Bottom Sloped Floor
8 REPLIES 8
Message 1 of 9
giorgiodeleoVCB8U
397 Views, 8 Replies
Bottom Sloped Floor
Hi, I'm having trouble modeling a raised floor that slopes on the bottom side. Can you recommend a solution?
Thanks so much,
Giorgio
8 REPLIES 8
Message 2 of 9
edit the floor boundary and draw the slope using the slope arrow, then you can specify the height difference or slope percentage
https://help.autodesk.com/view/RVT/2025/ENU/?guid=GUID-C1C203F9-DAF9-450B-BEB1-DE8CC40BA101
Message 3 of 9
Join Geometry will remove volume at the union.  So, join the Floor with the solid geometry below it.
Message 4 of 9
Thanks for your suggestion, but I need to maintain my top face planar because this is a raised floor that is placed on a sloped structural slab.
So i think that raising the bottom portion while keeping the top level horizontal would be the best option for me.
Message 5 of 9
Is it feasible for me to copy and hide the floor that is part of the structural model after the union?
Message 6 of 9
There should be nothing to hide.
Like I said, Join Geometry REMOVES volume at union.
Message 7 of 9
Actually, I don't think I understand you.  Can you elaborate on what you mean?
Message 8 of 9
in reply to: giorgiodeleoVCB8U
Two approaches:
1. Model a thick floor and use a sloped void to shave off the bottom.
2. Model one flat top floor and one sloped bottom floor then join geometry.
Message 9 of 9
I duplicated the underlying floor from the structural link, joined it with mine, and moved it to a closed workset.
This workflow also cuts my substrates, but since we use a thicker dashed line on the sheets, I don't mind losing some minor substrates (like membranes).
Also, I need to export my model to IFC, but I usually export only 3D elements that are visible within a specific view, so I think that should be fine too.
