family
family
family
I have a question.
There is one .rfa family, I want to go into the family and make changes in the edit type section.
Family's form is changing, why?
thank you for your help.
Mohamed-Nassar
Can you provide us with Picture to understand more!!
may this type have another dimension so it's changed when you change it
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
Secttor
hi @Anonymous
- family geometry is changing based on values/options gives to the parameters used when it was built. you can do this in the rfa or where it's placed in the project.
- you could share some screens/.rfa in order to get more or detailed info.
Revit MEP - Electrical Certified Professional
Revit MEP - Mechanical Certified Professional
Draftworks.wordpress.com
Welcome to the Forum.
Can you elaborate please? This isn't Twitter. Number of characters aren't limited to 280. Also, picture would be very helpful. I've been told that a picture is worth a thousand words.   😉
