Revit 2020 in Viewer Mode ?
DeurlooBM
Message 1 of 87
DeurlooBM
I was asked by the Twitter support team to post it here, so here goes.
I downloaded and installed Revit 2020 today and as every year I am excited to see the new stuff. But the first ting I noticed is that I can not save a project or a family and Revit pops up with a message telling me I'm in Viewer Mode (see attached image). I already tried logging out and back in again and of course rebooted my workstation as well.
Any idea what going on?
website: www.deurloobm.nl
Replies (86)
Message 61 of 87
karldraw
B I N G O !
Message 62 of 87
Still, doesn't help my 2019.2 stuck in viewer mode.
Message 63 of 87
Matt__W
@Anonymous the hot fix is for Revit 2020, not 2019.
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
Message 64 of 87
Is there another place to access the Hotfix? When I open the Autodesk Desktop App, the window opens but never loads anything. I'm running Windows on Bootcamp, if that matters.
I was able to find it from my account online.
Message 65 of 87
SO I uninstalled 2019.2 and reinstalled it and now it works.
Message 66 of 87
aryo
Observer
Observer
where to instal revit 20201.0.1 from?
It doesn't appear in my products downloads
Message 67 of 87
Shows up for me as the most recent updates at manage.autodesk.com.
Do you see any updates?  You may not have access to program updates if you don't.
Message 68 of 87
Matt__W
You can try this direct download link : https://up.autodesk.com/2020/RVT/9CA05B9A-2002-0510-A1B4-FFF7A680FE55/Autodesk_Revit_2020_0_1.msp
Matt Wunch
Twitter | LinkedIn
Message 69 of 87
When will the official fix come out?
Message 70 of 87
Matt__W
@Anonymous it's been out for a while now (since mid-April). Check the Desktop App for the 2020.0.1 update.
Here's the Release Notes about it.
https://up.autodesk.com/2020/RVT/Autodesk_Revit_2020_0_1_Readme.html
Matt Wunch
Twitter | LinkedIn
Message 71 of 87
I installed last week, didn't need to install the update/hot fix.
Message 72 of 87
huotger
If you are installing from Autodesk Desktop App, the Revit 2020.0.1 hotfix should be applied automatically when Revit 2020 is installed.  Unless you have disabled the "Always install the latest product updates at the same time" option within ADA settings.
I hope this helps.
Gerry Huot
SQA Manager
Message 73 of 87
Viveka_CD
Message 74 of 87
Install_N_Licensing
Autodesk Support
Autodesk Support
>>Solution provided above.
구매조건, 지불, 계약에 관한 문의 혹은 교육용 라이센스 신청이나 갱신에 관한 문의사항은 다음 링크에서 관련 카테고리를 선택하시어 케이스를 오픈해 주시면 각 담당 부서에서 보다 빠르게 답변을 받으실 수 있습니다. 지원 요청
Message 75 of 87
m2
I purchased subscription to Revit LT.  It is permanently in VIEWER MODE.  I am unable to be productive with this software until this is resolved.  Side question:  Why even have a viewer?  Other Autodesk products are inaccessible without valid license or may be looked at with separate "viewer" utility.
Michael McMillin, AIA
Message 76 of 87
Matt__W
@m2 have you seen this AKN article about this issue?
REVIT 2020 IS STUCK IN VIEWER MODE AFTER INSTALLING
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Your screenshot shows that you don't have the 2020.0.1 hotfix installed you. You still have the initial release installed.
HOW TO TIE THE BUILD NUMBER WITH THE REVIT UPDATE
Matt Wunch
Twitter | LinkedIn
Message 77 of 87
Hello - For this fix installation will I have to exit my current revit session?  I'm SO ANGRY right now that I might have lost two days worth of work when I thought it was auto saving in the background just to find out that YOUR RIDICULOUS PROGRAM switched me to Viewer Mode without my knowledge!!  There better be a way to recover ALL OF THIS WORK or there better be some sort of compensation for YOUR LACK OF REGARD for your user's time, energy, and use of a product that should function properly!  You have horrible customer service as well; In emergency situations you cannot speak to the Support Team directly, in real time, to try for a solution.  You have to schedule something which is extremely inconvenient.
Message 78 of 87
RobDraw
@Anonymous wrote:
Hello - For this fix installation will I have to exit my current revit session?  I'm SO ANGRY right now that I might have lost two days worth of work when I thought it was auto saving in the background.
Two days without saving? Autosave?
This kind of statement does not belong in a user help forum. The complaint department is down the hall and to the left.
Rob
Message 79 of 87
eva
Hi I download Revit 2019 on Jan29, and it worked really well. Today, Feb 2, I open Revit and it said revit in 2019.2 is in viewer mode. I followed the link : https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
and did step 1,2,3,4. Restart my computer. And I also installed all revit updates, still not working.
Please help…….
Message 80 of 87
RobDraw
Since this thread is about a specific issue with 2020 and has several posts marked as solutions, you should start a new thread as your issue is not related.
Rob
