template
template
template
I recently downloaded the revit 2017 and it set as metric system. When I want to create new template to choose US imperial system..there are only choices of generic or japanese file. How can I erace Japanese and install US imperial?
RDAOU
1.Type c:\programDATA\Autodesk\ and look for the folder RVT 2017 (check if imperial library contents are installed. If it is, set the proper path in Revit options
2. You can download the US Imperial content library (go to windows control panel >> programs and features and run the related CL for ur version then add the contents u need
3. Make ur own template with the project units you desire
How can I add the imperial system?
I have all japanese content library which I've never chosen. I don't have
imperial library. How can I fix everything?
ennujozlagam
@Anonymous  hello, you can check it HERE. thanks
i have revit architecture 2014 but when this app start template file shows none due to which architectural work can't be done....software does'nt work as it should be.... so please help me that how to open architecture template.......
RDAOU
@Anonymous did u manage to sort out the problem you are having with template ?
@Anonymous did you try any of the suggestions given above and still did not manage to locate and/or download the templates
