' 0:< Initial VM: Avail 134217444 MB, Used 13 MB, Peak 13; RAM: Avail 63225 MB, Used 48 MB, Peak 13
' 0:< GUI Resource Usage GDI: Avail 9995, Used 5, User: Used 3
'C 13-Sep-2016 16:02:32.515; 0:< started recording journal file
' Build: 20160720_1515(x64)
' Branch: RELEASE_2017_RTM
Dim Jrn
Set Jrn = CrsJournalScript
'C 13-Sep-2016 16:02:32.530; 0:< ->desktop InitApplication
'C 13-Sep-2016 16:02:32.531; 0:< <-desktop InitApplication
'C 13-Sep-2016 16:02:32.531; 0:< ->desktop InitNativeInstance
' 0:< Options::loadOptions: m_strDataLibraryLocations=Imperial Library=C:\ProgramData\Autodesk\RVT 2017\Libraries\US Imperial\,Imperial Detail Library=C:\ProgramData\Autodesk\RVT 2017\Libraries\US Imperial\Detail Items, Roombook Library=C:\ProgramData\Autodesk\RVT 2017\Libraries\US Imperial\Roombook Library, Areabook Library=C:\ProgramData\Autodesk\RVT 2017\Libraries\US Imperial\Areabook Library, Buildingbook Library=C:\ProgramData\Autodesk\RVT 2017\Libraries\US Imperial\Buildingbook Library (defaultLib==\Library)
' 0:< ::0:: Delta VM: Avail -24 -> 134217420 MB, Used +4 -> 18 MB, Peak +4 -> 18 MB; RAM: Avail -59 -> 63167 MB, Used +11 -> 60 MB, Peak +11 -> 60 MB
' 0:< GUI Resource Usage GDI: Avail 9980, Used 20, User: Used 249108103196
'C 13-Sep-2016 16:02:33.641; 0:< License initialization complete
' 0:< License version: 17.3.26.0
' 0:< ::0:: Delta VM: Avail -173 -> 134217247 MB, Used +31 -> 49 MB, Peak +33 -> 52 MB; RAM: Avail -85 -> 63082 MB, Used +49 -> 109 MB, Peak +49 -> 109 MB
' 0:< GUI Resource Usage GDI: Avail 9980, Used 20, User: Used 249108103220
' 0:< SystemSettings:
' 0:< 12=multiCoreCharacteristic
' 0:< true=isDotNetInstalled
' 0:< 4.6.01586(394802)=dotNetInstalledVersionString
' 0:< false=isProcessUserModeExceptionPolicyDisabledForCallbackFilter
' 0:< ::0:: Delta VM: Avail -18 -> 134217230 MB, Used +8 -> 58 MB, Peak +5 -> 58 MB; RAM: Avail -15 -> 63068 MB, Used +15 -> 124 MB, Peak +15 -> 124 MB
' 0:< GUI Resource Usage GDI: Avail 9973, Used 27, User: Used 249108103233
'C 13-Sep-2016 16:02:34.299; 0:< manage licensing
' 0:< ::0:: Delta VM: Avail -51 -> 134217180 MB, Used +5 -> 63 MB, Peak +12 -> 70 MB; RAM: Avail -151 -> 62917 MB, Used +14 -> 139 MB, Peak +19 -> 143 MB
' 0:< GUI Resource Usage GDI: Avail 9973, Used 27, User: Used 249108103237
' 0:< License mode: Standalone
' 0:< Type: Standalone - Locked
' 0:< Usage: Commercial
' 0:< Behavior: Extendable
' 0:< Expiration: Saturday, October 07, 2017
' 0:< ::0:: Delta VM: Avail -568 -> 134216613 MB, Used +35 -> 99 MB, Peak +29 -> 99 MB; RAM: Avail -44 -> 62874 MB, Used +35 -> 174 MB, Peak +30 -> 174 MB
' 0:< GUI Resource Usage GDI: Avail 9940, Used 60, User: Used 249108103250
' 0:< Setting WPF rendering mode to SoftwareOnly
' 0:< ::0:: Delta VM: Avail -156 -> 134216457 MB, Used +69 -> 169 MB, Peak +69 -> 169 MB; RAM: Avail -256 -> 62619 MB, Used +93 -> 267 MB, Peak +92 -> 267 MB
' 0:< GUI Resource Usage GDI: Avail 9838, Used 162, User: Used 249108103345
' 0:< Autodesk Revit 2017
' 0:< 64-bit load point = C:\Program Files\Autodesk\Revit 2017
' 0:< this journal = C:\Users\tople\AppData\Local\Autodesk\Revit\Autodesk Revit 2017\Journals\journal.0021.txt
' 0:< ::0:: Delta VM: Avail -9 -> 134216448 MB, Used +1 -> 170 MB, Peak +1 -> 170 MB; RAM: Avail -16 -> 62604 MB, Used +4 -> 271 MB, Peak +4 -> 271 MB
' 0:< Journal Init
'C 13-Sep-2016 16:02:40.969; 0:< Log Summary
' 0:< .Count
' 0:< ...PendingMessages = 48
' 0:< .Marshalling
' 0:< ...CompactCaching = 1 (Enabled)
' 0:< .ThreadPool
' 0:< ...ActivePoolSize = 26
' 0:< ...ConfiguredPoolSize = automatic
' 0:< ...ParallelCores = 12
' 0:< ...RequestedPoolSize = automatic
' 0:< .Tuning
' 0:< ...ElemTable = 1 (Serial except when multithreaded)
'H 13-Sep-2016 16:02:40.969; 0:<
Jrn.Data "JournalDefaultTemplate" _
, "Construction Template=$AllUsersAppData\Templates\US Imperial\Construction-Default.rte, Architectural Template=$AllUsersAppData\Templates\US Imperial\default.rte, Structural Template=$AllUsersAppData\Templates\US Imperial\Structural Analysis-Default.rte, Mechanical Template=$AllUsersAppData\Templates\US Imperial\Mechanical-Default.rte"
'H 13-Sep-2016 16:02:40.970; 0:<
Jrn.Data "JournalDefaultViewDiscipline" _
, "Coordination"
Jrn.Directive "Version" _
, "2017.000", "2.153"
Jrn.Directive "Username" _
[email protected]"
Jrn.Directive "CategoryDisciplineFilter" _
, -1
Jrn.Directive "DisciplineOption" _
, 7677
'H 13-Sep-2016 16:02:40.971; 0:<
Jrn.Directive "TabDisplayOptions" _
, "StayOnModifyInProject", 0
, "StayOnModifyInFamily", 1
, "ActiveCtOnSelection", 1
Jrn.Directive "AllowLinkSelection" _
, 1
Jrn.Directive "AllowFaceSelection" _
, 0
Jrn.Directive "AllowUnderlaySelection" _
, 0
Jrn.Directive "AllowPinnedSelection" _
, 1
Jrn.Directive "ThinLinesEnabled" _
, 0
'C 13-Sep-2016 16:02:40.981; 1:< logging master created MasterQueue Session6132_P0MasterQueue
'C 13-Sep-2016 16:02:40.982; 1:< logging started queue minder
'C 13-Sep-2016 16:02:40.982; 1:< logging started worker services
' 0:< ::0:: Delta VM: Avail -18 -> 134216431 MB, Used +0 -> 171 MB, Peak +1 -> 172 MB; RAM: Avail -14 -> 62590 MB, Used +1 -> 273 MB, Peak +5 -> 277 MB
' 0:< GUI Resource Usage GDI: Avail 9835, Used 165, User: Used 249108103344
' 0:< API_SUCCESS { Registered an external service: Name(NavisWorks Draw Service); VendorId(ADSK); ServiceId(e454a471-b9f3-4cb7-96b1-bab4cf7742a6) }
' 0:< API_SUCCESS { Registered an external service: Name(External Resource Service); VendorId(ADSK); ServiceId(b3892e5f-9161-4bbc-958a-c8ef75e94e96) }
' 0:< API_SUCCESS { Registered an external service: Name(NavisworksExportService); VendorId(ADSK); ServiceId(a9bdf0fd-2632-429e-bc35-50ebc2b824d2) }
' 0:< API_SUCCESS { Registered an external service: Name(Code Checking Parameter Service); VendorId(ADSK); ServiceId(de6db8de-dea6-40bd-9503-4ffe62ff6143) }
' 0:< API_SUCCESS { Registered an external service: Name(FramingProfileService); VendorId(ADSK); ServiceId(b2f816c0-6493-4537-8067-78a4e67f559e) }
' 0:< API_SUCCESS { Registered an external service: Name(Modify Connection Parameters Service); VendorId(ADSK); ServiceId(e9c0f948-320e-4e7f-a573-10755555305d) }
' 0:< API_SUCCESS { Registered an external service: Name(Connection Type Changed Service); VendorId(ADSK); ServiceId(e31c3100-9cab-4303-b85b-4171703ce1c4) }
' 0:< API_SUCCESS { Registered an external service: Name(SteelConnectionsService); VendorId(ADSK); ServiceId(282385f9-9627-4057-8b74-826d019f103c) }
' 0:< API_SUCCESS { Registered an external service: Name(Section Type Parameter Service); VendorId(ADSK); ServiceId(c42c9b55-c491-4611-97e9-9e617958e13e) }
' 0:< API_SUCCESS { Registered an external service: Name(Internal Forces Service); VendorId(ADSK); ServiceId(a97444aa-af8d-4a1e-af1f-fa7b77b368ee) }
' 0:< API_SUCCESS { Registered an external service: Name(IFC Export Service); VendorId(ADSK); ServiceId(d8b95737-f943-414c-9ad7-86785bf1acbc) }
' 0:< API_SUCCESS { Registered an external server: Name(Revit IFC Exporter); VendorId(ADSK); ServerId(ef8d0493-7f36-42b5-b9aa-8aaac716482b); ServiceId(d8b95737-f943-414c-9ad7-86785bf1acbc) }
' 0:< API_SUCCESS { Registered an external service: Name(IFC Import Service); VendorId(ADSK); ServiceId(98d317e2-e943-4cc0-a3da-2edf32a5d942) }
' 0:< API_SUCCESS { Registered an external server: Name(Revit IFC Importer); VendorId(ADSK); ServerId(660a7370-f6d6-43c8-8456-6b2eea785110); ServiceId(98d317e2-e943-4cc0-a3da-2edf32a5d942) }
' 0:< API_SUCCESS { Registered an external service: Name(Duct Fitting/Accessory Pressure Drop Calculator); VendorId(ADSK); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external service: Name(Pipe Fitting/Accessory Pressure Drop Calculator); VendorId(ADSK); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Registered an external service: Name(Duct Pressure Drop Calculator); VendorId(ADSK); ServiceId(8c707bd6-ecd6-4150-a0df-bd6c85dd9bb0) }
' 0:< API_SUCCESS { Registered an external service: Name(Pipe Pressure Drop Calculator); VendorId(ADSK); ServiceId(62d13e0c-9fe1-4d8e-a0c7-1f93d24cf3f3) }
' 0:< API_SUCCESS { Registered an external service: Name(Plumbing Flow Calculator); VendorId(ADSK); ServiceId(bf0da776-5307-4747-8285-f358e92a90d0) }
' 0:< API_SUCCESS { Registered an external service: Name(External Resource UI Service); VendorId(ADSK); ServiceId(1fe75ba7-79d4-45f6-8e31-c1b83d4476a9) }
' 0:< API_SUCCESS { Registered an external service: Name(Point Cloud Snapping Service); VendorId(ADSK); ServiceId(aaa05780-790c-43dc-bc41-1c2150227f45) }
' 0:< API_SUCCESS { Registered an external service: Name(Duct fitting and accessory pressure drop UI service); VendorId(ADSK); ServiceId(52009bda-c817-4aef-aa31-36dc3742516e) }
' 0:< API_SUCCESS { Registered an external service: Name(Pipe fitting and accessory pressure drop UI service); VendorId(ADSK); ServiceId(1931b323-1d29-4083-b1ce-bfdcddd011af) }
' 0:< ::0:: Delta VM: Avail -40 -> 134216392 MB, Used +18 -> 189 MB, Peak +17 -> 189 MB; RAM: Avail -109 -> 62482 MB, Used +14 -> 287 MB, Peak +9 -> 287 MB
' 0:< GUI Resource Usage GDI: Avail 9835, Used 165, User: Used 249108103346
' 0.168375 1:<<:initialize>
' 0:< ::0:: Delta VM: Avail -223 -> 134216169 MB, Used +68 -> 257 MB, Peak +68 -> 258 MB; RAM: Avail -145 -> 62337 MB, Used +90 -> 378 MB, Peak +90 -> 378 MB
' 0:< To make IFC server work.
' 0:< API_SUCCESS { Registered an external server: Name(Revit Default DB Server); VendorId(ADSK); ServerId(bd4f0f53-394a-4468-b37e-1e7949013382); ServiceId(b3892e5f-9161-4bbc-958a-c8ef75e94e96) }
' 0:< API_SUCCESS { Starting External DB Application: KeynoteDBServer, Class: KeynoteDBServer.ServerApp, Vendor : ADSK(Autodesk,
www.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit 2017\AddIns\Keynote\KeynoteDBServer.dll }
' 0:< API_SUCCESS { Registered an external server: Name(Plumbing Fixture Flow); VendorId(ADSK); ServerId(56121d7d-e1d7-42a3-bed8-f4d1d32058c8); ServiceId(bf0da776-5307-4747-8285-f358e92a90d0) }
' 0:< API_SUCCESS { Registered an external server: Name(Simplified Colebrook Equation); VendorId(ADSK); ServerId(ea275fb1-5d7b-47d6-b828-bf856df9bfd5); ServiceId(62d13e0c-9fe1-4d8e-a0c7-1f93d24cf3f3) }
' 0:< API_SUCCESS { Registered an external server: Name(Altshul-Tsal Equation); VendorId(ADSK); ServerId(042a10e0-8d24-46a4-9596-d192b3125d0c); ServiceId(8c707bd6-ecd6-4150-a0df-bd6c85dd9bb0) }
' 0:< API_SUCCESS { Registered an external server: Name(Haaland Equation); VendorId(USERADDIN); ServerId(2e9a77c0-62a0-4693-9442-33312be60ad7); ServiceId(8c707bd6-ecd6-4150-a0df-bd6c85dd9bb0) }
' 0:< API_SUCCESS { Registered an external server: Name(Haaland Equation); VendorId(USERADDIN); ServerId(58ea1b7c-2fca-453f-9ab9-7a3b9927ecc1); ServiceId(62d13e0c-9fe1-4d8e-a0c7-1f93d24cf3f3) }
' 0:< API_SUCCESS { Registered an external server: Name(Colebrook Equation); VendorId(USERADDIN); ServerId(e395a0ec-48a4-4255-b957-afbb3d73cb67); ServiceId(8c707bd6-ecd6-4150-a0df-bd6c85dd9bb0) }
' 0:< API_SUCCESS { Registered an external server: Name(Colebrook Equation); VendorId(USERADDIN); ServerId(0875f550-6141-4e34-a6b7-547cf9cfda01); ServiceId(62d13e0c-9fe1-4d8e-a0c7-1f93d24cf3f3) }
' 0:< API_SUCCESS { Starting External DB Application: StraightSegmentCalculationServersApp, Class: StraightSegmentCalculationServers.ServerApp, Vendor : ADSK(Autodesk,
www.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit 2017\AddIns\MEPCalculation\StraightSegmentCalculationServers.dll }
' 0:< API_SUCCESS { Registered an external server: Name(Not Defined); VendorId(ADSK); ServerId(76eff5da-2e71-45f7-b940-cc5716328ba0); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external server: Name(Coefficient from ASHRAE Table); VendorId(ADSK); ServerId(8baf7d75-8b9b-46d0-b8ce-3ad1c19e6b19); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external server: Name(Specific Coefficient); VendorId(ADSK); ServerId(5a598293-1504-46cc-a9c0-de55c82848b9); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external server: Name(Specific Loss); VendorId(ADSK); ServerId(46245996-eebb-4536-ac17-9c1cd917d8cf); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external server: Name(Not Defined); VendorId(ADSK); ServerId(61e7b8e1-16d1-4fe4-82f0-327af736323f); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Registered an external server: Name(K Coefficient from Table); VendorId(ADSK); ServerId(51dd5e98-a9dd-464b-b286-4a37953610bf); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Registered an external server: Name(Specific Coefficient); VendorId(ADSK); ServerId(32d58662-b467-4f7b-b728-f6ad7b7ba5e3); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Registered an external server: Name(Specific Loss); VendorId(ADSK); ServerId(16f4f7be-0ac0-461d-a9a4-1d3511cd280e); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Starting External DB Application: FittingAndAccessoryCalculationServers, Class: FittingAndAccessoryCalculationServers.ServerApp, Vendor : ADSK(Autodesk,
www.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit 2017\AddIns\MEPCalculation\FittingAndAccessoryCalculationServers.dll }
' 0:< API_SUCCESS { Registered an external server: Name(SteelConnectionsServer); VendorId(ADSK); ServerId(9c209d4a-ec98-460f-bfde-38f17a3443b4); ServiceId(282385f9-9627-4057-8b74-826d019f103c) }
' 0:< API_SUCCESS { Registered an external server: Name(FramingProfileServer); VendorId(ADSK); ServerId(54e490cd-8809-4dbb-84dd-dc0bc6cb1712); ServiceId(b2f816c0-6493-4537-8067-78a4e67f559e) }
' 0:< API_SUCCESS { Starting External DB Application: ExternalResourceDBServer, Class: RvtSteelConnectionsDB.SteelConnectionDBApplication, Vendor : ADSK(Autodesk,
www.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit 2017\AddIns\SteelConnections\RvtSteelConnectionsDB.dll }
' 0:< ::0:: Delta VM: Avail -7 -> 134216163 MB, Used +2 -> 260 MB, Peak +3 -> 261 MB; RAM: Avail -12 -> 62325 MB, Used +10 -> 388 MB, Peak +10 -> 388 MB
' 0:< API_SUCCESS { Registering DocumentOpening event by application CollaborateDB (bb3086be-63bb-44bd-99eb-d584c013cf2f). }
' 0:< API_SUCCESS { Registering DocumentSavedAs event by application CollaborateDB (bb3086be-63bb-44bd-99eb-d584c013cf2f). }
' 0:< API_SUCCESS { Registering DocumentOpened event by application CollaborateDB (bb3086be-63bb-44bd-99eb-d584c013cf2f). }
' 0:< API_SUCCESS { Registering DocumentClosing event by application CollaborateDB (bb3086be-63bb-44bd-99eb-d584c013cf2f). }
' 0:< API_SUCCESS { Starting External DB Application: CollaborateDB, Class: Autodesk.Revit.UI.Collaborate.CollaborateDBApplication, Vendor : ADSK(Autodesk,
www.autodesk.com), Assembly: C:\Program Files\Autodesk\A360 Collaboration for Revit 2017\CollaborateDB.dll }
' 0:< ::0:: Delta VM: Avail -26 -> 134216137 MB, Used +8 -> 269 MB, Peak +8 -> 270 MB; RAM: Avail -11 -> 62315 MB, Used +12 -> 401 MB, Peak +12 -> 401 MB
' 0:< GUI Resource Usage GDI: Avail 9835, Used 165, User: Used 249108103350
' 0:< API_SUCCESS { Registering ApplicationClosing event by application RaaS (d4f6554b-5d68-4a13-beec-4a0647c34408). }
' 0:< API_SUCCESS { Replacing command id 'ID_PHOTO_RENDER_IN_CLOUD' Executed implementation with implementation from application 'RaaS' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\RaaSForRevit\RaaSApplication.dll'. }
' 0:< API_SUCCESS { API registering command Executed event by application RaaS (d4f6554b-5d68-4a13-beec-4a0647c34408). }
' 0:< API_SUCCESS { Replacing command id 'ID_PHOTO_RENDER_IN_CLOUD' CanExecute implementation with implementation from application 'RaaS' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\RaaSForRevit\RaaSApplication.dll'. }
' 0:< API_SUCCESS { API registering command CanExecute event by application RaaS (d4f6554b-5d68-4a13-beec-4a0647c34408). }
' 0:< API_SUCCESS { Replacing command id 'ID_PHOTO_RENDER_GALLERY' Executed implementation with implementation from application 'RaaS' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\RaaSForRevit\RaaSApplication.dll'. }
' 0:< API_SUCCESS { Replacing command id 'ID_PHOTO_RENDER_GALLERY' CanExecute implementation with implementation from application 'RaaS' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\RaaSForRevit\RaaSApplication.dll'. }
' 0:< API_SUCCESS { Starting External Application: RaaS, Class: Autodesk.RaaS.RevitAddin.EApplication, Vendor : ADSK(Autodesk,
www.autodesk.com), Assembly: RaaSApplication.dll }
'H 13-Sep-2016 16:02:46.220; 0:<
Jrn.Directive "IdleTimeTaskSymbol" _
, "0.ExternalEvent"
' 0:< API_SUCCESS { Starting External Application: AutoLoad, Class: AutoLoader.AutoLoader, Vendor : ADSK(), Assembly: AutoLoader.dll }
' 0:< API_SUCCESS { Registering ViewActivated event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Registering DocumentClosing event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Registering DocumentClosed event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Registering DocumentChanged event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Registering DockableFrameVisibilityChanged event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
'H 13-Sep-2016 16:02:46.325; 0:<
, "1.OnIdleTask"
' 0:< API_SUCCESS { Registering Idling event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Registering FabricationPartBrowserChanged event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_FABRICATION_SETTINGS' CanExecute implementation with implementation from application 'FabPartBrowserApplication' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\FabricationPartBrowser\FabricationPartBrowser.dll'. }
' 0:< API_SUCCESS { API registering command Fabrication Settings CanExecute event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_FABRICATION_SETTINGS' Executed implementation with implementation from application 'FabPartBrowserApplication' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\FabricationPartBrowser\FabricationPartBrowser.dll'. }
' 0:< API_SUCCESS { API registering command Fabrication Settings Executed event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Replacing command id 'ID_FABRICATION_PART_SHOW_SERVICE_IN_PART_BROWSER' CanExecute implementation with implementation from application 'FabPartBrowserApplication' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\FabricationPartBrowser\FabricationPartBrowser.dll'. }
' 0:< API_SUCCESS { API registering command Show Service in Part Browser
'Show Service in Part Browser
'Show Service in Part Browser CanExecute event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Starting External Application: FabPartBrowserApplication, Class: FabricationPartBrowser.FabPartBrowserApplication, Vendor : ADSK(Autodesk,
www.autodesk.com), Assembly: FabricationPartBrowser.dll }
' 0:< API_SUCCESS { Registered an external server: Name(Duct not defined pressure drop UI server); VendorId(ADSK); ServerId(607992d7-359d-4593-b497-8aa238e2c564); ServiceId(52009bda-c817-4aef-aa31-36dc3742516e) }
' 0:< API_SUCCESS { Registered an external server: Name(Duct specific coefficient pressure drop UI server); VendorId(ADSK); ServerId(9641a039-441e-42e2-93a6-c0e2177cc23c); ServiceId(52009bda-c817-4aef-aa31-36dc3742516e) }
' 0:< API_SUCCESS { Registered an external server: Name(Duct specific loss pressure drop UI server); VendorId(ADSK); ServerId(d3b5e81d-9b8c-40da-8efb-99dd37fda611); ServiceId(52009bda-c817-4aef-aa31-36dc3742516e) }
' 0:< API_SUCCESS { Registered an external server: Name(Duct coefficient from table pressure drop UI server); VendorId(ADSK); ServerId(25fa8de2-67c4-47d1-91f6-bd6f0803a5ed); ServiceId(52009bda-c817-4aef-aa31-36dc3742516e) }
' 0:< API_SUCCESS { Registered an external server: Name(Pipe not defined pressure drop UI server); VendorId(ADSK); ServerId(62917391-e14d-4897-ad0c-05342d71e4f9); ServiceId(1931b323-1d29-4083-b1ce-bfdcddd011af) }
' 0:< API_SUCCESS { Registered an external server: Name(Pipe specific coefficient pressure drop UI server); VendorId(ADSK); ServerId(247265b6-7b71-4147-97c6-cc52b39c12aa); ServiceId(1931b323-1d29-4083-b1ce-bfdcddd011af) }
' 0:< API_SUCCESS { Registered an external server: Name(Pipe specific loss pressure drop UI server); VendorId(ADSK); ServerId(5978b92a-3f0b-4691-bbc8-caf2fae20a71); ServiceId(1931b323-1d29-4083-b1ce-bfdcddd011af) }
' 0:< API_SUCCESS { Registered an external server: Name(Pipe K coefficient from table pressure drop UI server); VendorId(ADSK); ServerId(cda19b6f-fbd5-4725-a0ce-f159bf5d02fe); ServiceId(1931b323-1d29-4083-b1ce-bfdcddd011af) }
' 0:< API_SUCCESS { Starting External Application: FittingAndAccessoryCalculationUIServers, Class: FittingAndAccessoryCalculationUIServers.ServerApp, Vendor : ADSK(Autodesk,
www.autodesk.com), Assembly: FittingAndAccessoryCalculationUIServers.dll }
' 0:< API_SUCCESS { Replacing command id 'ID_EXPORT_IFC' Executed implementation with implementation from application 'IFC override' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\IFCExporterUI\IFCExportUI.dll'. }
' 0:< API_SUCCESS { API registering command Export to IAI IFC (Industry Foundation Classes) file format Executed event by application IFC override (e78da2e3-7e89-464c-97cd-2212c8be3fa8). }
' 0:< API_SUCCESS { Starting External Application: IFC override, Class: BIM.IFC.Export.UI.IFCCommandOverrideApplication, Vendor : ADSK(Autodesk,
www.autodesk.com), Assembly: IFCExportUI.dll }
' 0:< API_SUCCESS { Starting External Application: Import Shape, Class: ImportShape.ImportShape, Vendor : ADSK(Autodesk,
www.autodesk.com), Assembly: ImportShape.dll }
' 0:< API_SUCCESS { Registered an external server: Name(Revit Default UI Server.); VendorId(ADSK); ServerId(3ffc688a-bb2e-4145-90ab-9443da02aef6); ServiceId(1fe75ba7-79d4-45f6-8e31-c1b83d4476a9) }
' 0:< API_SUCCESS { Starting External Application: KeynoteUIServer, Class: KeynoteUIServer.ServerApp, Vendor : ADSK(Autodesk,
www.autodesk.com), Assembly: KeynoteUIServer.dll }
' 0:< API_SUCCESS { Registered an external server: Name(Internal Forces Server); VendorId(ADSK); ServerId(a97444aa-af8d-4a1e-af1f-fa7b77b368ee); ServiceId(a97444aa-af8d-4a1e-af1f-fa7b77b368ee) }
' 0:< API_SUCCESS { Starting External Application: Member Forces, Class: MemberForcesUI.ServerApp, Vendor : ADSK(Autodesk,
www.autodesk.com), Assembly: MemberForces.dll }
' 0:< API_SUCCESS { Replacing command id 'ID_NUMBERING_REINF_PARTITIONS' Executed implementation with implementation from application 'Object Numbering' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\ObjectNumbering\ObjectNumberingUI.dll'. }
' 0:< API_SUCCESS { API registering command Executed event by application Object Numbering (32b5860a-aec9-4df7-96b0-07168b27446e). }
' 0:< API_SUCCESS { Replacing command id 'ID_NUMBERING_REINF_PARTITIONS' CanExecute implementation with implementation from application 'Object Numbering' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\ObjectNumbering\ObjectNumberingUI.dll'. }
' 0:< API_SUCCESS { API registering command CanExecute event by application Object Numbering (32b5860a-aec9-4df7-96b0-07168b27446e). }
' 0:< API_SUCCESS { Starting External Application: Object Numbering, Class: BIM.Numbering.UI.NumberingUIApplication, Vendor : ADSK(Autodesk,
www.autodesk.com), Assembly: ObjectNumberingUI.dll }
' 0:< API_SUCCESS { Registered an external server: Name(PointCloudSnappingServer); VendorId(ADSK); ServerId(85f4b666-8811-4e3d-9ed4-3d2ae4cd2e4c); ServiceId(aaa05780-790c-43dc-bc41-1c2150227f45) }
' 0:< Third Party Updater 'PointCloudSnappingServer: Snapping Pipe Updater' registered for all documents.
' 0:< API_SUCCESS { Starting External Application: PointCloudSnappingServer, Class: PointCloudSnappingServer.Application, Vendor : ADSK(Autodesk,
www.autodesk.com), Assembly: PointCloudSnappingServer.dll }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_DUCT_PRESSURE_LOSS_REPORT' CanExecute implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { API registering command Duct Pressure Loss Report CanExecute event by application PressureLossReport (b00d3753-d3bc-4255-9c97-e389de87a5d6). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_DUCT_PRESSURE_LOSS_REPORT' Executed implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { API registering command Duct Pressure Loss Report Executed event by application PressureLossReport (b00d3753-d3bc-4255-9c97-e389de87a5d6). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_PIPE_PRESSURE_LOSS_REPORT' CanExecute implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { API registering command Pipe Pressure Loss Report CanExecute event by application PressureLossReport (b00d3753-d3bc-4255-9c97-e389de87a5d6). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_PIPE_PRESSURE_LOSS_REPORT' Executed implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { API registering command Pipe Pressure Loss Report Executed event by application PressureLossReport (b00d3753-d3bc-4255-9c97-e389de87a5d6). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_SELECT_DUCT_PRESSURE_LOSS_REPORT' CanExecute implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_SELECT_DUCT_PRESSURE_LOSS_REPORT' Executed implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_SELECT_PIPE_PRESSURE_LOSS_REPORT' CanExecute implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_SELECT_PIPE_PRESSURE_LOSS_REPORT' Executed implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { Starting External Application: PressureLossReport, Class: PressureLossReport.PressureLossReportApplication, Vendor : ADSK(Autodesk,
www.autodesk.com), Assembly: PressureLossReport.dll }
' 0:< API_SUCCESS { Registered an external server: Name(SectionTypeParameterServer); VendorId(ADSK); ServerId(1b91ce46-ddb4-44ec-a942-d45efadde353); ServiceId(c42c9b55-c491-4611-97e9-9e617958e13e) }
' 0:< API_SUCCESS { Starting External Application: Structural Section Properties, Class: SectionProperties.ServerApp, Vendor : ADSK(Autodesk,
www.autodesk.com), Assembly: SectionProperties.dll }
' 0:< ::0:: Delta VM: Avail -38 -> 134216100 MB, Used +4 -> 273 MB, Peak +4 -> 274 MB; RAM: Avail -9 -> 62306 MB, Used +8 -> 409 MB, Peak +8 -> 410 MB
' 0:< GUI Resource Usage GDI: Avail 9831, Used 169, User: Used 249108103351
' 0:< API_SUCCESS { Registering DocumentCreated event by application Common (4e6988f3-7c3a-41a6-aa31-511fa8f0f451). }
' 0:< API_SUCCESS { Registering DocumentOpened event by application Common (4e6988f3-7c3a-41a6-aa31-511fa8f0f451). }
' 0:< API_SUCCESS { Registering DocumentSaving event by application Common (4e6988f3-7c3a-41a6-aa31-511fa8f0f451). }
' 0:< API_SUCCESS { Registering DocumentSavingAs event by application Common (4e6988f3-7c3a-41a6-aa31-511fa8f0f451). }
' 0:< API_SUCCESS { Registering DocumentSynchronizedWithCentral event by application Common (4e6988f3-7c3a-41a6-aa31-511fa8f0f451). }
' 0:< API_SUCCESS { Registering DocumentSynchronizingWithCentral event by application Common (4e6988f3-7c3a-41a6-aa31-511fa8f0f451). }
' 0:< API_SUCCESS { Registering DocumentClosing event by application Common (4e6988f3-7c3a-41a6-aa31-511fa8f0f451). }
' 0:< API_SUCCESS { Registering DocumentChanged event by application Common (4e6988f3-7c3a-41a6-aa31-511fa8f0f451). }
' 0:< API_SUCCESS { Registering FileExporting event by application Common (4e6988f3-7c3a-41a6-aa31-511fa8f0f451). }
' 0:< API_SUCCESS { Registering FileExported event by application Common (4e6988f3-7c3a-41a6-aa31-511fa8f0f451). }
' 0:< API_SUCCESS { Registering ViewActivated event by application Common (4e6988f3-7c3a-41a6-aa31-511fa8f0f451). }
' 0:< Third Party Updater 'Common: DrxUpdater' registered for all documents.
' 0:< API_SUCCESS { Starting External Application: Common, Class: Adsk.DrxApplication.DrxCommonApp, Vendor : ADSK(Autodesk,
www.autodesk.com), Assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Areabook\Program\DrxCommon.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6400, name: , text: Calculate Areas, class: Adsk.DrxApplication.DrxAreaCalculationCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Areabook\Program\AreaCalculation.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6401, name: , text: Edit Room, class: Adsk.DrxApplication.DrxRoomEditCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Areabook\Program\AreaCalculation.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6402, name: , text: Add/Edit Floor Area, class: Adsk.DrxApplication.DrxFloorAreaAddCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Areabook\Program\AreaCalculation.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6403, name: , text: Add Room Group, class: Adsk.DrxApplication.DrxRoomGroupAddCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Areabook\Program\AreaCalculation.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6404, name: , text: Edit Room Group, class: Adsk.DrxApplication.DrxRoomGroupEditCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Areabook\Program\AreaCalculation.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6405, name: , text: Calculation Settings, class: Adsk.DrxApplication.DrxAreaCalculationOptionsCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Areabook\Program\AreaCalculation.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6406, name: , text: Edit Room Assignment Type, class: Adsk.DrxApplication.DrxRoomAssignmentsEditCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Areabook\Program\AreaCalculation.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6407, name: , text: Hide/Show Areabook IDs, class: Adsk.DrxApplication.DrxAreaToggleIDsCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Areabook\Program\AreaCalculation.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6408, name: , text: Set language, class: Adsk.DrxApplication.DrxChangeUILanguageCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Areabook\Program\AreaCalculation.dll }
' 0:< API_SUCCESS { Starting External Application: Area Calculation International, Class: Adsk.DrxApplication.DrxAreaCalculationApp, Vendor : ADSK(Autodesk,
www.autodesk.com), Assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Areabook\Program\AreaCalculation.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6409, name: , text: Batch Print, class: Revit.PrintHarness.PrintHarnessAPI, assembly: C:\Program Files\Autodesk\Batch Print for Revit 2017\BatchPrint.dll }
' 0:< API_SUCCESS { Starting External Application: Batch Print Application, Class: Revit.PrintHarness.PrintHarnessApplication, Vendor : ADSK(Autodesk, subscription.autodesk.com), Assembly: C:\Program Files\Autodesk\Batch Print for Revit 2017\BatchPrint.dll }
' 0:< API_SUCCESS { Registering ViewActivated event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Replacing command id 'ID_COLLABORATE' Executed implementation with implementation from application 'Collaborate' dll 'C:\Program Files\Autodesk\A360 Collaboration for Revit 2017\Collaborate.dll'. }
' 0:< API_SUCCESS { API registering command Collaborate Executed event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Replacing command id 'ID_COLLABORATE' CanExecute implementation with implementation from application 'Collaborate' dll 'C:\Program Files\Autodesk\A360 Collaboration for Revit 2017\Collaborate.dll'. }
' 0:< API_SUCCESS { API registering command Collaborate CanExecute event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Replacing command id 'ID_COLLABORATE_360' Executed implementation with implementation from application 'Collaborate' dll 'C:\Program Files\Autodesk\A360 Collaboration for Revit 2017\Collaborate.dll'. }
' 0:< API_SUCCESS { API registering command Executed event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Replacing command id 'ID_COLLABORATE_360' CanExecute implementation with implementation from application 'Collaborate' dll 'C:\Program Files\Autodesk\A360 Collaboration for Revit 2017\Collaborate.dll'. }
' 0:< API_SUCCESS { API registering command CanExecute event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Starting External Application: Collaborate, Class: Autodesk.Revit.UI.Collaborate.CollaborateApplication, Vendor : ADSK(Autodesk,
www.autodesk.com), Assembly: C:\Program Files\Autodesk\A360 Collaboration for Revit 2017\Collaborate.dll }
' 0:< API_SUCCESS { Replacing command id 'ID_COLLABORATE_BROWSER' Executed implementation with implementation from application 'CollaborateBrowser' dll 'C:\Program Files\Autodesk\A360 Collaboration for Revit 2017\CollaborateBrowser.dll'. }
' 0:< API_SUCCESS { API registering command A360 Projects Executed event by application CollaborateBrowser (901c7e33-857c-4c9c-846c-8f971c7cf72a). }
' 0:< API_SUCCESS { Replacing command id 'ID_COLLABORATE_BROWSER' CanExecute implementation with implementation from application 'CollaborateBrowser' dll 'C:\Program Files\Autodesk\A360 Collaboration for Revit 2017\CollaborateBrowser.dll'. }
' 0:< API_SUCCESS { API registering command A360 Projects CanExecute event by application CollaborateBrowser (901c7e33-857c-4c9c-846c-8f971c7cf72a). }
' 0:< API_SUCCESS { Starting External Application: CollaborateBrowser, Class: Autodesk.Revit.UI.CollaborateBrowser.CollaborateBrowserApplication, Vendor : ADSK(Autodesk,
www.autodesk.com), Assembly: C:\Program Files\Autodesk\A360 Collaboration for Revit 2017\CollaborateBrowser.dll }
'C 13-Sep-2016 16:02:47.415; 0:< Loading bcg.dll: Autodesk.Bcg, Version=1.7.3.0, Culture=neutral, PublicKeyToken=d672471c03b2c408
'C 13-Sep-2016 16:02:47.500; 0:< SkyscraperClientHost: Initialize Success: True
' 0:< API_SUCCESS { Starting External Application: SkyscraperClientHostApplication, Class: SkyscraperClientHost.SkyscraperClientHostApplication, Vendor : ADSK(Autodesk,
www.autodesk.com), Assembly: C:\Program Files\Autodesk\A360 Collaboration for Revit 2017\SkyscraperClientHost.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6410, name: , text: Transmit a model, class: eTransmitForRevit.eTransmitCommand, assembly: C:\Program Files\Autodesk\eTransmit for Revit 2017\eTransmitForRevit.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6411, name: , text: Help, class: eTransmitForRevit.eTransmitHelp, assembly: C:\Program Files\Autodesk\eTransmit for Revit 2017\eTransmitForRevit.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6412, name: , text: About, class: eTransmitForRevit.eTransmitAbout, assembly: C:\Program Files\Autodesk\eTransmit for Revit 2017\eTransmitForRevit.dll }
' 0:< API_SUCCESS { Starting External Application: eTransmit for Revit, Class: eTransmitForRevit.eTransmitApplication, Vendor : ADSK(Autodesk,
www.autodesk.com), Assembly: C:\Program Files\Autodesk\eTransmit for Revit 2017\eTransmitForRevit.dll }
' 0:< ::0:: Delta VM: Avail -12 -> 134216088 MB, Used +2 -> 275 MB, Peak +1 -> 276 MB; RAM: Avail +0 -> 62307 MB, Used +4 -> 414 MB, Peak +4 -> 414 MB
' 0:< API_SUCCESS { Added pushbutton Id: 6413, name: , text: Check, class: BIMStandardsManager.Command, assembly: C:\Program Files\Autodesk\Revit Model Review 2017\ModelReview.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6414, name: , text: Manage, class: BIMStandardsManager.CommandConfig, assembly: C:\Program Files\Autodesk\Revit Model Review 2017\ModelReview.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6415, name: , text: View, class: BIMStandardsManager.CommandReview, assembly: C:\Program Files\Autodesk\Revit Model Review 2017\ModelReview.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6416, name: , text: About..., class: BIMStandardsManager.CommandAbout, assembly: C:\Program Files\Autodesk\Revit Model Review 2017\ModelReview.dll }
' 0:< ::0:: Delta VM: Avail 134216088 MB, Used 275 MB; RAM: Avail +10 -> 62317 MB, Used -11 -> 403 MB
' 0:< GUI Resource Usage GDI: Avail 9827, Used 173, User: Used 249108103351
' 0:< API_SUCCESS { Starting External Application: Model Review, Class: BIMStandardsManager.ExternalApp, Vendor : ADSK(Autodesk, subscription.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit Model Review 2017\ModelReview.dll }
' 0:< API_SUCCESS { Registering DocumentOpened event by application Model Review Events (1469753f-186d-4dc2-b0e9-431b302e62f9). }
' 0:< API_SUCCESS { Registering DocumentSaving event by application Model Review Events (1469753f-186d-4dc2-b0e9-431b302e62f9). }
' 0:< API_SUCCESS { Registering DocumentSavingAs event by application Model Review Events (1469753f-186d-4dc2-b0e9-431b302e62f9). }
' 0:< API_SUCCESS { Registering DocumentSynchronizingWithCentral event by application Model Review Events (1469753f-186d-4dc2-b0e9-431b302e62f9). }
' 0:< API_ERROR { Starting External Application: Model Review Events, Class: BIMStandardsManager.CommandEventsApp, Vendor : ADSK(Autodesk, subscription.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit Model Review 2017\ModelReview.dll }
' 0:< API_SUCCESS { Registering ApplicationInitialized event by application AREXRevitStart (26a4f622-eb0a-4829-a9c3-9194b77a7fe4). }
' 0:< API_SUCCESS { Starting External Application: AREXRevitStart, Class: REX.AREXRevitStart.AREXRevitStart, Vendor : ADSK(), Assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Products\Revit\AREXRevitStart.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6417, name: , text: Revit DB Link, class: Revit.Addon.RevitDBLink.CS.Command, assembly: C:\Program Files\Autodesk\Revit DB Link 2017\RevitDBLink.dll }
' 0:< API_SUCCESS { Starting External Application: RevitDBLink, Class: Revit.Addon.RevitDBLink.CS.App, Vendor : ADSK(Autodesk, subscription.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit DB Link 2017\RevitDBLink.dll }
' 0:< API_SUCCESS { Registering ApplicationInitialized event by application AREXRevitStart (c0566ed7-4309-4082-b3ba-ea6b7b4d292a). }
' 0:< API_SUCCESS { Registering ApplicationInitialized event by application AREXRevitStart (1aa95c7e-ebf6-4205-b465-993f7efdc2e1). }
' 0:< API_SUCCESS { Added pushbutton Id: 6418, name: , text: Launch SNU, class: SpaceNaming.Command, assembly: C:\Program Files\Autodesk\Space Naming Utility for Revit MEP 2017\SpaceNaming.dll }
' 0:< API_SUCCESS { Starting External Application: Space Naming Utility Application, Class: SpaceNaming.Command, Vendor : ADSK(Autodesk, subscription.autodesk.com), Assembly: C:\Program Files\Autodesk\Space Naming Utility for Revit MEP 2017\SpaceNaming.dll }
' 0:< API_SUCCESS { Registering ApplicationInitialized event by application AREXRevitStart (be4833f0-363a-4442-82f9-fc2805b4220f). }
' 0:< API_SUCCESS { Registering DocumentOpened event by application Worksharing Monitor Application (04e9bc6c-9b81-4c82-a31a-7559fe7a1579). }
' 0:< API_SUCCESS { Registering DocumentClosing event by application Worksharing Monitor Application (04e9bc6c-9b81-4c82-a31a-7559fe7a1579). }
' 0:< API_SUCCESS { Registering DocumentSaved event by application Worksharing Monitor Application (04e9bc6c-9b81-4c82-a31a-7559fe7a1579). }
' 0:< API_SUCCESS { Registering DocumentSavedAs event by application Worksharing Monitor Application (04e9bc6c-9b81-4c82-a31a-7559fe7a1579). }
' 0:< API_SUCCESS { Starting External Application: Worksharing Monitor Application, Class: WorkSharingLib.ExternalApplication, Vendor : ADSK(Autodesk, subscription.autodesk.com), Assembly: C:\Program Files\Autodesk\Worksharing Monitor for Revit 2017\WorkSharingLib.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6419, name: , text: Launch WSM, class: WorksharingCommand.WorksharingCommand, assembly: C:\Program Files\Autodesk\Worksharing Monitor for Revit 2017\WorkSharingCommand.dll }
' 0:< API_SUCCESS { Starting External Application: Worksharing Monitor Launch App, Class: WorksharingCommand.WorksharingApp, Vendor : ADSK(Autodesk, subscription.autodesk.com), Assembly: C:\Program Files\Autodesk\Worksharing Monitor for Revit 2017\WorkSharingCommand.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6420, name: , text: Glue, class: BIM360RevitAddin.GlueItCommand, assembly: C:\ProgramData\Autodesk\Revit\Addins\2017\BIM360Glue\BIM360GlueRevit2017Addin.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6421, name: , text: Clash
'Pinpoint, class: BIM360RevitAddin.GluePinPointCommand, assembly: C:\ProgramData\Autodesk\Revit\Addins\2017\BIM360Glue\BIM360GlueRevit2017Addin.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6422, name: , text: Equipment
'Properties, class: BIM360RevitAddin.EquipmentCommand, assembly: C:\ProgramData\Autodesk\Revit\Addins\2017\BIM360Glue\BIM360GlueRevit2017Addin.dll }
' 0:< ::0:: Delta VM: Avail -26 -> 134216062 MB, Used +12 -> 287 MB, Peak +22 -> 298 MB; RAM: Avail -13 -> 62304 MB, Used +19 -> 423 MB, Peak +17 -> 432 MB
' 0:< GUI Resource Usage GDI: Avail 9819, Used 181, User: Used 249108103359
' 0:< API_SUCCESS { Registering ApplicationInitialized event by application Ribbon (c82755fa-ff61-5113-9a07-27b2127a13e5). }
' 0:< API_SUCCESS { Registering ApplicationClosing event by application Ribbon (c82755fa-ff61-5113-9a07-27b2127a13e5). }
' 0:< API_SUCCESS { Starting External Application: Ribbon, Class: BIM360RevitAddin.HorizontalRibbon, Vendor : BIM360(Autodesk, Inc,
www.autodesk.com), Assembly: BIM360Glue/BIM360GlueRevit2017Addin.dll }
' 0:< API_SUCCESS { Registering FailuresProcessing event by application Common (053ba6e7-1d1a-41e4-8529-c7cde73336e8). }
' 0:< API_SUCCESS { Registering DocumentCreated event by application Common (053ba6e7-1d1a-41e4-8529-c7cde73336e8). }
' 0:< API_SUCCESS { Registering DocumentOpened event by application Common (053ba6e7-1d1a-41e4-8529-c7cde73336e8). }
' 0:< API_SUCCESS { Registering DocumentSaving event by application Common (053ba6e7-1d1a-41e4-8529-c7cde73336e8). }
' 0:< API_SUCCESS { Registering DocumentSavingAs event by application Common (053ba6e7-1d1a-41e4-8529-c7cde73336e8). }
' 0:< API_SUCCESS { Registering DocumentSynchronizedWithCentral event by application Common (053ba6e7-1d1a-41e4-8529-c7cde73336e8). }
' 0:< API_SUCCESS { Registering DocumentSynchronizingWithCentral event by application Common (053ba6e7-1d1a-41e4-8529-c7cde73336e8). }
' 0:< API_SUCCESS { Registering DocumentClosing event by application Common (053ba6e7-1d1a-41e4-8529-c7cde73336e8). }
' 0:< API_SUCCESS { Registering DocumentChanged event by application Common (053ba6e7-1d1a-41e4-8529-c7cde73336e8). }
' 0:< API_SUCCESS { Registering DialogBoxShowing event by application Common (053ba6e7-1d1a-41e4-8529-c7cde73336e8). }
' 0:< API_SUCCESS { Registering FileExporting event by application Common (053ba6e7-1d1a-41e4-8529-c7cde73336e8). }
' 0:< API_SUCCESS { Registering FileExported event by application Common (053ba6e7-1d1a-41e4-8529-c7cde73336e8). }
' 0:< API_SUCCESS { Registering ViewActivated event by application Common (053ba6e7-1d1a-41e4-8529-c7cde73336e8). }
' 0:< Third Party Updater 'Common: BrxUpdater' registered for all documents.
' 0:< API_SUCCESS { Starting External Application: Common, Class: Adsk.BrxApplication.BrxCommonApp, Vendor : ADSK(Autodesk,
www.autodesk.com), Assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Buildingbook\Program\BrxCommon.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6423, name: , text: Calculate Building Part Quantities, class: Adsk.BrxApplication.BrxBuildingBookCalculationCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Buildingbook\Program\BuildingBook.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6424, name: , text: Calculation Settings, class: Adsk.BrxApplication.BrxBuildingBookCalcOptCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Buildingbook\Program\BuildingBook.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6425, name: , text: Quantity IDs: Show All, class: Adsk.BrxApplication.BrxShowQIDsCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Buildingbook\Program\BuildingBook.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6426, name: , text: Quantity IDs: Hide All, class: Adsk.BrxApplication.BrxHideQIDsCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Buildingbook\Program\BuildingBook.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6427, name: , text: Material IDs: Show All, class: Adsk.BrxApplication.BrxShowMaterialIDsCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Buildingbook\Program\BuildingBook.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6428, name: , text: Material IDs: Hide All, class: Adsk.BrxApplication.BrxHideMaterialIDsCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Buildingbook\Program\BuildingBook.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6429, name: , text: Hide/Show IDs by Category, class: Adsk.BrxApplication.BrxHideShowByCategoryCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Buildingbook\Program\BuildingBook.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6430, name: , text: Select Building Parts by ID, class: Adsk.BrxApplication.BrxBuildingBookSelectByQIDCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Buildingbook\Program\BuildingBook.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6431, name: , text: Purge discontinued versions data, class: Adsk.BrxApplication.BrxPurgeBPQ2014Cmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Buildingbook\Program\BuildingBook.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6432, name: , text: Set language, class: Adsk.BrxApplication.BrxChangeUILanguageCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Buildingbook\Program\BuildingBook.dll }
' 0:< API_SUCCESS { Starting External Application: BuildingBook International, Class: Adsk.BrxApplication.BrxBuildingBookApp, Vendor : ADSK(Autodesk,
www.autodesk.com), Assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Buildingbook\Program\BuildingBook.dll }
' 0:< ::0:: Delta VM: Avail -11 -> 134216052 MB, Used -2 -> 286 MB; RAM: Avail -1 -> 62303 MB, Used 423 MB
' 0:< API_SUCCESS { Registering ApplicationInitialized event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Registering DocumentOpened event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Registering DocumentCreated event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Registering DocumentSavedAs event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Registering DocumentSaved event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Registering DocumentClosed event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Registering ApplicationClosing event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Replacing command id 'ID_TEAM' Executed implementation with implementation from application 'Communicator for Autodesk Revit' dll 'C:\ProgramData\Autodesk\Revit\Addins\2017\Communicator\SmartMonkey.dll'. }
' 0:< API_SUCCESS { API registering command Communicator Executed event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Replacing command id 'ID_TEAM' CanExecute implementation with implementation from application 'Communicator for Autodesk Revit' dll 'C:\ProgramData\Autodesk\Revit\Addins\2017\Communicator\SmartMonkey.dll'. }
' 0:< API_SUCCESS { API registering command Communicator CanExecute event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Starting External Application: Communicator for Autodesk Revit, Class: Autodesk.Revit.SmartMonkeyPlugin.SmartMonkeyApplication, Vendor : ADSK(Autodesk,
www.autodesk.com), Assembly: Communicator\SmartMonkey.dll }
' 0:< API_SUCCESS { Registering Idling event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Registering ViewActivated event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Registering ViewActivating event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Registering DocumentClosing event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Registering DocumentClosed event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Registering DocumentOpened event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Replacing command id 'ID_VISUAL_PROGRAMMING_DYNAMO' CanExecute implementation with implementation from application 'Dynamo For Revit' dll 'C:\Program Files\Dynamo 0.9\Revit_2017\DynamoRevitVersionSelector.dll'. }
' 0:< API_SUCCESS { API registering command Launch Dynamo
'Dynamo CanExecute event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
'Dynamo BeforeExecuted event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Replacing command id 'ID_VISUAL_PROGRAMMING_DYNAMO' Executed implementation with implementation from application 'Dynamo For Revit' dll 'C:\Program Files\Dynamo 0.9\Revit_2017\DynamoRevitVersionSelector.dll'. }
'Dynamo Executed event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< Third Party Updater 'Dynamo For Revit: Sun and Shadow Settings Updater' registered for all documents.
' 0:< API_SUCCESS { Registering DocumentChanged event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Starting External Application: Dynamo For Revit, Class: Dynamo.Applications.VersionLoader, Vendor : ADSK(Dynamo), Assembly: C:\Program Files\Dynamo 0.9\Revit_2017\DynamoRevitVersionSelector.dll }
' 0:< API_SUCCESS { Replacing command id 'ID_VIEWS_FOR_A360' Executed implementation with implementation from application 'Views For A360' dll 'C:\ProgramData\Autodesk\Revit\Addins\2017\.\ExportViewSelectorAddin\ExportViewSelectorAddin.dll'. }
' 0:< API_SUCCESS { API registering command Views For A360 Executed event by application Views For A360 (78bd1446-1817-4842-8075-591b0424acaa). }
' 0:< API_SUCCESS { Replacing command id 'ID_VIEWS_FOR_A360' CanExecute implementation with implementation from application 'Views For A360' dll 'C:\ProgramData\Autodesk\Revit\Addins\2017\.\ExportViewSelectorAddin\ExportViewSelectorAddin.dll'. }
' 0:< API_SUCCESS { API registering command Views For A360 CanExecute event by application Views For A360 (78bd1446-1817-4842-8075-591b0424acaa). }
' 0:< API_SUCCESS { Starting External Application: Views For A360, Class: Autodesk.Revit.Addin.ExportViewSelector.ExportViewSelectorApp, Vendor : ADSK(Autodesk,
www.autodesk.com), Assembly: .\ExportViewSelectorAddin\ExportViewSelectorAddin.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6433, name: , text: Convert RFA
'to FormIt 360, class: RFAToAXMAddon.RFAToAXMCommand, assembly: C:\Program Files\Autodesk\FormIt 360 Converter For Revit 2017\FormIt360ConversionAddon\RFAToAXMAddon.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6434, name: , text: Convert SKP
'to FormIt 360, class: RFAToAXMAddon.SketchUpToAXMCommand, assembly: C:\Program Files\Autodesk\FormIt 360 Converter For Revit 2017\FormIt360ConversionAddon\RFAToAXMAddon.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6435, name: , text: Import FormIt 360
'to RVT, class: AXMImportorAddon.AXMImportorCommand, assembly: C:\Program Files\Autodesk\FormIt 360 Converter For Revit 2017\FormIt360ConversionAddon\AXMImportorAddon.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6436, name: , text: Reload Families, class: AXMImportorAddon.ReloadFamiliesCommand, assembly: C:\Program Files\Autodesk\FormIt 360 Converter For Revit 2017\FormIt360ConversionAddon\AXMImportorAddon.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6437, name: , text: About FormIt 360, class: FormItConverter.FormIt360Link, assembly: C:\Program Files\Autodesk\FormIt 360 Converter For Revit 2017\FormIt360ConversionAddon\FormItConverterRibbon.dll }
' 0:< API_SUCCESS { Starting External Application: FormIt Conversion, Class: FormItConverter.Ribbon, Vendor : ADSK(Autodesk,
www.autodesk.com), Assembly: C:\Program Files\Autodesk\FormIt 360 Converter For Revit 2017\FormIt360ConversionAddon\FormItConverterRibbon.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6438, name: , text: Import Autodesk Fabrication Job File, class: MEPFabricationOpenJob.ImportJobCommand, assembly: C:\Program Files\Autodesk\Fabrication 2017\Revit Extension for Fabrication\MEPFabricationOpenJob.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6439, name: , text: Export Autodesk Fabrication Job File, class: MEPFabricationOpenJob.ExportJobCommand, assembly: C:\Program Files\Autodesk\Fabrication 2017\Revit Extension for Fabrication\MEPFabricationOpenJob.dll }
' 0:< API_SUCCESS { Starting External Application: Revit Extension for Fabrication, Class: MEPFabricationOpenJob.Application, Vendor : ADSK(Autodesk,
www.autodesk.com), Assembly: C:\Program Files\Autodesk\Fabrication 2017\Revit Extension for Fabrication\MEPFabricationOpenJob.dll }
' 0:< API_SUCCESS { Registering DocumentCreated event by application Common (3a77a84e-3f0d-4f84-be7f-a7ecc7f3f708). }
' 0:< API_SUCCESS { Registering DocumentOpened event by application Common (3a77a84e-3f0d-4f84-be7f-a7ecc7f3f708). }
' 0:< API_SUCCESS { Registering DocumentSaving event by application Common (3a77a84e-3f0d-4f84-be7f-a7ecc7f3f708). }
' 0:< API_SUCCESS { Registering DocumentSavingAs event by application Common (3a77a84e-3f0d-4f84-be7f-a7ecc7f3f708). }
' 0:< API_SUCCESS { Registering DocumentSynchronizedWithCentral event by application Common (3a77a84e-3f0d-4f84-be7f-a7ecc7f3f708). }
' 0:< API_SUCCESS { Registering DocumentSynchronizingWithCentral event by application Common (3a77a84e-3f0d-4f84-be7f-a7ecc7f3f708). }
' 0:< API_SUCCESS { Registering DocumentClosing event by application Common (3a77a84e-3f0d-4f84-be7f-a7ecc7f3f708). }
' 0:< API_SUCCESS { Registering DocumentChanged event by application Common (3a77a84e-3f0d-4f84-be7f-a7ecc7f3f708). }
' 0:< API_SUCCESS { Registering DialogBoxShowing event by application Common (3a77a84e-3f0d-4f84-be7f-a7ecc7f3f708). }
' 0:< API_SUCCESS { Registering FileExporting event by application Common (3a77a84e-3f0d-4f84-be7f-a7ecc7f3f708). }
' 0:< API_SUCCESS { Registering FileExported event by application Common (3a77a84e-3f0d-4f84-be7f-a7ecc7f3f708). }
' 0:< API_SUCCESS { Registering ViewActivated event by application Common (3a77a84e-3f0d-4f84-be7f-a7ecc7f3f708). }
' 0:< Third Party Updater 'Common: RrxUpdater' registered for all documents.
' 0:< API_SUCCESS { Starting External Application: Common, Class: Adsk.RrxApplication.RrxCommonApp, Vendor : ADSK(Autodesk,
www.autodesk.com), Assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Roombook\Program\RrxCommon.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6440, name: , text: Calculate Room Quantities, class: Adsk.RrxApplication.RrxCalculationStyleCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Roombook\Program\RoomBookInternational.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6441, name: , text: Calculation Settings, class: Adsk.RrxApplication.RrxCalculationOptionsCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Roombook\Program\RoomBookInternational.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6442, name: , text: Apply Surface Materials to Rooms, class: Adsk.RrxApplication.RrxApplyMaterialStyleCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Roombook\Program\RoomBookInternational.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6443, name: , text: Edit Surface Materials, class: Adsk.RrxApplication.RrxMaterialStyleCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Roombook\Program\RoomBookInternational.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6444, name: , text: Hide/Show Quantity IDs, class: Adsk.RrxApplication.RrxCalculationToggleQIDCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Roombook\Program\RoomBookInternational.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6445, name: , text: Hide/Show Finish IDs, class: Adsk.RrxApplication.RrxCalculationToggleFinishSymCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Roombook\Program\RoomBookInternational.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6446, name: , text: Set language, class: Adsk.RrxApplication.RrxChangeUILanguageRBICmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Roombook\Program\RoomBookInternational.dll }
' 0:< API_SUCCESS { Starting External Application: RoomBook International, Class: Adsk.RrxApplication.RrxRoomBookInternationalApp, Vendor : ADSK(Autodesk,
www.autodesk.com), Assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Roombook\Program\RoomBookInternational.dll }
' 0:< API_SUCCESS { Registering DocumentClosed event by application External Tool (e0a2d7a5-030b-4d4e-8689-8406903ea241). }
' 0:< API_SUCCESS { Registering DocumentCreating event by application External Tool (e0a2d7a5-030b-4d4e-8689-8406903ea241). }
' 0:< API_SUCCESS { Registering DocumentClosing event by application External Tool (e0a2d7a5-030b-4d4e-8689-8406903ea241). }
' 0:< API_SUCCESS { Registering DocumentSaving event by application External Tool (e0a2d7a5-030b-4d4e-8689-8406903ea241). }
' 0:< API_SUCCESS { Registering DocumentSavingAs event by application External Tool (e0a2d7a5-030b-4d4e-8689-8406903ea241). }
' 0:< API_SUCCESS { Registering DocumentChanged event by application External Tool (e0a2d7a5-030b-4d4e-8689-8406903ea241). }
' 0:< API_SUCCESS { Registering ViewActivating event by application External Tool (e0a2d7a5-030b-4d4e-8689-8406903ea241). }
' 0:< API_SUCCESS { Registered an external server: Name(ModifyConnectionParametersServer); VendorId(ADSK); ServerId(d81402f0-e558-4434-89a8-30ec1f52a4d0); ServiceId(e9c0f948-320e-4e7f-a573-10755555305d) }
' 0:< API_SUCCESS { Registered an external server: Name(ConnectionTypeChangedServer); VendorId(ADSK); ServerId(43229eb0-f06b-49a9-b404-ff52ae5842ad); ServiceId(e31c3100-9cab-4303-b85b-4171703ce1c4) }
' 0:< API_SUCCESS { Starting External Application: External Tool, Class: RvtSteelConnectionsUI.SteelConnection, Vendor : Autodesk(Autodesk,
www.autodesk.com), Assembly: C:\Program Files\Autodesk\Steel Connections for Revit\RvtSteelConnectionsUI.dll }
' 0:< ::0:: Delta VM: Avail -12 -> 134216041 MB, Used +4 -> 290 MB; RAM: Avail -4 -> 62299 MB, Used +3 -> 427 MB
' 0:< GUI Resource Usage GDI: Avail 9816, Used 184, User: Used 249108103360
'C 13-Sep-2016 16:02:50.025; 0:< ->processShellCommand
'E 13-Sep-2016 16:02:50.026; 0:<
Jrn.Command "Internal" , "Show or hide recent files , ID_STARTUP_PAGE"
' 0:< ::1:: Delta VM: Avail -99 -> 134215943 MB, Used +10 -> 301 MB, Peak +2 -> 301 MB; RAM: Avail -11 -> 62289 MB, Used +11 -> 439 MB, Peak +7 -> 439 MB
' 0:< GUI Resource Usage GDI: Avail 9809, Used 191, User: Used 249108103370
'C 13-Sep-2016 16:02:50.233; 0:< <-processShellCommand
'C 13-Sep-2016 16:02:50.234; 0:< ->DesktopMFCApp::doStartupWarnings
'C 13-Sep-2016 16:02:50.234; 0:< License readyForUI
'C 13-Sep-2016 16:02:50.292; 0:< manage involvement
' 0:< ::1:: Delta VM: Avail -11 -> 134215932 MB, Used +1 -> 302 MB, Peak +1 -> 303 MB; RAM: Avail -4 -> 62286 MB, Used +3 -> 442 MB, Peak +3 -> 442 MB
' 0:< GUI Resource Usage GDI: Avail 9809, Used 191, User: Used 249108103369
'C 13-Sep-2016 16:02:50.386; 0:< manage debug modes
'C 13-Sep-2016 16:02:50.387; 0:< MFCApp::testGraphicsHardware
' 0:< Revit Graphics Information
' 0:< Current Mode : DirectX Hardware
' 0:< Use Hardware: ON
' 0:< Use Overlays : ON
' 0:< START CanUseHardware(forced)
' 1:<
'OGS Device Memory Size: 34704 MB
' 1:< ::1:: Delta VM: Avail -32889 -> 134183044 MB, Used +63 -> 366 MB, Peak +65 -> 368 MB; RAM: Avail -16 -> 62270 MB, Used +22 -> 465 MB, Peak +23 -> 466 MB
' 1:< GUI Resource Usage GDI: Avail 9808, Used 192, User: Used 249108103382
' 1:< DX Device: DirectX 11, Hardware
' 1:< DX Device: DirectX 11, WARP
'C 13-Sep-2016 16:02:50.720; 1:< START video card certification
' 1:<
'Current driver version: \Windows\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_90f801d8702dbf86\nvd3dumx,C:\Windows\System32\DriverStore\Fi:21.21.13.6926
'Certified driver(s): 9.18.13.3182
' 1:< VIDEO CARD ENVIRONMENT: CARD="NVIDIA Quadro K2000" ManufacturerID="10DE" DeviceID="0FFE" osID="8000" DRIVER="\Windows\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_90f801d8702dbf86\nvd3dumx,C:\Windows\System32\DriverStore\Fi:21.21.13.6926" DEVICE="DX11" FL_Caps="50" (Shader Model)
'C 13-Sep-2016 16:02:50.743; 1:< FINISH video card certification
' 0.357230 1:<<' 0:<
'Can use hardware=y
'Hardware support flags:
'FeatureLevelLow=n
'DrvOlderThanTested=y
'DrvNewerThanTested=n
'CardIsNotListed=n
'NotCertifiedEnv=n
'3GBSwitchIsOn=n
'SoftwareModeForced=n
' 0:< FINISH CanUseHardware(forced)
'C 13-Sep-2016 16:02:50.744; 0:< MFCApp::testMSAA
'C 13-Sep-2016 16:02:50.744; 0:< postConditionalWarnings
'C 13-Sep-2016 16:02:50.744; 0:< giveAtomRegistrationWarnings
'C 13-Sep-2016 16:02:50.744; 0:< warnings->consumeAll
'C 13-Sep-2016 16:02:50.745; 0:< Process result of DebugModes-Changed Task Dialog
'C 13-Sep-2016 16:02:50.745; 0:< isMaterialLibraryAvailable
'C 13-Sep-2016 16:02:50.745; 0:< start up warnings for AddIns
'C 13-Sep-2016 16:02:50.745; 0:< <-DesktopMFCApp::doStartupWarnings
' 0:< DBG_INFO: Resetting WPF rendering mode back to Revit default in Desktop Open Notification!: line 269 of RibbonAPI.cpp.
' 0:< Setting WPF rendering mode to SoftwareOnly
'C 13-Sep-2016 16:02:50.747; 0:< <-desktop InitNativeInstance
'C 13-Sep-2016 16:02:50.747; 0:< ->desktop InitManagedInstance
' 1:< ::1:: Delta VM: Avail -14 -> 134183031 MB, Used +3 -> 369 MB, Peak +3 -> 371 MB; RAM: Avail -18 -> 62253 MB, Used +10 -> 475 MB, Peak +10 -> 476 MB
' 1:< GUI Resource Usage GDI: Avail 9658, Used 342, User: Used 249108103383
' 1:< API_SUCCESS { Added pushbutton Id: 6447, name: , text: Modify, class: REX.AREXRevitMngr.Modifier, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Products\Revit\AREXRevitMngr.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6448, name: , text: Delete, class: REX.AREXRevitMngr.Remover, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Products\Revit\AREXRevitMngr.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6449, name: , text: Preferences, class: REX.AREXRevitMngr.Preferences, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Products\Revit\AREXRevitMngr.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6450, name: , text: Frame Generator, class: REX.DLTFrame3D.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Modeling\DLTFrame3D\DLTFrame3D.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6451, name: , text: Grids Generator, class: REX.DRevitGridGenerator.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Modeling\DRevitGridGenerator\DRevitGridGenerator.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6452, name: , text: Rafter Framing, class: REX.DRafterFraming.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Modeling\DRafterFraming\DRafterFraming.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6453, name: , text: Roof Trusses, class: REX.DRoofTrusses.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Modeling\DRoofTrusses\DRoofTrusses.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6454, name: , text: Wood Framing Walls, class: REX.ATimberFraming.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Modeling\ATimberFraming\ATimberFraming.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6455, name: , text: Automatic Reinforcement Generation, class: REX.DReinfAuto.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Reinforcement\DReinfAuto\DReinfAuto.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6456, name: , text: Beams, class: REX.DReinfBeam.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Reinforcement\DReinfBeam\DReinfBeam.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6457, name: , text: Columns, class: REX.DReinfColumn.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Reinforcement\DReinfColumn\DReinfColumn.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6458, name: , text: Continuous Footings, class: REX.DReinfFootingCont.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Reinforcement\DReinfFootingCont\DReinfFootingCont.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6459, name: , text: Interferences of Reinforcing Bars, class: REX.DReinfRebarCollisions.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Reinforcement\DReinfRebarCollisions\DReinfRebarCollisions.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6460, name: , text: Parapets, class: REX.DReinfParapet.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Reinforcement\DReinfParapet\DReinfParapet.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6461, name: , text: Pile Caps, class: REX.DReinfPileCap.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Reinforcement\DReinfPileCap\DReinfPileCap.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6462, name: , text: Piles, class: REX.DReinfPile.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Reinforcement\DReinfPile\DReinfPile.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6463, name: , text: Retaining Walls, class: REX.DReinfRetainingWall.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Reinforcement\DReinfRetainingWall\DReinfRetainingWall.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6464, name: , text: Slab Corners, class: REX.DReinfSlabCorner.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Reinforcement\DReinfSlabCorner\DReinfSlabCorner.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6465, name: , text: Slab Openings, class: REX.DReinfSlabOpening.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Reinforcement\DReinfSlabOpening\DReinfSlabOpening.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6466, name: , text: Spread Footings, class: REX.DReinfFootingSpread.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Reinforcement\DReinfFootingSpread\DReinfFootingSpread.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6467, name: , text: Wall Corners, class: REX.DReinfWallCorner.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Reinforcement\DReinfWallCorner\DReinfWallCorner.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6468, name: , text: Walls, class: REX.DReinfWall.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Reinforcement\DReinfWall\DReinfWall.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6469, name: , text: Compare Models, class: REX.DRevitModelsCompare.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Tools\DRevitModelsCompare\DRevitModelsCompare.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6470, name: , text: Element Positioning, class: REX.DElementsPositioning.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Tools\DElementsPositioning\DElementsPositioning.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6471, name: , text: Bridge - Concrete box girder, class: REX.DBridgesBoxGirder.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Bridges\DBridgesBoxGirder\DBridgesBoxGirder.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6472, name: , text: Bridge - Concrete slab, class: REX.DBridgesConcreteSlab.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Bridges\DBridgesConcreteSlab\DBridgesConcreteSlab.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6473, name: , text: Bridge - Concrete slab with girders, class: REX.DBridgesBeamsGirder.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Bridges\DBridgesBeamsGirder\DBridgesBeamsGirder.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6474, name: , text: Customization of bridge families, class: REX.DBridgesXml.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Bridges\DBridgesXml\DBridgesXml.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6475, name: , text: Documentation, class: REX.DBridgesDocumentation.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Bridges\DBridgesDocumentation\DBridgesDocumentation.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6476, name: , text: Export Revit Elements to AutoCAD Civil 3D, class: REX.DBridge.ExportSolids.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Bridges\DBridge.ExportSolids\DBridge.ExportSolids.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6477, name: , text: Integration with AutoCAD Civil3D, class: REX.DBridgeCivil3DConnector.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Bridges\DBridgeCivil3DConnector\DBridgeCivil3DConnectorx64.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6478, name: , text: Roads and Terrain, class: REX.DBridgeRoad.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Bridges\DBridgeRoad\DBridgeRoad.dll }
' 1:< ::1:: Delta VM: Avail -12 -> 134183019 MB, Used +1 -> 370 MB; RAM: Avail -4 -> 62250 MB, Used +2 -> 478 MB, Peak +1 -> 478 MB
' 1:< GUI Resource Usage GDI: Avail 9650, Used 350, User: Used 249108103383
' 1:< Third Party Updater 'AREXRevitStart: REXExtension: DReinfBeam' registered for all documents.
' 1:< Third Party Updater 'AREXRevitStart: REXExtension: DReinfColumn' registered for all documents.
' 1:< Third Party Updater 'AREXRevitStart: REXExtension: DReinfFootingSpread' registered for all documents.
' 1:< Third Party Updater 'AREXRevitStart: REXExtension: DReinfWall' registered for all documents.
' 1:< API_SUCCESS { Registering DocumentOpened event by application AREXRevitStart (c0566ed7-4309-4082-b3ba-ea6b7b4d292a). }
' 1:< API_SUCCESS { Registering DocumentCreated event by application AREXRevitStart (c0566ed7-4309-4082-b3ba-ea6b7b4d292a). }
' 1:< API_SUCCESS { Registering DisplayingOptionsDialog event by application AREXRevitStart (c0566ed7-4309-4082-b3ba-ea6b7b4d292a). }
' 1:< API_SUCCESS { Registering ViewActivated event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 1:< API_SUCCESS { Registering DocumentSynchronizingWithCentral event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 1:< API_SUCCESS { Registering DocumentSynchronizedWithCentral event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
'C 13-Sep-2016 16:02:53.521; 0:< <-desktop InitManagedInstance
' 0:< ::1:: Delta VM: Avail -56 -> 134182964 MB, Used +8 -> 379 MB, Peak +8 -> 380 MB; RAM: Avail -33 -> 62217 MB, Used +22 -> 501 MB, Peak +23 -> 502 MB
' 0:< GUI Resource Usage GDI: Avail 9623, Used 377, User: Used 249108103388
'C 13-Sep-2016 16:02:53.824; 0:< appPriv idle
' 0:< OPERATING SYSTEM INFORMATION:
' 0:< BuildNumber : 14393
' 0:< BuildType : Multiprocessor Free
' 0:< Caption : Microsoft Windows 10 Pro
' 0:< CodeSet : 1252
' 0:< CountryCode : 1
' 0:< FreePhysicalMemory : 63706804
' 0:< FreeSpaceInPagingFiles : 9961472
' 0:< FreeVirtualMemory : 73081704
' 0:< MaxProcessMemorySize : 137438953344
' 0:< OSLanguage : 1033
' 0:< OSType : 18
' 0:< ServicePackMajorVersion : 0
' 0:< ServicePackMinorVersion : 0
' 0:< TotalVirtualMemorySize : 76904144
' 0:< TotalVisibleMemorySize : 66942672
' 0:< Version : 10.0.14393
' 0:< Process affinity mask : FFF
' 0:< System affinity mask : FFF
' 0:< PROCESSOR INFORMATION:
' 0:< AddressWidth : 64
' 0:< Architecture : 9
' 0:< Availability : 3
' 0:< Caption : Intel64 Family 6 Model 79 Stepping 1
' 0:< CurrentClockSpeed : 3401
' 0:< DataWidth : 64
' 0:< Description : Intel64 Family 6 Model 79 Stepping 1
' 0:< Family : 179
' 0:< L2CacheSize : 1536
' 0:< Level : 6
' 0:< Manufacturer : GenuineIntel
' 0:< MaxClockSpeed : 3401
' 0:< Name : Intel(R) Core(TM) i7-6800K CPU @ 3.40GHz
' 0:< ProcessorType : 3
' 0:< Revision : 20225
' 0:< Role : CPU
' 0:< SocketDesignation : SOCKET 0
' 0:< StatusInfo : 3
' 0:< Version :
' 0:< VIDEO CONTROLLER INFORMATION:
' 0:< AdapterCompatibility : NVIDIA
' 0:< AdapterDACType : Integrated RAMDAC
' 0:< AdapterRAM : -2147483648
' 0:< Caption : NVIDIA Quadro K2000
' 0:< CurrentBitsPerPixel : 32
' 0:< CurrentHorizontalResolution : 1280
' 0:< CurrentNumberOfColors : 4294967296
' 0:< CurrentRefreshRate : 60
' 0:< CurrentVerticalResolution : 1024
' 0:< Description : NVIDIA Quadro K2000
' 0:< DriverDate : 20160830000000.000000-000
' 0:< DriverVersion : 21.21.13.6926
' 0:< MaxRefreshRate : 75
' 0:< MinRefreshRate : 56
' 0:< Monochrome : 0
' 0:< Name : NVIDIA Quadro K2000
' 0:< VideoArchitecture : 5
' 0:< VideoMemoryType : 2
' 0:< VideoModeDescription : 1280 x 1024 x 4294967296 colors
' 0:< VideoProcessor : Quadro K2000
' 0:< ::1:: Delta VM: Avail -6 -> 134182959 MB, Used +1 -> 380 MB, Peak +1 -> 381 MB; RAM: Avail -11 -> 62207 MB, Used +4 -> 505 MB, Peak +3 -> 505 MB
' 0:< GUI Resource Usage GDI: Avail 9614, Used 386, User: Used 249108103396
' 0:< PRINTER INFORMATION:
' 0:< Caption : Send To OneNote 2016
' 0:< Default : 0
' 0:< DeviceID : Send To OneNote 2016
' 0:< Direct : 0
' 0:< DriverName : Send to Microsoft OneNote 16 Driver
' 0:< EnableBIDI : 0
' 0:< EnableDevQueryPrint : 0
' 0:< HorizontalResolution : 600
' 0:< Local : -1
' 0:< Name : Send To OneNote 2016
' 0:< Network : 0
' 0:< PortName : nul:
' 0:< PrintJobDataType : RAW
' 0:< PrintProcessor : winprint
' 0:< RawOnly : 0
' 0:< Shared : 0
' 0:< SpoolEnabled : -1
' 0:< VerticalResolution : 600
' 0:< Caption : PDFCreator
' 0:< Default : -1
' 0:< DeviceID : PDFCreator
' 0:< Direct : 0
' 0:< DriverName : PDFCreator
' 0:< Local : -1
' 0:< Name : PDFCreator
' 0:< Network : 0
' 0:< PortName : pdfcmon
' 0:< RawOnly : 0
' 0:< Shared : 0
' 0:< Caption : Microsoft XPS Document Writer
' 0:< Default : 0
' 0:< DeviceID : Microsoft XPS Document Writer
' 0:< Direct : 0
' 0:< DriverName : Microsoft XPS Document Writer v4
' 0:< Local : -1
' 0:< Name : Microsoft XPS Document Writer
' 0:< Network : 0
' 0:< PortName : PORTPROMPT:
' 0:< RawOnly : 0
' 0:< Shared : 0
' 0:< Caption : Microsoft Print to PDF
' 0:< Default : 0
' 0:< DeviceID : Microsoft Print to PDF
' 0:< Direct : 0
' 0:< DriverName : Microsoft Print To PDF
' 0:< Local : -1
' 0:< Name : Microsoft Print to PDF
' 0:< Network : 0
' 0:< RawOnly : 0
' 0:< Shared : 0
' 0:< Caption : Fax
' 0:< Default : 0
' 0:< DeviceID : Fax
' 0:< Direct : 0
' 0:< DriverName : Microsoft Shared Fax Driver
' 0:< HorizontalResolution : 200
' 0:< Local : -1
' 0:< Name : Fax
' 0:< Network : 0
' 0:< PortName : SHRFAX:
' 0:< RawOnly : 0
' 0:< Shared : 0
' 0:< VerticalResolution : 200
' 0:< PRINTER CONFIGURATION INFORMATION:
' 0:< Color : 2
' 0:< Copies : 1
' 0:< Description : Send To OneNote 2016
' 0:< DriverVersion : 1539
' 0:< Orientation : 1
' 0:< PaperLength : 2794
' 0:< PaperSize : Letter 8 1/2 x 11 in
' 0:< PaperWidth : 2159
' 0:< PrintQuality : 600
' 0:< SpecificationVersion : 1025
' 0:< XResolution : 600
' 0:< YResolution : 600
' 0:< Color : 2
' 0:< Copies : 1
' 0:< Description : PDFCreator
' 0:< Color : 2
' 0:< Copies : 1
' 0:< Description : Microsoft XPS Document Writer
' 0:< Color : 2
' 0:< Copies : 1
' 0:< Description : Microsoft Print to PDF
' 0:< Color : 1
' 0:< Description : Fax
' 0:< DriverVersion : 1024
' 0:< Duplex : 0
' 0:< PrintQuality : 200
' 0:< XResolution : 200
' 0:< YResolution : 200
' 0:< ::1:: Delta VM: Avail +7 -> 134182967 MB, Used -4 -> 376 MB, Peak +0 -> 382 MB; RAM: Avail -13 -> 62195 MB, Used +1 -> 507 MB, Peak +2 -> 508 MB
' 0:< GUI Resource Usage GDI: Avail 9619, Used 381, User: Used 249108103397
'E 13-Sep-2016 16:03:06.795; 0:<
Jrn.AppButtonEvent 1 , "Application Menu is opening"
'E 13-Sep-2016 16:03:08.284; 0:<
Jrn.AppButtonEvent 0 , "Application Menu is closing"
'E 13-Sep-2016 16:03:08.317; 0:<
Jrn.Command "Ribbon" , "Quit the application; prompts to save projects , ID_APP_EXIT"
' 1:< ::4:: Delta VM: Avail +43 -> 134183011 MB, Used -6 -> 371 MB; RAM: Avail +118 -> 62313 MB, Used -8 -> 499 MB, Peak +2 -> 511 MB
' 1:< GUI Resource Usage GDI: Avail 9683, Used 317, User: Used 249108103300
' 1:< Revit worker 1 closed cleanly
' 0:< [00001aa8]QueueMinder stopped
'C 13-Sep-2016 16:03:08.774; 1:< logging finished virtualization services
'C 13-Sep-2016 16:03:08.774; 1:< logging finished worker services
'C 13-Sep-2016 16:03:08.774; 1:< logging erased queues
' 0.296081 1:<<
'C 13-Sep-2016 16:03:08.774; 0:< ->desktop ExitManagedInstance
'C 13-Sep-2016 16:03:08.797; 0:< <-desktop ExitManagedInstance
'C 13-Sep-2016 16:03:08.797; 0:< ->desktop ExitNativeInstance
' 0:< API_SUCCESS { Unregistering ViewActivated event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Unregistering DocumentClosing event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Unregistering DocumentClosed event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Unregistering DocumentChanged event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Unregistering DockableFrameVisibilityChanged event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Unregistering Idling event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Registering FabricationPartBrowserChanged event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Restoring command id 'ID_MEP_FABRICATION_SETTINGS' CanExecute implementation. }
' 0:< API_SUCCESS { API unregistering command Fabrication Settings CanExecute event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Restoring command id 'ID_MEP_FABRICATION_SETTINGS' Executed implementation. }
' 0:< API_SUCCESS { API unregistering command Fabrication Settings Executed event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Restoring command id 'ID_FABRICATION_PART_SHOW_SERVICE_IN_PART_BROWSER' CanExecute implementation. }
' 0:< API_SUCCESS { API unregistering command Show Service in Part Browser
'Show Service in Part Browser
'Show Service in Part Browser CanExecute event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Restoring command id 'ID_EXPORT_IFC' Executed implementation. }
' 0:< API_SUCCESS { API unregistering command Export to IAI IFC (Industry Foundation Classes) file format Executed event by application IFC override (e78da2e3-7e89-464c-97cd-2212c8be3fa8). }
' 0:< Third Party Updater 'Common: DrxUpdater' has been unregistered.
' 0:< API_SUCCESS { Unregistering ViewActivated event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Unregistering ApplicationClosing event by application Ribbon (c82755fa-ff61-5113-9a07-27b2127a13e5). }
' 0:< Third Party Updater 'Common: BrxUpdater' has been unregistered.
' 0:< API_SUCCESS { Restoring command id 'ID_TEAM' Executed implementation. }
' 0:< API_SUCCESS { API unregistering command Communicator Executed event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Restoring command id 'ID_TEAM' CanExecute implementation. }
' 0:< API_SUCCESS { API unregistering command Communicator CanExecute event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Unregistering DocumentOpened event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Unregistering DocumentCreated event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Unregistering DocumentSavedAs event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Unregistering DocumentSaved event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Unregistering ApplicationClosing event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Unregistering DocumentSynchronizingWithCentral event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Unregistering DocumentSynchronizedWithCentral event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< Third Party Updater 'Common: RrxUpdater' has been unregistered.
' 0:< API_SUCCESS { Unregistering DocumentClosed event by application External Tool (e0a2d7a5-030b-4d4e-8689-8406903ea241). }
' 0:< API_SUCCESS { Unregistering DocumentCreating event by application External Tool (e0a2d7a5-030b-4d4e-8689-8406903ea241). }
' 0:< API_SUCCESS { Unregistering DocumentClosing event by application External Tool (e0a2d7a5-030b-4d4e-8689-8406903ea241). }
' 0:< API_SUCCESS { Unregistering DocumentSaving event by application External Tool (e0a2d7a5-030b-4d4e-8689-8406903ea241). }
' 0:< API_SUCCESS { Unregistering DocumentSavingAs event by application External Tool (e0a2d7a5-030b-4d4e-8689-8406903ea241). }
' 0:< API_SUCCESS { Unregistering DocumentChanged event by application External Tool (e0a2d7a5-030b-4d4e-8689-8406903ea241). }
' 0:< API_SUCCESS { Unregistering ViewActivating event by application External Tool (e0a2d7a5-030b-4d4e-8689-8406903ea241). }
' 0:< API_SUCCESS { Unregistering DocumentSavedAs event by application CollaborateDB (bb3086be-63bb-44bd-99eb-d584c013cf2f). }
' 0:< API_SUCCESS { Unregistering DocumentOpened event by application CollaborateDB (bb3086be-63bb-44bd-99eb-d584c013cf2f). }
' 0:< API_SUCCESS { Unregistering DocumentClosing event by application CollaborateDB (bb3086be-63bb-44bd-99eb-d584c013cf2f). }
' 0:< Forcibly unregistering Updater with id:51c0be9b-07a8-443a-be8c-21db815b17e7
' 0:< Forcibly unregistering Updater with id:00000000-c00c-478e-9226-63d19d957aed
' 0:< Forcibly unregistering Updater with id:00000000-9a62-4ecd-adb1-9a93bf539620
' 0:< Forcibly unregistering Updater with id:00000000-7174-4309-88a1-27d09090ef6d
' 0:< Forcibly unregistering Updater with id:00000000-0a7a-49e7-bd08-6696111b3b53
' 0:< Forcibly unregistering Updater with id:649e613c-2d39-4a7b-9720-662750f5243e
' 0:< Forcibly removing all update triggers for all Updaters
' 0:< Unregistering all external services.
' 0:< ::4:: Delta VM: Avail +68 -> 134183080 MB, Used -58 -> 313 MB; RAM: Avail +2 -> 62316 MB, Used -4 -> 496 MB
' 0:< GUI Resource Usage GDI: Avail 9689, Used 311, User: Used 249108103290
' 0:< Exception occurred
'C 13-Sep-2016 16:03:09.099; 0:< ExceptionCode=0xc0000005 ExceptionFlags=0x00000000 ExceptionAddress=00007FFF8357A0A0
' 0:< System (MB) [Available / Total ] [Revit Memory Usage (MB) ]
' 0:< RAM Statistics: 62316 / 65373 496=InUse 511=Peak
' 0:< VM Statistics: 134183081 / 134217727 313=InUse 382=Peak
' 0:< Unconverted MessageBox "An unrecoverable error has occurred. The program will now be terminated. All of your data has been recently saved, so there is no need to create recovery files."
' 0:< ::4:: Delta VM: Avail -26 -> 134183054 MB, Used 313 MB; RAM: Avail -7 -> 62309 MB, Used 496 MB
' 0:< GUI Resource Usage GDI: Avail 9686, Used 314, User: Used 249108103283
'H 13-Sep-2016 16:03:10.342; 0:<
Jrn.Data "MessageBox" _
, "IDOK", "An unrecoverable error has occurred. The program will now be terminated. All of your data has been recently saved, so there is no need to create recovery files."
'C 13-Sep-2016 16:03:10.342; 0:< program terminated:initialize>
