Revit 2021 Phase Filter - New Construction
rdw
Message 1 of 20
rdw
I am simply trying to add a solid black fill filter to the new construction walls but can not seem to get this to work. I must be missing something.  When i adding a cut pattern to the existing walls it works without a problem, I do the same thing for new walls and no matter what i do i can not get that pattern to show up in the walls.  I do not want achieve the solid fill by changing my detail view to coarse.  I should be able to manipulate the same way i do the existing phase. Can someone please help? What step am i missing? No matter what i change in the phasing graphic overrides for new construction nothing will change. There is zero reaction to new walls.
Replies (19)
Message 2 of 20
Why don't you do it through a Rule-Based Project Filter?
Message 3 of 20
Message 4 of 20
rdw
I don't believe I should need to do it that way. If you can modify the existing walls through the phase filter why can't you do the same with the new walls??
Message 5 of 20
rdw
That seems a bit unnecessary.  If you arecapable of changing existing walls with the phasing filter graphics override function you should be able to do the same with the new walls?
Message 6 of 20
I'm not following you?  Walls aren't "modified" through the phase filter.  Can you elaborate?  .
Message 7 of 20
Yah, I'm still lost.  Can you walk me through those steps?
Message 8 of 20
lucdoucet_msdl
@rdw
If it is important that the phase be the reason a wall is filled, as it can be in an existing phase view, all families will be filled, not just the walls.
For the new construction elements to be filled in a view, three things are required:
1. The elements are set to the current phase  (elements are new in the current view set to "New construction" in example);
2. The phase filter is set to "Replace" for new elements and (see Manage|Phases|
3. The phase graphic override for new elements has projection and cut remplacement fills (See New Replaced in example)
If only walls or a subset of revit families are to be filled, I would agree with @barthbradley  that a filter operating on some common parameter with a filter graphic override in the view would be better.
Hope this helps
-luc
Message 9 of 20
What's your View's Phase and Phase Filter set to?  What's the Phase Filters and Graphic Overrides set to?  Maybe some screenshots would help.
Message 10 of 20
rdw
Please see attached photos. We would like the new construction to have a solid fill pattern without having to change the detail level to coarse or any of that. We should be able to manipulate this phase exactly as we did the existing phase.
Message 11 of 20
Message 12 of 20
No photos.
Message 13 of 20
rdw
Thank you
Message 14 of 20
rdw
I appreciate all the help but i have figured it out thanks to lucdoucet_msdl
Message 15 of 20
I'm amazed that you are doing this through Phase Filters and not Ruled-Based Filters. It's overly complicated. Too many variables come into play.  You'll see what I mean as you go forward.
Have a good day.
Message 16 of 20
...are you aware this applies to much more than just walls?
Message 17 of 20
lucdoucet_msdl
@barthbradley
Here's a Real World Case Scenario: Presentation drawings.
Everything cut is new and filled white.
Message 18 of 20
Not sure what you are pointing out to me, but the picture kind of reminds me of a blueprint we did 30 years ago.
Hank Center Tower?  Are you Morphosis?
Message 19 of 20
rdw
  • 100% presentation is the scenario here. Thank you for understanding and helping.
Message 20 of 20
Yah...that's pretty much what you "do" with Revit.
