Revit 2024 Project Browser Frozen
20 REPLIES 20
Message 1 of 21
wlawsonXCGKS
1237 Views, 20 Replies
When I link in a new revit file into Revit 2024 the project browser freezes.  I am having to shut down and re-open the file again to get the project browser unfrozen.  Others within the team are having this issue also.  Does anyone know how to fix this issue?
20 REPLIES 20
Message 2 of 21
in reply to: wlawsonXCGKS
Message 3 of 21
wlawsonXCGKS
in reply to: barthbradley
This is only a screen issue with the Revit 2024 version, it works with different screen sizes (i.e. a laptop and a larger monitor) for previous versions of Revit such as 2021, its just the new version that doesn't seem to like the 2 different screen sizes.  So the question is why is this only an issue with version 2024? Will there be a patch or hot fix to resolve this?  Many users have a different set up from home to office.
Message 4 of 21
ennujozlagam
maybe?
https://www.autodesk.com/support/technical/article/caas/tsarticles/ts/1BlfQlbA9wWd1JmijceW6d.html
Message 5 of 21
wlawsonXCGKS
Many thanks for that. Do you know what specifically in the release notes will resolve this. Do you know if the fix that you have sent the link to will definitely fix the Project Browser issue?  The project browser section of the notes mentions “stability fixes” but doesn’t say anything specific. Our IT department are reluctant to apply this without knowing for certain that it will fix the issue.
Message 6 of 21
devan-mistry
we are having the same issue as this across all of our Revit 2024 users.
Did you manage to find a fix at all?
The latets Revit 2024.2.1 hotfix has not resolved the issue with the Project Browser freezing.
Our IT team thinks it is a diplay/resolution issue with multiple screen set ups from home and the office and moving to and fro with docking stations etc.
Message 7 of 21
wlawsonXCGKS
in reply to: devan-mistry
This is what our own IT dept Think also, we do not have a resolution as yet. Not certain, as it is the browser of the last linked file that is frozen onto the browser panel, not sure that has anything to do with monitor screen sizes.
Message 8 of 21
devan-mistry
thanks.
What do you mean by the browser of the last linked file exactly?
Message 9 of 21
wlawsonXCGKS
We have been finding that it freezes immediately after linking in another disciplines model so for example if you are doing the furniture for the building you link in the architectural, steel, M&E etc so you can do your furniture layouts. Once the linked files have either been loaded in or revised to a newer version, this is when the freezing is happening for us. So you are in your own model, but the information shown on the browser panel is still showing the information from the browser panel of the last linked in model, the browser hasn't updated back to the main files information.
Message 10 of 21
devan-mistry
ah, that is interesting.
To be honest, at our end, we have not really noticed a pattern in the PB freezing.
It tends to happen more when you move from the office to working from home the next day for example and the first time you open Revit on a different screen set up with differing resolutions.
Surely Autodesk are aware of this now and should release a Hotfix?
Message 11 of 21
wlawsonXCGKS
I hope they are as with everywhere all staff have smaller laptops and larger screens at both home and in the office/site, it's the norm now to be using a variety of screen sizes. I don't believe that is the issue though as it only happens with the 2024 version of Revit, up until this point staff being fully mobile and using a variety of screen sizes and the older versions say Revit 2021 we have had no issues to date, strange that screen size seems to be the answer floating about just now.
Message 12 of 21
devan-mistry
same goes for us - no issues whatsoever on same working/monitors set up on RVT 2020, 2021, 2022 or 2023.
Only 2024...
Did you try and report / get tech support from Autodesk directly?
We did and they listed nothing under the cause and gave some generic instructions on how to resolve with multiple fixes to iterate between and test!
Message 13 of 21
wlawsonXCGKS
Pretty much the same scenario, our IT came back with the screen size and nothing they could do about it. I think its cutting down on the operating system on 2024 myself, waiting patiently for a hotfix/patch for it once they realise.
Message 14 of 21
devan-mistry
yes me too.
One last question - did you explore the idea of any add-ins causing this?
Our Revit support suggested this but I am very sceptical of this as all previous RVT versions had the same add ins and this never happened
Message 15 of 21
wlawsonXCGKS
We tested this with one user who had no add ins to the program, same issue, think that's a red herring.
Message 16 of 21
devan-mistry
thanks for confirming, thought the same.
Let's await a further hotfix from Autodesk I guess...
Message 17 of 21
devan-mistry
We have a fix! albeit temporary.
When the PB freezes in RVT2024, you can click on the PB itself anywhere inside the window (even though it obviously will not let you) and hit F5 on your keyboard...it refreshed and comes back alive!
Not a complete fix to stop it from occuring however much better than having to restart RVT2024 several times a day per user.
I am going to inform Autodesk directly of this issue/temp fix so that they can look into it further and hopefully release a Hotfix update soon
Message 18 of 21
andywatson64
YES! THANK YOU!
I haven't been able to isolate the issue as well as some others in this thread, but F5 works perfectly! I wanted to report and say thanks.
Message 19 of 21
wlawsonXCGKS
in reply to: andywatson64
Working for me too ☺ F5!!!
Message 20 of 21
jamDTZWA
Amazing!! Works a charm. Thank you!
Forma Design Contest
Technology Administrators
