Revit 2019.2 update doesn't work
Message 1 of 40
Hello, I've installed Revit 2019.2 update on two computers. On first computer update working ok, but on second computer it was successfully instaled, but when I open project in Revit on the top of window doesn't write 2019.2. Also new functions don't work (schedule zoom,...). What could be wrong?
Martin
Replies (39)
Message 21 of 40
mdavis22569
 I would think they are ....
You might then have to hold off on the installation of it ...
Mike Davis
Message 22 of 40
huotger
We do apologize for any frustration you are experiencing with updating Revit 2019.  Within your environment, do you have the scenario where the Revit 2019.0.2 Hotfix was attempted to be installed on Revit 2019 with Revit 2019.1 Update applied?  If not, you should be able to install the Revit 2019.2 Update directly at this time.
Gerry Huot
Gerry Huot
SQA Manager
Message 23 of 40
RevitJediMaster
I believe that to be the case for most of our users.  Only one user that I know of was able to get the update to install correctly.  His machine was recently built and, most likely, had the patches applied in the correct order that allowed the install to complete successfully.
Message 24 of 40
yvoheinen
I Agree with you Jakek, this isn't even a solution for 5 users.  Completely Uninstalling and Re-installing just takes up to much time, for just a "simple" Revit update.
I hope there will be a viable solution, which does not require a complete uninstall and Re-install.
@RevitJediMaster wrote:
Pardon my frustrated tone, but this issue is not "solved."  Uninstalling Revit and re-installing to apply a point update is not a viable solution for 45 users.  I could see it, maybe, for 1-5 users.  But it takes considerable time and effort to do that for an office of even 10 users.  The added features are not worth the investment.
Is Autodesk working on a different solution?  Or do they consider this a done deal and we'll just need to wait for Revit 2020 to get the new features?
Message 25 of 40
Hi Tony,
Has a better solution for installing the 2019.2 update for Revit been found? I find that most solutions given from Autodesk, is to reinstall Revit. This is not a solution.
The first day that the update was released, I did a few test installs and noticed that the build number didn't change to reflect the update. This is simple testing that should be done before a patch is pushed out.
I've tried uninstalling all patches and installing the latest patch. No luck with that. A full uninstall of Revit 2019 along with the patches, address the issue. This isn't a viable solution for me, as we have 40+ pc's within the office.
Message 26 of 40
Thank you , this worked for me.
Message 27 of 40
I agree with you guys, we need a solid solution that isn't time consuming and works 100%. Uninstalling and reinstalling isn't a solution, its a band-aid.
This same issue happened before. If you installed Revit 2019 0.2 before Revit 2019.1, it would not take the 2019.1 update. We were then told this will be corrected when 2019.2 is released. 2019.2 has issues of its own when trying to install.
Where are the Autodesk employees that should be looking into this issue?!?!
Message 28 of 40
Alex_Diaz_B
See if my solution on this post fixes your installation issue.
https://forums.autodesk.com/t5/revit-architecture-forum/announcement-revit-2019-2-and-revit-lt-2019-...
Alex Diaz
Message 29 of 40
Hi adiaz,
I have already done what you did, just a different way. I also tried your way in that solution, no luck. As the updates 0.2 and 1 don't *Fully* uninstall. I need another working solution.
Message 30 of 40
RevitJediMaster
@Alex_Diaz_B
I tried both and get the warning box, "The patch is not applied to this product."
Message 31 of 40
Hey  jakek,
Thats because it cannot fully uninstall the older packages. Try to install update 2019.2. It will "install" but when you go into Revit 2019, it will be build Revit 2019.1
Message 32 of 40
RevitJediMaster
@Anonymous wrote:
Hey  jakek,
Yes.  I've tried to install 2019.2 from an .exe and all it does is install Dynamo Core 1.3.4 (not sure when that was uninstalled...).  Revit still shows v. 2019.1 and none of the new features work.
Message 33 of 40
jakek ,Tell me about it. If you want the issue fixed, you must reinstall Revit completely. It does not look like Autodesk is looking into this Very Well Known issue. Seems to me that they want us to do all the trial and error to find the fix.
Message 34 of 40
Alex_Diaz_B
Sorry to hear it didn't work for you. Maybe I got lucky. My Revit installations show 2019.2Revit 2019.2_2.jpg
Unfortunately we all are alone trying to find a decent workaround/solution to Autodesk poor QA/QC before releasing a patch/sp. You may not have other option to either wait for a better solution from Autodesk or follow their current "solution" to completely uninstall Revit 2019, re-install and apply the patch.
I feel your pain
Alex Diaz
Message 35 of 40
Tony_Michniewicz
Using Alex's suggestion, I was able to revert Revit to its original version and then I was able to successfully apply the 2019.2 Update.  While testing this behavior, I found that you must run the MSIPATCHREMOVE process for the most recently installed Revit update.  To clarify, if the last update applied was the 2019.0.2 Security Fix, then I had to run the MSIPATCHREMOVE process specific to that update but if the 2019.2 Update was applied after the 2019.0.2 Security Fix, then I had to run the MSIPATCHREMOVE process for the 2019.2 Update.
For those of you that want to try this solution, I would recommend running each of the following at a "run as administrator" command prompt:
Msiexec /I {7346B4A0-1900-0510-0000-705C0D862004} MSIPATCHREMOVE={9CA05B9A-1907-0510-A1B4-FFF7A680FE55}
Msiexec /I {7346B4A0-1900-0510-0000-705C0D862004} MSIPATCHREMOVE={9CA05B9A-1905-0510-A1B4-FFF7A680FE55}
Msiexec /I {7346B4A0-1900-0510-0000-705C0D862004} MSIPATCHREMOVE={9CA05B9A-1904-0510-A1B4-FFF7A680FE55}
If a Windows Installer message is displayed stating "The patch is not applied to this product.", you are safe to move along to the next one.  When you run the MSIPATCHREMOVE process for the currently applied patch, the process should take a while to complete and will most likely prompt you for the original installation media.  When complete, the Revit installation files should be reverted to their original version.  Checking the version of the Revit.exe file is a quick method to confirm this change.
At this point, I would recommend running the 2019.2 Update once again.  If this action results in a prompt to uninstall or modify this update, select the uninstall option.  Once that action is complete, run the 2019.2 Update once again and it should install successfully.
If this approach does not work on your system, the only other workaround is to uninstall and reinstall Revit, then apply the 2019.2 Update.  In this scenario, please note that you do not need to uninstall other Revit components, such as the Revit Content Libraries or add-ons (Batch Print or Model Review).
Tony Michniewicz
Revit Software QA Analyst
Message 36 of 40
Hi Tony,
This is the real solution! Thanks a lot.
Just one quick note: After uninstalling the patches , I couldn't open Revit to check the version code, it was shutting down every time. But then I directly re-installed 2019.2, and everything worked perfectly.
Message 37 of 40
RevitJediMaster
This worked for me.  The key seems to be uninstalling the 2019.2 patch from the command line (I assume that was the first one in the post) since running the .exe of the patch to uninstall must not completely remove the patch.
FYI - to run the command prompt "as administrator" (I had to look this up):  Windows Key+R, type "cmd.exe" without the quotes, and press CTRL+SHIFT+ENTER.  The Command prompt should show C:\WINDOWS\SYSTEM32>,  not C:\Users\<Username>>.
Thanks @Tony_Michniewicz  for the solution!
Edit: spelling.
Message 38 of 40
yvoheinen
Tony,
This is a solution that works for us! thank you for time and effort!
Message 39 of 40
robk
Autodesk,
Please send me $120.00 to compensate me for MY time (this time) for the uninstalling and reinstalling procedure as your (ridiculous) Revit 2019.2.2 solution. THIS is what we pay dearly for?
Cheers,
Rob Kuchta
Message 40 of 40
RobDraw
Welcome to the woes of updating. Sometimes these things are necessary.
BTW, this is a user help forum, the complaint department is down the hall and to the left.
Rob
