lines in plan. Array the family in a grid and tag all. Then you can do the tags a couple of ways.
Or...
And...
You can create slope glazing and use curtainwall panel as your guide with text value. Then you can define the number of vertical & horizontal grids you want. See attached
