Im trying to make a grass and concrete driveway like the one below, but with square pavers. Its concrete with grass in between. How do i do this. I also need to be able to put in 8 concrete trees with a flagpole in the middle.
The tree layout is similar to the oicture, but with less trees. I sketched the driveway plan. circles are trees. star is flagpole. shaded area is driveway. Thanks in advance!!
I used a floor changed the material to concrete cast in place and drew the outline of a rectangle and copied and mirrored it around to get the concrete pavers. I then copy and pasted the same place the pavers and duplicated it to make the grass area around them. I then edited the grass to include a boarder around the paver area. See the attached RVT and image.
For the flag pole do a search on google and you should be able to find some you can use. The palm trees I wouldn't know where to look.
Hope this helps you with what you are trying to do.
