Message 1 of 20
- Mute
- Permalink
- Report
I am simply trying to add a solid black fill filter to the new construction walls but can not seem to get this to work. I must be missing something. When i adding a cut pattern to the existing walls it works without a problem, I do the same thing for new walls and no matter what i do i can not get that pattern to show up in the walls. I do not want achieve the solid fill by changing my detail view to coarse. I should be able to manipulate the same way i do the existing phase. Can someone please help? What step am i missing? No matter what i change in the phasing graphic overrides for new construction nothing will change. There is zero reaction to new walls.
