Im confused on what 3Ds max is. Can i build a whole home in Revit with no finishes on it and just import it into 3ds and add finishes and rendering? In 3Ds how versatile are the material selections?
Solved by loboarch. Go to Solution.
@Anonymous wrote:Im confused on what 3Ds max is. Can i build a whole home in Revit with no finishes on it and just import it into 3ds and add finishes and rendering?
don't know what your confused about
there is 3ds max or there is Revit
they are completely separate products
yes you can design your house in Revit and import into 3ds max to render or you can just render inside Revit
it really depends on what your looking for
are you looking to add animations into your model or do you just want a high quality static picture?
DarrenP
