Revit 2017, after closing revit, An unrecoverable error has occurred.
Message 1 of 12
An unrecoverable error has occurred. The program will now be terminated. All of your data has been recently saved, so there is no need to create recovery files.
Replies (11)
Message 2 of 12
Revit_Whisperer
Message 3 of 12
Thank you for the links. I tried updating the add-ons and creating a new
user folder as mentioned in the articles, but I am still receiving the
error message. What would be the next step? Thanks
Message 4 of 12
Revit_Whisperer
I think I need some additional information
  • Is this happening on a specific file, or any file?
  • Is it happening when you open, close, change views etc.
  • If you log into your machine as a different user does this still occur?
  • Is Revit on the most current update?
Please provide your journal from a time when this error occurred.
Revit Journal Files location
C:\Users\UserName\AppData\Local\Autodesk\Revit\Autodesk Revit 201#\Journals
Message 5 of 12
' 0:< Initial VM: Avail 134217444 MB, Used 13 MB, Peak 13; RAM: Avail 63225 MB, Used 48 MB, Peak 13
' 0:< GUI Resource Usage GDI: Avail 9995, Used 5, User: Used 3
'C 13-Sep-2016 16:02:32.515; 0:< started recording journal file
' Build: 20160720_1515(x64)
' Branch: RELEASE_2017_RTM
Dim Jrn
Set Jrn = CrsJournalScript
'C 13-Sep-2016 16:02:32.530; 0:< ->desktop InitApplication
'C 13-Sep-2016 16:02:32.531; 0:< <-desktop InitApplication
'C 13-Sep-2016 16:02:32.531; 0:< ->desktop InitNativeInstance
' 0:< Options::loadOptions: m_strDataLibraryLocations=Imperial Library=C:\ProgramData\Autodesk\RVT 2017\Libraries\US Imperial\,Imperial Detail Library=C:\ProgramData\Autodesk\RVT 2017\Libraries\US Imperial\Detail Items, Roombook Library=C:\ProgramData\Autodesk\RVT 2017\Libraries\US Imperial\Roombook Library, Areabook Library=C:\ProgramData\Autodesk\RVT 2017\Libraries\US Imperial\Areabook Library, Buildingbook Library=C:\ProgramData\Autodesk\RVT 2017\Libraries\US Imperial\Buildingbook Library (defaultLib==\Library)
' 0:< ::0:: Delta VM: Avail -24 -> 134217420 MB, Used +4 -> 18 MB, Peak +4 -> 18 MB; RAM: Avail -59 -> 63167 MB, Used +11 -> 60 MB, Peak +11 -> 60 MB
' 0:< GUI Resource Usage GDI: Avail 9980, Used 20, User: Used 249108103196
'C 13-Sep-2016 16:02:33.641; 0:< License initialization complete
' 0:< License version: 17.3.26.0
' 0:< ::0:: Delta VM: Avail -173 -> 134217247 MB, Used +31 -> 49 MB, Peak +33 -> 52 MB; RAM: Avail -85 -> 63082 MB, Used +49 -> 109 MB, Peak +49 -> 109 MB
' 0:< GUI Resource Usage GDI: Avail 9980, Used 20, User: Used 249108103220
' 0:< SystemSettings:
' 0:< 12=multiCoreCharacteristic
' 0:< true=isDotNetInstalled
' 0:< 4.6.01586(394802)=dotNetInstalledVersionString
' 0:< false=isProcessUserModeExceptionPolicyDisabledForCallbackFilter
' 0:< ::0:: Delta VM: Avail -18 -> 134217230 MB, Used +8 -> 58 MB, Peak +5 -> 58 MB; RAM: Avail -15 -> 63068 MB, Used +15 -> 124 MB, Peak +15 -> 124 MB
' 0:< GUI Resource Usage GDI: Avail 9973, Used 27, User: Used 249108103233
'C 13-Sep-2016 16:02:34.299; 0:< manage licensing
' 0:< ::0:: Delta VM: Avail -51 -> 134217180 MB, Used +5 -> 63 MB, Peak +12 -> 70 MB; RAM: Avail -151 -> 62917 MB, Used +14 -> 139 MB, Peak +19 -> 143 MB
' 0:< GUI Resource Usage GDI: Avail 9973, Used 27, User: Used 249108103237
' 0:< License mode: Standalone
' 0:< Type: Standalone - Locked
' 0:< Usage: Commercial
' 0:< Behavior: Extendable
' 0:< Expiration: Saturday, October 07, 2017
' 0:< ::0:: Delta VM: Avail -568 -> 134216613 MB, Used +35 -> 99 MB, Peak +29 -> 99 MB; RAM: Avail -44 -> 62874 MB, Used +35 -> 174 MB, Peak +30 -> 174 MB
' 0:< GUI Resource Usage GDI: Avail 9940, Used 60, User: Used 249108103250
' 0:< Setting WPF rendering mode to SoftwareOnly
' 0:< ::0:: Delta VM: Avail -156 -> 134216457 MB, Used +69 -> 169 MB, Peak +69 -> 169 MB; RAM: Avail -256 -> 62619 MB, Used +93 -> 267 MB, Peak +92 -> 267 MB
' 0:< GUI Resource Usage GDI: Avail 9838, Used 162, User: Used 249108103345
' 0:< Autodesk Revit 2017
' 0:< 64-bit load point = C:\Program Files\Autodesk\Revit 2017
' 0:< this journal = C:\Users\tople\AppData\Local\Autodesk\Revit\Autodesk Revit 2017\Journals\journal.0021.txt
' 0:< ::0:: Delta VM: Avail -9 -> 134216448 MB, Used +1 -> 170 MB, Peak +1 -> 170 MB; RAM: Avail -16 -> 62604 MB, Used +4 -> 271 MB, Peak +4 -> 271 MB
' 0:< Journal Init
'C 13-Sep-2016 16:02:40.969; 0:< Log Summary
' 0:< .Count
' 0:< ...PendingMessages = 48
' 0:< .Marshalling
' 0:< ...CompactCaching = 1 (Enabled)
' 0:< .ThreadPool
' 0:< ...ActivePoolSize = 26
' 0:< ...ConfiguredPoolSize = automatic
' 0:< ...ParallelCores = 12
' 0:< ...RequestedPoolSize = automatic
' 0:< .Tuning
' 0:< ...ElemTable = 1 (Serial except when multithreaded)
'H 13-Sep-2016 16:02:40.969; 0:<
Jrn.Data "JournalDefaultTemplate" _
, "Construction Template=$AllUsersAppData\Templates\US Imperial\Construction-Default.rte, Architectural Template=$AllUsersAppData\Templates\US Imperial\default.rte, Structural Template=$AllUsersAppData\Templates\US Imperial\Structural Analysis-Default.rte, Mechanical Template=$AllUsersAppData\Templates\US Imperial\Mechanical-Default.rte"
'H 13-Sep-2016 16:02:40.970; 0:<
Jrn.Data "JournalDefaultViewDiscipline" _
, "Coordination"
Jrn.Directive "Version" _
, "2017.000", "2.153"
Jrn.Directive "Username" _
, "tople@mc-atl.com"
Jrn.Directive "CategoryDisciplineFilter" _
, -1
Jrn.Directive "DisciplineOption" _
, 7677
'H 13-Sep-2016 16:02:40.971; 0:<
Jrn.Directive "TabDisplayOptions" _
, "StayOnModifyInProject", 0
, "StayOnModifyInFamily", 1
, "ActiveCtOnSelection", 1
Jrn.Directive "AllowLinkSelection" _
, 1
Jrn.Directive "AllowFaceSelection" _
, 0
Jrn.Directive "AllowUnderlaySelection" _
, 0
Jrn.Directive "AllowPinnedSelection" _
, 1
Jrn.Directive "ThinLinesEnabled" _
, 0
'C 13-Sep-2016 16:02:40.981; 1:< logging master created MasterQueue Session6132_P0MasterQueue
'C 13-Sep-2016 16:02:40.982; 1:< logging started queue minder
'C 13-Sep-2016 16:02:40.982; 1:< logging started worker services
' 0:< ::0:: Delta VM: Avail -18 -> 134216431 MB, Used +0 -> 171 MB, Peak +1 -> 172 MB; RAM: Avail -14 -> 62590 MB, Used +1 -> 273 MB, Peak +5 -> 277 MB
' 0:< GUI Resource Usage GDI: Avail 9835, Used 165, User: Used 249108103344
' 0:< API_SUCCESS { Registered an external service: Name(NavisWorks Draw Service); VendorId(ADSK); ServiceId(e454a471-b9f3-4cb7-96b1-bab4cf7742a6) }
' 0:< API_SUCCESS { Registered an external service: Name(External Resource Service); VendorId(ADSK); ServiceId(b3892e5f-9161-4bbc-958a-c8ef75e94e96) }
' 0:< API_SUCCESS { Registered an external service: Name(NavisworksExportService); VendorId(ADSK); ServiceId(a9bdf0fd-2632-429e-bc35-50ebc2b824d2) }
' 0:< API_SUCCESS { Registered an external service: Name(Code Checking Parameter Service); VendorId(ADSK); ServiceId(de6db8de-dea6-40bd-9503-4ffe62ff6143) }
' 0:< API_SUCCESS { Registered an external service: Name(FramingProfileService); VendorId(ADSK); ServiceId(b2f816c0-6493-4537-8067-78a4e67f559e) }
' 0:< API_SUCCESS { Registered an external service: Name(Modify Connection Parameters Service); VendorId(ADSK); ServiceId(e9c0f948-320e-4e7f-a573-10755555305d) }
' 0:< API_SUCCESS { Registered an external service: Name(Connection Type Changed Service); VendorId(ADSK); ServiceId(e31c3100-9cab-4303-b85b-4171703ce1c4) }
' 0:< API_SUCCESS { Registered an external service: Name(SteelConnectionsService); VendorId(ADSK); ServiceId(282385f9-9627-4057-8b74-826d019f103c) }
' 0:< API_SUCCESS { Registered an external service: Name(Section Type Parameter Service); VendorId(ADSK); ServiceId(c42c9b55-c491-4611-97e9-9e617958e13e) }
' 0:< API_SUCCESS { Registered an external service: Name(Internal Forces Service); VendorId(ADSK); ServiceId(a97444aa-af8d-4a1e-af1f-fa7b77b368ee) }
' 0:< API_SUCCESS { Registered an external service: Name(IFC Export Service); VendorId(ADSK); ServiceId(d8b95737-f943-414c-9ad7-86785bf1acbc) }
' 0:< API_SUCCESS { Registered an external server: Name(Revit IFC Exporter); VendorId(ADSK); ServerId(ef8d0493-7f36-42b5-b9aa-8aaac716482b); ServiceId(d8b95737-f943-414c-9ad7-86785bf1acbc) }
' 0:< API_SUCCESS { Registered an external service: Name(IFC Import Service); VendorId(ADSK); ServiceId(98d317e2-e943-4cc0-a3da-2edf32a5d942) }
' 0:< API_SUCCESS { Registered an external server: Name(Revit IFC Importer); VendorId(ADSK); ServerId(660a7370-f6d6-43c8-8456-6b2eea785110); ServiceId(98d317e2-e943-4cc0-a3da-2edf32a5d942) }
' 0:< API_SUCCESS { Registered an external service: Name(Duct Fitting/Accessory Pressure Drop Calculator); VendorId(ADSK); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external service: Name(Pipe Fitting/Accessory Pressure Drop Calculator); VendorId(ADSK); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Registered an external service: Name(Duct Pressure Drop Calculator); VendorId(ADSK); ServiceId(8c707bd6-ecd6-4150-a0df-bd6c85dd9bb0) }
' 0:< API_SUCCESS { Registered an external service: Name(Pipe Pressure Drop Calculator); VendorId(ADSK); ServiceId(62d13e0c-9fe1-4d8e-a0c7-1f93d24cf3f3) }
' 0:< API_SUCCESS { Registered an external service: Name(Plumbing Flow Calculator); VendorId(ADSK); ServiceId(bf0da776-5307-4747-8285-f358e92a90d0) }
' 0:< API_SUCCESS { Registered an external service: Name(External Resource UI Service); VendorId(ADSK); ServiceId(1fe75ba7-79d4-45f6-8e31-c1b83d4476a9) }
' 0:< API_SUCCESS { Registered an external service: Name(Point Cloud Snapping Service); VendorId(ADSK); ServiceId(aaa05780-790c-43dc-bc41-1c2150227f45) }
' 0:< API_SUCCESS { Registered an external service: Name(Duct fitting and accessory pressure drop UI service); VendorId(ADSK); ServiceId(52009bda-c817-4aef-aa31-36dc3742516e) }
' 0:< API_SUCCESS { Registered an external service: Name(Pipe fitting and accessory pressure drop UI service); VendorId(ADSK); ServiceId(1931b323-1d29-4083-b1ce-bfdcddd011af) }
' 0:< ::0:: Delta VM: Avail -40 -> 134216392 MB, Used +18 -> 189 MB, Peak +17 -> 189 MB; RAM: Avail -109 -> 62482 MB, Used +14 -> 287 MB, Peak +9 -> 287 MB
' 0:< GUI Resource Usage GDI: Avail 9835, Used 165, User: Used 249108103346
' 0.168375 1:<<:initialize>
' 0:< ::0:: Delta VM: Avail -223 -> 134216169 MB, Used +68 -> 257 MB, Peak +68 -> 258 MB; RAM: Avail -145 -> 62337 MB, Used +90 -> 378 MB, Peak +90 -> 378 MB
' 0:< To make IFC server work.
' 0:< API_SUCCESS { Registered an external server: Name(Revit Default DB Server); VendorId(ADSK); ServerId(bd4f0f53-394a-4468-b37e-1e7949013382); ServiceId(b3892e5f-9161-4bbc-958a-c8ef75e94e96) }
' 0:< API_SUCCESS { Starting External DB Application: KeynoteDBServer, Class: KeynoteDBServer.ServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit 2017\AddIns\Keynote\KeynoteDBServer.dll }
' 0:< API_SUCCESS { Registered an external server: Name(Plumbing Fixture Flow); VendorId(ADSK); ServerId(56121d7d-e1d7-42a3-bed8-f4d1d32058c8); ServiceId(bf0da776-5307-4747-8285-f358e92a90d0) }
' 0:< API_SUCCESS { Registered an external server: Name(Simplified Colebrook Equation); VendorId(ADSK); ServerId(ea275fb1-5d7b-47d6-b828-bf856df9bfd5); ServiceId(62d13e0c-9fe1-4d8e-a0c7-1f93d24cf3f3) }
' 0:< API_SUCCESS { Registered an external server: Name(Altshul-Tsal Equation); VendorId(ADSK); ServerId(042a10e0-8d24-46a4-9596-d192b3125d0c); ServiceId(8c707bd6-ecd6-4150-a0df-bd6c85dd9bb0) }
' 0:< API_SUCCESS { Registered an external server: Name(Haaland Equation); VendorId(USERADDIN); ServerId(2e9a77c0-62a0-4693-9442-33312be60ad7); ServiceId(8c707bd6-ecd6-4150-a0df-bd6c85dd9bb0) }
' 0:< API_SUCCESS { Registered an external server: Name(Haaland Equation); VendorId(USERADDIN); ServerId(58ea1b7c-2fca-453f-9ab9-7a3b9927ecc1); ServiceId(62d13e0c-9fe1-4d8e-a0c7-1f93d24cf3f3) }
' 0:< API_SUCCESS { Registered an external server: Name(Colebrook Equation); VendorId(USERADDIN); ServerId(e395a0ec-48a4-4255-b957-afbb3d73cb67); ServiceId(8c707bd6-ecd6-4150-a0df-bd6c85dd9bb0) }
' 0:< API_SUCCESS { Registered an external server: Name(Colebrook Equation); VendorId(USERADDIN); ServerId(0875f550-6141-4e34-a6b7-547cf9cfda01); ServiceId(62d13e0c-9fe1-4d8e-a0c7-1f93d24cf3f3) }
' 0:< API_SUCCESS { Starting External DB Application: StraightSegmentCalculationServersApp, Class: StraightSegmentCalculationServers.ServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit 2017\AddIns\MEPCalculation\StraightSegmentCalculationServers.dll }
' 0:< API_SUCCESS { Registered an external server: Name(Not Defined); VendorId(ADSK); ServerId(76eff5da-2e71-45f7-b940-cc5716328ba0); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external server: Name(Coefficient from ASHRAE Table); VendorId(ADSK); ServerId(8baf7d75-8b9b-46d0-b8ce-3ad1c19e6b19); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external server: Name(Specific Coefficient); VendorId(ADSK); ServerId(5a598293-1504-46cc-a9c0-de55c82848b9); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external server: Name(Specific Loss); VendorId(ADSK); ServerId(46245996-eebb-4536-ac17-9c1cd917d8cf); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external server: Name(Not Defined); VendorId(ADSK); ServerId(61e7b8e1-16d1-4fe4-82f0-327af736323f); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Registered an external server: Name(K Coefficient from Table); VendorId(ADSK); ServerId(51dd5e98-a9dd-464b-b286-4a37953610bf); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Registered an external server: Name(Specific Coefficient); VendorId(ADSK); ServerId(32d58662-b467-4f7b-b728-f6ad7b7ba5e3); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Registered an external server: Name(Specific Loss); VendorId(ADSK); ServerId(16f4f7be-0ac0-461d-a9a4-1d3511cd280e); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Starting External DB Application: FittingAndAccessoryCalculationServers, Class: FittingAndAccessoryCalculationServers.ServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit 2017\AddIns\MEPCalculation\FittingAndAccessoryCalculationServers.dll }
' 0:< API_SUCCESS { Registered an external server: Name(SteelConnectionsServer); VendorId(ADSK); ServerId(9c209d4a-ec98-460f-bfde-38f17a3443b4); ServiceId(282385f9-9627-4057-8b74-826d019f103c) }
' 0:< API_SUCCESS { Registered an external server: Name(FramingProfileServer); VendorId(ADSK); ServerId(54e490cd-8809-4dbb-84dd-dc0bc6cb1712); ServiceId(b2f816c0-6493-4537-8067-78a4e67f559e) }
' 0:< API_SUCCESS { Starting External DB Application: ExternalResourceDBServer, Class: RvtSteelConnectionsDB.SteelConnectionDBApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit 2017\AddIns\SteelConnections\RvtSteelConnectionsDB.dll }
' 0:< ::0:: Delta VM: Avail -7 -> 134216163 MB, Used +2 -> 260 MB, Peak +3 -> 261 MB; RAM: Avail -12 -> 62325 MB, Used +10 -> 388 MB, Peak +10 -> 388 MB
' 0:< API_SUCCESS { Registering DocumentOpening event by application CollaborateDB (bb3086be-63bb-44bd-99eb-d584c013cf2f). }
' 0:< API_SUCCESS { Registering DocumentSavedAs event by application CollaborateDB (bb3086be-63bb-44bd-99eb-d584c013cf2f). }
' 0:< API_SUCCESS { Registering DocumentOpened event by application CollaborateDB (bb3086be-63bb-44bd-99eb-d584c013cf2f). }
' 0:< API_SUCCESS { Registering DocumentClosing event by application CollaborateDB (bb3086be-63bb-44bd-99eb-d584c013cf2f). }
' 0:< API_SUCCESS { Starting External DB Application: CollaborateDB, Class: Autodesk.Revit.UI.Collaborate.CollaborateDBApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\A360 Collaboration for Revit 2017\CollaborateDB.dll }
' 0:< ::0:: Delta VM: Avail -26 -> 134216137 MB, Used +8 -> 269 MB, Peak +8 -> 270 MB; RAM: Avail -11 -> 62315 MB, Used +12 -> 401 MB, Peak +12 -> 401 MB
' 0:< GUI Resource Usage GDI: Avail 9835, Used 165, User: Used 249108103350
' 0:< API_SUCCESS { Registering ApplicationClosing event by application RaaS (d4f6554b-5d68-4a13-beec-4a0647c34408). }
' 0:< API_SUCCESS { Replacing command id 'ID_PHOTO_RENDER_IN_CLOUD' Executed implementation with implementation from application 'RaaS' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\RaaSForRevit\RaaSApplication.dll'. }
' 0:< API_SUCCESS { API registering command Executed event by application RaaS (d4f6554b-5d68-4a13-beec-4a0647c34408). }
' 0:< API_SUCCESS { Replacing command id 'ID_PHOTO_RENDER_IN_CLOUD' CanExecute implementation with implementation from application 'RaaS' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\RaaSForRevit\RaaSApplication.dll'. }
' 0:< API_SUCCESS { API registering command CanExecute event by application RaaS (d4f6554b-5d68-4a13-beec-4a0647c34408). }
' 0:< API_SUCCESS { Replacing command id 'ID_PHOTO_RENDER_GALLERY' Executed implementation with implementation from application 'RaaS' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\RaaSForRevit\RaaSApplication.dll'. }
' 0:< API_SUCCESS { Replacing command id 'ID_PHOTO_RENDER_GALLERY' CanExecute implementation with implementation from application 'RaaS' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\RaaSForRevit\RaaSApplication.dll'. }
' 0:< API_SUCCESS { Starting External Application: RaaS, Class: Autodesk.RaaS.RevitAddin.EApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: RaaSApplication.dll }
'H 13-Sep-2016 16:02:46.220; 0:<
Jrn.Directive "IdleTimeTaskSymbol" _
, "0.ExternalEvent"
' 0:< API_SUCCESS { Starting External Application: AutoLoad, Class: AutoLoader.AutoLoader, Vendor : ADSK(), Assembly: AutoLoader.dll }
' 0:< API_SUCCESS { Registering ViewActivated event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Registering DocumentClosing event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Registering DocumentClosed event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Registering DocumentChanged event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Registering DockableFrameVisibilityChanged event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
'H 13-Sep-2016 16:02:46.325; 0:<
, "1.OnIdleTask"
' 0:< API_SUCCESS { Registering Idling event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Registering FabricationPartBrowserChanged event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_FABRICATION_SETTINGS' CanExecute implementation with implementation from application 'FabPartBrowserApplication' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\FabricationPartBrowser\FabricationPartBrowser.dll'. }
' 0:< API_SUCCESS { API registering command Fabrication Settings CanExecute event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_FABRICATION_SETTINGS' Executed implementation with implementation from application 'FabPartBrowserApplication' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\FabricationPartBrowser\FabricationPartBrowser.dll'. }
' 0:< API_SUCCESS { API registering command Fabrication Settings Executed event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Replacing command id 'ID_FABRICATION_PART_SHOW_SERVICE_IN_PART_BROWSER' CanExecute implementation with implementation from application 'FabPartBrowserApplication' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\FabricationPartBrowser\FabricationPartBrowser.dll'. }
' 0:< API_SUCCESS { API registering command Show Service in Part Browser
'Show Service in Part Browser
'Show Service in Part Browser CanExecute event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Starting External Application: FabPartBrowserApplication, Class: FabricationPartBrowser.FabPartBrowserApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: FabricationPartBrowser.dll }
' 0:< API_SUCCESS { Registered an external server: Name(Duct not defined pressure drop UI server); VendorId(ADSK); ServerId(607992d7-359d-4593-b497-8aa238e2c564); ServiceId(52009bda-c817-4aef-aa31-36dc3742516e) }
' 0:< API_SUCCESS { Registered an external server: Name(Duct specific coefficient pressure drop UI server); VendorId(ADSK); ServerId(9641a039-441e-42e2-93a6-c0e2177cc23c); ServiceId(52009bda-c817-4aef-aa31-36dc3742516e) }
' 0:< API_SUCCESS { Registered an external server: Name(Duct specific loss pressure drop UI server); VendorId(ADSK); ServerId(d3b5e81d-9b8c-40da-8efb-99dd37fda611); ServiceId(52009bda-c817-4aef-aa31-36dc3742516e) }
' 0:< API_SUCCESS { Registered an external server: Name(Duct coefficient from table pressure drop UI server); VendorId(ADSK); ServerId(25fa8de2-67c4-47d1-91f6-bd6f0803a5ed); ServiceId(52009bda-c817-4aef-aa31-36dc3742516e) }
' 0:< API_SUCCESS { Registered an external server: Name(Pipe not defined pressure drop UI server); VendorId(ADSK); ServerId(62917391-e14d-4897-ad0c-05342d71e4f9); ServiceId(1931b323-1d29-4083-b1ce-bfdcddd011af) }
' 0:< API_SUCCESS { Registered an external server: Name(Pipe specific coefficient pressure drop UI server); VendorId(ADSK); ServerId(247265b6-7b71-4147-97c6-cc52b39c12aa); ServiceId(1931b323-1d29-4083-b1ce-bfdcddd011af) }
' 0:< API_SUCCESS { Registered an external server: Name(Pipe specific loss pressure drop UI server); VendorId(ADSK); ServerId(5978b92a-3f0b-4691-bbc8-caf2fae20a71); ServiceId(1931b323-1d29-4083-b1ce-bfdcddd011af) }
' 0:< API_SUCCESS { Registered an external server: Name(Pipe K coefficient from table pressure drop UI server); VendorId(ADSK); ServerId(cda19b6f-fbd5-4725-a0ce-f159bf5d02fe); ServiceId(1931b323-1d29-4083-b1ce-bfdcddd011af) }
' 0:< API_SUCCESS { Starting External Application: FittingAndAccessoryCalculationUIServers, Class: FittingAndAccessoryCalculationUIServers.ServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: FittingAndAccessoryCalculationUIServers.dll }
' 0:< API_SUCCESS { Replacing command id 'ID_EXPORT_IFC' Executed implementation with implementation from application 'IFC override' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\IFCExporterUI\IFCExportUI.dll'. }
' 0:< API_SUCCESS { API registering command Export to IAI IFC (Industry Foundation Classes) file format Executed event by application IFC override (e78da2e3-7e89-464c-97cd-2212c8be3fa8). }
' 0:< API_SUCCESS { Starting External Application: IFC override, Class: BIM.IFC.Export.UI.IFCCommandOverrideApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: IFCExportUI.dll }
' 0:< API_SUCCESS { Starting External Application: Import Shape, Class: ImportShape.ImportShape, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: ImportShape.dll }
' 0:< API_SUCCESS { Registered an external server: Name(Revit Default UI Server.); VendorId(ADSK); ServerId(3ffc688a-bb2e-4145-90ab-9443da02aef6); ServiceId(1fe75ba7-79d4-45f6-8e31-c1b83d4476a9) }
' 0:< API_SUCCESS { Starting External Application: KeynoteUIServer, Class: KeynoteUIServer.ServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: KeynoteUIServer.dll }
' 0:< API_SUCCESS { Registered an external server: Name(Internal Forces Server); VendorId(ADSK); ServerId(a97444aa-af8d-4a1e-af1f-fa7b77b368ee); ServiceId(a97444aa-af8d-4a1e-af1f-fa7b77b368ee) }
' 0:< API_SUCCESS { Starting External Application: Member Forces, Class: MemberForcesUI.ServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: MemberForces.dll }
' 0:< API_SUCCESS { Replacing command id 'ID_NUMBERING_REINF_PARTITIONS' Executed implementation with implementation from application 'Object Numbering' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\ObjectNumbering\ObjectNumberingUI.dll'. }
' 0:< API_SUCCESS { API registering command Executed event by application Object Numbering (32b5860a-aec9-4df7-96b0-07168b27446e). }
' 0:< API_SUCCESS { Replacing command id 'ID_NUMBERING_REINF_PARTITIONS' CanExecute implementation with implementation from application 'Object Numbering' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\ObjectNumbering\ObjectNumberingUI.dll'. }
' 0:< API_SUCCESS { API registering command CanExecute event by application Object Numbering (32b5860a-aec9-4df7-96b0-07168b27446e). }
' 0:< API_SUCCESS { Starting External Application: Object Numbering, Class: BIM.Numbering.UI.NumberingUIApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: ObjectNumberingUI.dll }
' 0:< API_SUCCESS { Registered an external server: Name(PointCloudSnappingServer); VendorId(ADSK); ServerId(85f4b666-8811-4e3d-9ed4-3d2ae4cd2e4c); ServiceId(aaa05780-790c-43dc-bc41-1c2150227f45) }
' 0:< Third Party Updater 'PointCloudSnappingServer: Snapping Pipe Updater' registered for all documents.
' 0:< API_SUCCESS { Starting External Application: PointCloudSnappingServer, Class: PointCloudSnappingServer.Application, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: PointCloudSnappingServer.dll }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_DUCT_PRESSURE_LOSS_REPORT' CanExecute implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { API registering command Duct Pressure Loss Report CanExecute event by application PressureLossReport (b00d3753-d3bc-4255-9c97-e389de87a5d6). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_DUCT_PRESSURE_LOSS_REPORT' Executed implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { API registering command Duct Pressure Loss Report Executed event by application PressureLossReport (b00d3753-d3bc-4255-9c97-e389de87a5d6). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_PIPE_PRESSURE_LOSS_REPORT' CanExecute implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { API registering command Pipe Pressure Loss Report CanExecute event by application PressureLossReport (b00d3753-d3bc-4255-9c97-e389de87a5d6). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_PIPE_PRESSURE_LOSS_REPORT' Executed implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { API registering command Pipe Pressure Loss Report Executed event by application PressureLossReport (b00d3753-d3bc-4255-9c97-e389de87a5d6). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_SELECT_DUCT_PRESSURE_LOSS_REPORT' CanExecute implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_SELECT_DUCT_PRESSURE_LOSS_REPORT' Executed implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_SELECT_PIPE_PRESSURE_LOSS_REPORT' CanExecute implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_SELECT_PIPE_PRESSURE_LOSS_REPORT' Executed implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { Starting External Application: PressureLossReport, Class: PressureLossReport.PressureLossReportApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: PressureLossReport.dll }
' 0:< API_SUCCESS { Registered an external server: Name(SectionTypeParameterServer); VendorId(ADSK); ServerId(1b91ce46-ddb4-44ec-a942-d45efadde353); ServiceId(c42c9b55-c491-4611-97e9-9e617958e13e) }
' 0:< API_SUCCESS { Starting External Application: Structural Section Properties, Class: SectionProperties.ServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: SectionProperties.dll }
' 0:< ::0:: Delta VM: Avail -38 -> 134216100 MB, Used +4 -> 273 MB, Peak +4 -> 274 MB; RAM: Avail -9 -> 62306 MB, Used +8 -> 409 MB, Peak +8 -> 410 MB
' 0:< GUI Resource Usage GDI: Avail 9831, Used 169, User: Used 249108103351
' 0:< API_SUCCESS { Registering DocumentCreated event by application Common (4e6988f3-7c3a-41a6-aa31-511fa8f0f451). }
' 0:< API_SUCCESS { Registering DocumentOpened event by application Common (4e6988f3-7c3a-41a6-aa31-511fa8f0f451). }
' 0:< API_SUCCESS { Registering DocumentSaving event by application Common (4e6988f3-7c3a-41a6-aa31-511fa8f0f451). }
' 0:< API_SUCCESS { Registering DocumentSavingAs event by application Common (4e6988f3-7c3a-41a6-aa31-511fa8f0f451). }
' 0:< API_SUCCESS { Registering DocumentSynchronizedWithCentral event by application Common (4e6988f3-7c3a-41a6-aa31-511fa8f0f451). }
' 0:< API_SUCCESS { Registering DocumentSynchronizingWithCentral event by application Common (4e6988f3-7c3a-41a6-aa31-511fa8f0f451). }
' 0:< API_SUCCESS { Registering DocumentClosing event by application Common (4e6988f3-7c3a-41a6-aa31-511fa8f0f451). }
' 0:< API_SUCCESS { Registering DocumentChanged event by application Common (4e6988f3-7c3a-41a6-aa31-511fa8f0f451). }
' 0:< API_SUCCESS { Registering FileExporting event by application Common (4e6988f3-7c3a-41a6-aa31-511fa8f0f451). }
' 0:< API_SUCCESS { Registering FileExported event by application Common (4e6988f3-7c3a-41a6-aa31-511fa8f0f451). }
' 0:< API_SUCCESS { Registering ViewActivated event by application Common (4e6988f3-7c3a-41a6-aa31-511fa8f0f451). }
' 0:< Third Party Updater 'Common: DrxUpdater' registered for all documents.
' 0:< API_SUCCESS { Starting External Application: Common, Class: Adsk.DrxApplication.DrxCommonApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Areabook\Program\DrxCommon.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6400, name: , text: Calculate Areas, class: Adsk.DrxApplication.DrxAreaCalculationCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Areabook\Program\AreaCalculation.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6401, name: , text: Edit Room, class: Adsk.DrxApplication.DrxRoomEditCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Areabook\Program\AreaCalculation.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6402, name: , text: Add/Edit Floor Area, class: Adsk.DrxApplication.DrxFloorAreaAddCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Areabook\Program\AreaCalculation.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6403, name: , text: Add Room Group, class: Adsk.DrxApplication.DrxRoomGroupAddCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Areabook\Program\AreaCalculation.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6404, name: , text: Edit Room Group, class: Adsk.DrxApplication.DrxRoomGroupEditCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Areabook\Program\AreaCalculation.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6405, name: , text: Calculation Settings, class: Adsk.DrxApplication.DrxAreaCalculationOptionsCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Areabook\Program\AreaCalculation.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6406, name: , text: Edit Room Assignment Type, class: Adsk.DrxApplication.DrxRoomAssignmentsEditCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Areabook\Program\AreaCalculation.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6407, name: , text: Hide/Show Areabook IDs, class: Adsk.DrxApplication.DrxAreaToggleIDsCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Areabook\Program\AreaCalculation.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6408, name: , text: Set language, class: Adsk.DrxApplication.DrxChangeUILanguageCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Areabook\Program\AreaCalculation.dll }
' 0:< API_SUCCESS { Starting External Application: Area Calculation International, Class: Adsk.DrxApplication.DrxAreaCalculationApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Areabook\Program\AreaCalculation.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6409, name: , text: Batch Print, class: Revit.PrintHarness.PrintHarnessAPI, assembly: C:\Program Files\Autodesk\Batch Print for Revit 2017\BatchPrint.dll }
' 0:< API_SUCCESS { Starting External Application: Batch Print Application, Class: Revit.PrintHarness.PrintHarnessApplication, Vendor : ADSK(Autodesk, subscription.autodesk.com), Assembly: C:\Program Files\Autodesk\Batch Print for Revit 2017\BatchPrint.dll }
' 0:< API_SUCCESS { Registering ViewActivated event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Replacing command id 'ID_COLLABORATE' Executed implementation with implementation from application 'Collaborate' dll 'C:\Program Files\Autodesk\A360 Collaboration for Revit 2017\Collaborate.dll'. }
' 0:< API_SUCCESS { API registering command Collaborate Executed event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Replacing command id 'ID_COLLABORATE' CanExecute implementation with implementation from application 'Collaborate' dll 'C:\Program Files\Autodesk\A360 Collaboration for Revit 2017\Collaborate.dll'. }
' 0:< API_SUCCESS { API registering command Collaborate CanExecute event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Replacing command id 'ID_COLLABORATE_360' Executed implementation with implementation from application 'Collaborate' dll 'C:\Program Files\Autodesk\A360 Collaboration for Revit 2017\Collaborate.dll'. }
' 0:< API_SUCCESS { API registering command Executed event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Replacing command id 'ID_COLLABORATE_360' CanExecute implementation with implementation from application 'Collaborate' dll 'C:\Program Files\Autodesk\A360 Collaboration for Revit 2017\Collaborate.dll'. }
' 0:< API_SUCCESS { API registering command CanExecute event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Starting External Application: Collaborate, Class: Autodesk.Revit.UI.Collaborate.CollaborateApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\A360 Collaboration for Revit 2017\Collaborate.dll }
' 0:< API_SUCCESS { Replacing command id 'ID_COLLABORATE_BROWSER' Executed implementation with implementation from application 'CollaborateBrowser' dll 'C:\Program Files\Autodesk\A360 Collaboration for Revit 2017\CollaborateBrowser.dll'. }
' 0:< API_SUCCESS { API registering command A360 Projects Executed event by application CollaborateBrowser (901c7e33-857c-4c9c-846c-8f971c7cf72a). }
' 0:< API_SUCCESS { Replacing command id 'ID_COLLABORATE_BROWSER' CanExecute implementation with implementation from application 'CollaborateBrowser' dll 'C:\Program Files\Autodesk\A360 Collaboration for Revit 2017\CollaborateBrowser.dll'. }
' 0:< API_SUCCESS { API registering command A360 Projects CanExecute event by application CollaborateBrowser (901c7e33-857c-4c9c-846c-8f971c7cf72a). }
' 0:< API_SUCCESS { Starting External Application: CollaborateBrowser, Class: Autodesk.Revit.UI.CollaborateBrowser.CollaborateBrowserApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\A360 Collaboration for Revit 2017\CollaborateBrowser.dll }
'C 13-Sep-2016 16:02:47.415; 0:< Loading bcg.dll: Autodesk.Bcg, Version=1.7.3.0, Culture=neutral, PublicKeyToken=d672471c03b2c408
'C 13-Sep-2016 16:02:47.500; 0:< SkyscraperClientHost: Initialize Success: True
' 0:< API_SUCCESS { Starting External Application: SkyscraperClientHostApplication, Class: SkyscraperClientHost.SkyscraperClientHostApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\A360 Collaboration for Revit 2017\SkyscraperClientHost.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6410, name: , text: Transmit a model, class: eTransmitForRevit.eTransmitCommand, assembly: C:\Program Files\Autodesk\eTransmit for Revit 2017\eTransmitForRevit.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6411, name: , text: Help, class: eTransmitForRevit.eTransmitHelp, assembly: C:\Program Files\Autodesk\eTransmit for Revit 2017\eTransmitForRevit.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6412, name: , text: About, class: eTransmitForRevit.eTransmitAbout, assembly: C:\Program Files\Autodesk\eTransmit for Revit 2017\eTransmitForRevit.dll }
' 0:< API_SUCCESS { Starting External Application: eTransmit for Revit, Class: eTransmitForRevit.eTransmitApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\eTransmit for Revit 2017\eTransmitForRevit.dll }
' 0:< ::0:: Delta VM: Avail -12 -> 134216088 MB, Used +2 -> 275 MB, Peak +1 -> 276 MB; RAM: Avail +0 -> 62307 MB, Used +4 -> 414 MB, Peak +4 -> 414 MB
' 0:< API_SUCCESS { Added pushbutton Id: 6413, name: , text: Check, class: BIMStandardsManager.Command, assembly: C:\Program Files\Autodesk\Revit Model Review 2017\ModelReview.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6414, name: , text: Manage, class: BIMStandardsManager.CommandConfig, assembly: C:\Program Files\Autodesk\Revit Model Review 2017\ModelReview.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6415, name: , text: View, class: BIMStandardsManager.CommandReview, assembly: C:\Program Files\Autodesk\Revit Model Review 2017\ModelReview.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6416, name: , text: About..., class: BIMStandardsManager.CommandAbout, assembly: C:\Program Files\Autodesk\Revit Model Review 2017\ModelReview.dll }
' 0:< ::0:: Delta VM: Avail 134216088 MB, Used 275 MB; RAM: Avail +10 -> 62317 MB, Used -11 -> 403 MB
' 0:< GUI Resource Usage GDI: Avail 9827, Used 173, User: Used 249108103351
' 0:< API_SUCCESS { Starting External Application: Model Review, Class: BIMStandardsManager.ExternalApp, Vendor : ADSK(Autodesk, subscription.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit Model Review 2017\ModelReview.dll }
' 0:< API_SUCCESS { Registering DocumentOpened event by application Model Review Events (1469753f-186d-4dc2-b0e9-431b302e62f9). }
' 0:< API_SUCCESS { Registering DocumentSaving event by application Model Review Events (1469753f-186d-4dc2-b0e9-431b302e62f9). }
' 0:< API_SUCCESS { Registering DocumentSavingAs event by application Model Review Events (1469753f-186d-4dc2-b0e9-431b302e62f9). }
' 0:< API_SUCCESS { Registering DocumentSynchronizingWithCentral event by application Model Review Events (1469753f-186d-4dc2-b0e9-431b302e62f9). }
' 0:< API_ERROR { Starting External Application: Model Review Events, Class: BIMStandardsManager.CommandEventsApp, Vendor : ADSK(Autodesk, subscription.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit Model Review 2017\ModelReview.dll }
' 0:< API_SUCCESS { Registering ApplicationInitialized event by application AREXRevitStart (26a4f622-eb0a-4829-a9c3-9194b77a7fe4). }
' 0:< API_SUCCESS { Starting External Application: AREXRevitStart, Class: REX.AREXRevitStart.AREXRevitStart, Vendor : ADSK(), Assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Products\Revit\AREXRevitStart.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6417, name: , text: Revit DB Link, class: Revit.Addon.RevitDBLink.CS.Command, assembly: C:\Program Files\Autodesk\Revit DB Link 2017\RevitDBLink.dll }
' 0:< API_SUCCESS { Starting External Application: RevitDBLink, Class: Revit.Addon.RevitDBLink.CS.App, Vendor : ADSK(Autodesk, subscription.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit DB Link 2017\RevitDBLink.dll }
' 0:< API_SUCCESS { Registering ApplicationInitialized event by application AREXRevitStart (c0566ed7-4309-4082-b3ba-ea6b7b4d292a). }
' 0:< API_SUCCESS { Registering ApplicationInitialized event by application AREXRevitStart (1aa95c7e-ebf6-4205-b465-993f7efdc2e1). }
' 0:< API_SUCCESS { Added pushbutton Id: 6418, name: , text: Launch SNU, class: SpaceNaming.Command, assembly: C:\Program Files\Autodesk\Space Naming Utility for Revit MEP 2017\SpaceNaming.dll }
' 0:< API_SUCCESS { Starting External Application: Space Naming Utility Application, Class: SpaceNaming.Command, Vendor : ADSK(Autodesk, subscription.autodesk.com), Assembly: C:\Program Files\Autodesk\Space Naming Utility for Revit MEP 2017\SpaceNaming.dll }
' 0:< API_SUCCESS { Registering ApplicationInitialized event by application AREXRevitStart (be4833f0-363a-4442-82f9-fc2805b4220f). }
' 0:< API_SUCCESS { Registering DocumentOpened event by application Worksharing Monitor Application (04e9bc6c-9b81-4c82-a31a-7559fe7a1579). }
' 0:< API_SUCCESS { Registering DocumentClosing event by application Worksharing Monitor Application (04e9bc6c-9b81-4c82-a31a-7559fe7a1579). }
' 0:< API_SUCCESS { Registering DocumentSaved event by application Worksharing Monitor Application (04e9bc6c-9b81-4c82-a31a-7559fe7a1579). }
' 0:< API_SUCCESS { Registering DocumentSavedAs event by application Worksharing Monitor Application (04e9bc6c-9b81-4c82-a31a-7559fe7a1579). }
' 0:< API_SUCCESS { Starting External Application: Worksharing Monitor Application, Class: WorkSharingLib.ExternalApplication, Vendor : ADSK(Autodesk, subscription.autodesk.com), Assembly: C:\Program Files\Autodesk\Worksharing Monitor for Revit 2017\WorkSharingLib.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6419, name: , text: Launch WSM, class: WorksharingCommand.WorksharingCommand, assembly: C:\Program Files\Autodesk\Worksharing Monitor for Revit 2017\WorkSharingCommand.dll }
' 0:< API_SUCCESS { Starting External Application: Worksharing Monitor Launch App, Class: WorksharingCommand.WorksharingApp, Vendor : ADSK(Autodesk, subscription.autodesk.com), Assembly: C:\Program Files\Autodesk\Worksharing Monitor for Revit 2017\WorkSharingCommand.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6420, name: , text: Glue, class: BIM360RevitAddin.GlueItCommand, assembly: C:\ProgramData\Autodesk\Revit\Addins\2017\BIM360Glue\BIM360GlueRevit2017Addin.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6421, name: , text: Clash
'Pinpoint, class: BIM360RevitAddin.GluePinPointCommand, assembly: C:\ProgramData\Autodesk\Revit\Addins\2017\BIM360Glue\BIM360GlueRevit2017Addin.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6422, name: , text: Equipment
'Properties, class: BIM360RevitAddin.EquipmentCommand, assembly: C:\ProgramData\Autodesk\Revit\Addins\2017\BIM360Glue\BIM360GlueRevit2017Addin.dll }
' 0:< ::0:: Delta VM: Avail -26 -> 134216062 MB, Used +12 -> 287 MB, Peak +22 -> 298 MB; RAM: Avail -13 -> 62304 MB, Used +19 -> 423 MB, Peak +17 -> 432 MB
' 0:< GUI Resource Usage GDI: Avail 9819, Used 181, User: Used 249108103359
' 0:< API_SUCCESS { Registering ApplicationInitialized event by application Ribbon (c82755fa-ff61-5113-9a07-27b2127a13e5). }
' 0:< API_SUCCESS { Registering ApplicationClosing event by application Ribbon (c82755fa-ff61-5113-9a07-27b2127a13e5). }
' 0:< API_SUCCESS { Starting External Application: Ribbon, Class: BIM360RevitAddin.HorizontalRibbon, Vendor : BIM360(Autodesk, Inc, www.autodesk.com), Assembly: BIM360Glue/BIM360GlueRevit2017Addin.dll }
' 0:< API_SUCCESS { Registering FailuresProcessing event by application Common (053ba6e7-1d1a-41e4-8529-c7cde73336e8). }
' 0:< API_SUCCESS { Registering DocumentCreated event by application Common (053ba6e7-1d1a-41e4-8529-c7cde73336e8). }
' 0:< API_SUCCESS { Registering DocumentOpened event by application Common (053ba6e7-1d1a-41e4-8529-c7cde73336e8). }
' 0:< API_SUCCESS { Registering DocumentSaving event by application Common (053ba6e7-1d1a-41e4-8529-c7cde73336e8). }
' 0:< API_SUCCESS { Registering DocumentSavingAs event by application Common (053ba6e7-1d1a-41e4-8529-c7cde73336e8). }
' 0:< API_SUCCESS { Registering DocumentSynchronizedWithCentral event by application Common (053ba6e7-1d1a-41e4-8529-c7cde73336e8). }
' 0:< API_SUCCESS { Registering DocumentSynchronizingWithCentral event by application Common (053ba6e7-1d1a-41e4-8529-c7cde73336e8). }
' 0:< API_SUCCESS { Registering DocumentClosing event by application Common (053ba6e7-1d1a-41e4-8529-c7cde73336e8). }
' 0:< API_SUCCESS { Registering DocumentChanged event by application Common (053ba6e7-1d1a-41e4-8529-c7cde73336e8). }
' 0:< API_SUCCESS { Registering DialogBoxShowing event by application Common (053ba6e7-1d1a-41e4-8529-c7cde73336e8). }
' 0:< API_SUCCESS { Registering FileExporting event by application Common (053ba6e7-1d1a-41e4-8529-c7cde73336e8). }
' 0:< API_SUCCESS { Registering FileExported event by application Common (053ba6e7-1d1a-41e4-8529-c7cde73336e8). }
' 0:< API_SUCCESS { Registering ViewActivated event by application Common (053ba6e7-1d1a-41e4-8529-c7cde73336e8). }
' 0:< Third Party Updater 'Common: BrxUpdater' registered for all documents.
' 0:< API_SUCCESS { Starting External Application: Common, Class: Adsk.BrxApplication.BrxCommonApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Buildingbook\Program\BrxCommon.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6423, name: , text: Calculate Building Part Quantities, class: Adsk.BrxApplication.BrxBuildingBookCalculationCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Buildingbook\Program\BuildingBook.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6424, name: , text: Calculation Settings, class: Adsk.BrxApplication.BrxBuildingBookCalcOptCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Buildingbook\Program\BuildingBook.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6425, name: , text: Quantity IDs: Show All, class: Adsk.BrxApplication.BrxShowQIDsCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Buildingbook\Program\BuildingBook.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6426, name: , text: Quantity IDs: Hide All, class: Adsk.BrxApplication.BrxHideQIDsCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Buildingbook\Program\BuildingBook.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6427, name: , text: Material IDs: Show All, class: Adsk.BrxApplication.BrxShowMaterialIDsCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Buildingbook\Program\BuildingBook.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6428, name: , text: Material IDs: Hide All, class: Adsk.BrxApplication.BrxHideMaterialIDsCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Buildingbook\Program\BuildingBook.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6429, name: , text: Hide/Show IDs by Category, class: Adsk.BrxApplication.BrxHideShowByCategoryCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Buildingbook\Program\BuildingBook.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6430, name: , text: Select Building Parts by ID, class: Adsk.BrxApplication.BrxBuildingBookSelectByQIDCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Buildingbook\Program\BuildingBook.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6431, name: , text: Purge discontinued versions data, class: Adsk.BrxApplication.BrxPurgeBPQ2014Cmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Buildingbook\Program\BuildingBook.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6432, name: , text: Set language, class: Adsk.BrxApplication.BrxChangeUILanguageCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Buildingbook\Program\BuildingBook.dll }
' 0:< API_SUCCESS { Starting External Application: BuildingBook International, Class: Adsk.BrxApplication.BrxBuildingBookApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Buildingbook\Program\BuildingBook.dll }
' 0:< ::0:: Delta VM: Avail -11 -> 134216052 MB, Used -2 -> 286 MB; RAM: Avail -1 -> 62303 MB, Used 423 MB
' 0:< API_SUCCESS { Registering ApplicationInitialized event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Registering DocumentOpened event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Registering DocumentCreated event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Registering DocumentSavedAs event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Registering DocumentSaved event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Registering DocumentClosed event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Registering ApplicationClosing event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Replacing command id 'ID_TEAM' Executed implementation with implementation from application 'Communicator for Autodesk Revit' dll 'C:\ProgramData\Autodesk\Revit\Addins\2017\Communicator\SmartMonkey.dll'. }
' 0:< API_SUCCESS { API registering command Communicator Executed event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Replacing command id 'ID_TEAM' CanExecute implementation with implementation from application 'Communicator for Autodesk Revit' dll 'C:\ProgramData\Autodesk\Revit\Addins\2017\Communicator\SmartMonkey.dll'. }
' 0:< API_SUCCESS { API registering command Communicator CanExecute event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Starting External Application: Communicator for Autodesk Revit, Class: Autodesk.Revit.SmartMonkeyPlugin.SmartMonkeyApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: Communicator\SmartMonkey.dll }
' 0:< API_SUCCESS { Registering Idling event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Registering ViewActivated event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Registering ViewActivating event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Registering DocumentClosing event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Registering DocumentClosed event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Registering DocumentOpened event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Replacing command id 'ID_VISUAL_PROGRAMMING_DYNAMO' CanExecute implementation with implementation from application 'Dynamo For Revit' dll 'C:\Program Files\Dynamo 0.9\Revit_2017\DynamoRevitVersionSelector.dll'. }
' 0:< API_SUCCESS { API registering command Launch Dynamo
'Dynamo CanExecute event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
'Dynamo BeforeExecuted event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Replacing command id 'ID_VISUAL_PROGRAMMING_DYNAMO' Executed implementation with implementation from application 'Dynamo For Revit' dll 'C:\Program Files\Dynamo 0.9\Revit_2017\DynamoRevitVersionSelector.dll'. }
'Dynamo Executed event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< Third Party Updater 'Dynamo For Revit: Sun and Shadow Settings Updater' registered for all documents.
' 0:< API_SUCCESS { Registering DocumentChanged event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Starting External Application: Dynamo For Revit, Class: Dynamo.Applications.VersionLoader, Vendor : ADSK(Dynamo), Assembly: C:\Program Files\Dynamo 0.9\Revit_2017\DynamoRevitVersionSelector.dll }
' 0:< API_SUCCESS { Replacing command id 'ID_VIEWS_FOR_A360' Executed implementation with implementation from application 'Views For A360' dll 'C:\ProgramData\Autodesk\Revit\Addins\2017\.\ExportViewSelectorAddin\ExportViewSelectorAddin.dll'. }
' 0:< API_SUCCESS { API registering command Views For A360 Executed event by application Views For A360 (78bd1446-1817-4842-8075-591b0424acaa). }
' 0:< API_SUCCESS { Replacing command id 'ID_VIEWS_FOR_A360' CanExecute implementation with implementation from application 'Views For A360' dll 'C:\ProgramData\Autodesk\Revit\Addins\2017\.\ExportViewSelectorAddin\ExportViewSelectorAddin.dll'. }
' 0:< API_SUCCESS { API registering command Views For A360 CanExecute event by application Views For A360 (78bd1446-1817-4842-8075-591b0424acaa). }
' 0:< API_SUCCESS { Starting External Application: Views For A360, Class: Autodesk.Revit.Addin.ExportViewSelector.ExportViewSelectorApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: .\ExportViewSelectorAddin\ExportViewSelectorAddin.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6433, name: , text: Convert RFA
'to FormIt 360, class: RFAToAXMAddon.RFAToAXMCommand, assembly: C:\Program Files\Autodesk\FormIt 360 Converter For Revit 2017\FormIt360ConversionAddon\RFAToAXMAddon.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6434, name: , text: Convert SKP
'to FormIt 360, class: RFAToAXMAddon.SketchUpToAXMCommand, assembly: C:\Program Files\Autodesk\FormIt 360 Converter For Revit 2017\FormIt360ConversionAddon\RFAToAXMAddon.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6435, name: , text: Import FormIt 360
'to RVT, class: AXMImportorAddon.AXMImportorCommand, assembly: C:\Program Files\Autodesk\FormIt 360 Converter For Revit 2017\FormIt360ConversionAddon\AXMImportorAddon.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6436, name: , text: Reload Families, class: AXMImportorAddon.ReloadFamiliesCommand, assembly: C:\Program Files\Autodesk\FormIt 360 Converter For Revit 2017\FormIt360ConversionAddon\AXMImportorAddon.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6437, name: , text: About FormIt 360, class: FormItConverter.FormIt360Link, assembly: C:\Program Files\Autodesk\FormIt 360 Converter For Revit 2017\FormIt360ConversionAddon\FormItConverterRibbon.dll }
' 0:< API_SUCCESS { Starting External Application: FormIt Conversion, Class: FormItConverter.Ribbon, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\FormIt 360 Converter For Revit 2017\FormIt360ConversionAddon\FormItConverterRibbon.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6438, name: , text: Import Autodesk Fabrication Job File, class: MEPFabricationOpenJob.ImportJobCommand, assembly: C:\Program Files\Autodesk\Fabrication 2017\Revit Extension for Fabrication\MEPFabricationOpenJob.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6439, name: , text: Export Autodesk Fabrication Job File, class: MEPFabricationOpenJob.ExportJobCommand, assembly: C:\Program Files\Autodesk\Fabrication 2017\Revit Extension for Fabrication\MEPFabricationOpenJob.dll }
' 0:< API_SUCCESS { Starting External Application: Revit Extension for Fabrication, Class: MEPFabricationOpenJob.Application, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Fabrication 2017\Revit Extension for Fabrication\MEPFabricationOpenJob.dll }
' 0:< API_SUCCESS { Registering DocumentCreated event by application Common (3a77a84e-3f0d-4f84-be7f-a7ecc7f3f708). }
' 0:< API_SUCCESS { Registering DocumentOpened event by application Common (3a77a84e-3f0d-4f84-be7f-a7ecc7f3f708). }
' 0:< API_SUCCESS { Registering DocumentSaving event by application Common (3a77a84e-3f0d-4f84-be7f-a7ecc7f3f708). }
' 0:< API_SUCCESS { Registering DocumentSavingAs event by application Common (3a77a84e-3f0d-4f84-be7f-a7ecc7f3f708). }
' 0:< API_SUCCESS { Registering DocumentSynchronizedWithCentral event by application Common (3a77a84e-3f0d-4f84-be7f-a7ecc7f3f708). }
' 0:< API_SUCCESS { Registering DocumentSynchronizingWithCentral event by application Common (3a77a84e-3f0d-4f84-be7f-a7ecc7f3f708). }
' 0:< API_SUCCESS { Registering DocumentClosing event by application Common (3a77a84e-3f0d-4f84-be7f-a7ecc7f3f708). }
' 0:< API_SUCCESS { Registering DocumentChanged event by application Common (3a77a84e-3f0d-4f84-be7f-a7ecc7f3f708). }
' 0:< API_SUCCESS { Registering DialogBoxShowing event by application Common (3a77a84e-3f0d-4f84-be7f-a7ecc7f3f708). }
' 0:< API_SUCCESS { Registering FileExporting event by application Common (3a77a84e-3f0d-4f84-be7f-a7ecc7f3f708). }
' 0:< API_SUCCESS { Registering FileExported event by application Common (3a77a84e-3f0d-4f84-be7f-a7ecc7f3f708). }
' 0:< API_SUCCESS { Registering ViewActivated event by application Common (3a77a84e-3f0d-4f84-be7f-a7ecc7f3f708). }
' 0:< Third Party Updater 'Common: RrxUpdater' registered for all documents.
' 0:< API_SUCCESS { Starting External Application: Common, Class: Adsk.RrxApplication.RrxCommonApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Roombook\Program\RrxCommon.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6440, name: , text: Calculate Room Quantities, class: Adsk.RrxApplication.RrxCalculationStyleCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Roombook\Program\RoomBookInternational.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6441, name: , text: Calculation Settings, class: Adsk.RrxApplication.RrxCalculationOptionsCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Roombook\Program\RoomBookInternational.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6442, name: , text: Apply Surface Materials to Rooms, class: Adsk.RrxApplication.RrxApplyMaterialStyleCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Roombook\Program\RoomBookInternational.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6443, name: , text: Edit Surface Materials, class: Adsk.RrxApplication.RrxMaterialStyleCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Roombook\Program\RoomBookInternational.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6444, name: , text: Hide/Show Quantity IDs, class: Adsk.RrxApplication.RrxCalculationToggleQIDCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Roombook\Program\RoomBookInternational.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6445, name: , text: Hide/Show Finish IDs, class: Adsk.RrxApplication.RrxCalculationToggleFinishSymCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Roombook\Program\RoomBookInternational.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6446, name: , text: Set language, class: Adsk.RrxApplication.RrxChangeUILanguageRBICmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Roombook\Program\RoomBookInternational.dll }
' 0:< API_SUCCESS { Starting External Application: RoomBook International, Class: Adsk.RrxApplication.RrxRoomBookInternationalApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Roombook\Program\RoomBookInternational.dll }
' 0:< API_SUCCESS { Registering DocumentClosed event by application External Tool (e0a2d7a5-030b-4d4e-8689-8406903ea241). }
' 0:< API_SUCCESS { Registering DocumentCreating event by application External Tool (e0a2d7a5-030b-4d4e-8689-8406903ea241). }
' 0:< API_SUCCESS { Registering DocumentClosing event by application External Tool (e0a2d7a5-030b-4d4e-8689-8406903ea241). }
' 0:< API_SUCCESS { Registering DocumentSaving event by application External Tool (e0a2d7a5-030b-4d4e-8689-8406903ea241). }
' 0:< API_SUCCESS { Registering DocumentSavingAs event by application External Tool (e0a2d7a5-030b-4d4e-8689-8406903ea241). }
' 0:< API_SUCCESS { Registering DocumentChanged event by application External Tool (e0a2d7a5-030b-4d4e-8689-8406903ea241). }
' 0:< API_SUCCESS { Registering ViewActivating event by application External Tool (e0a2d7a5-030b-4d4e-8689-8406903ea241). }
' 0:< API_SUCCESS { Registered an external server: Name(ModifyConnectionParametersServer); VendorId(ADSK); ServerId(d81402f0-e558-4434-89a8-30ec1f52a4d0); ServiceId(e9c0f948-320e-4e7f-a573-10755555305d) }
' 0:< API_SUCCESS { Registered an external server: Name(ConnectionTypeChangedServer); VendorId(ADSK); ServerId(43229eb0-f06b-49a9-b404-ff52ae5842ad); ServiceId(e31c3100-9cab-4303-b85b-4171703ce1c4) }
' 0:< API_SUCCESS { Starting External Application: External Tool, Class: RvtSteelConnectionsUI.SteelConnection, Vendor : Autodesk(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Steel Connections for Revit\RvtSteelConnectionsUI.dll }
' 0:< ::0:: Delta VM: Avail -12 -> 134216041 MB, Used +4 -> 290 MB; RAM: Avail -4 -> 62299 MB, Used +3 -> 427 MB
' 0:< GUI Resource Usage GDI: Avail 9816, Used 184, User: Used 249108103360
'C 13-Sep-2016 16:02:50.025; 0:< ->processShellCommand
'E 13-Sep-2016 16:02:50.026; 0:<
Jrn.Command "Internal" , "Show or hide recent files , ID_STARTUP_PAGE"
' 0:< ::1:: Delta VM: Avail -99 -> 134215943 MB, Used +10 -> 301 MB, Peak +2 -> 301 MB; RAM: Avail -11 -> 62289 MB, Used +11 -> 439 MB, Peak +7 -> 439 MB
' 0:< GUI Resource Usage GDI: Avail 9809, Used 191, User: Used 249108103370
'C 13-Sep-2016 16:02:50.233; 0:< <-processShellCommand
'C 13-Sep-2016 16:02:50.234; 0:< ->DesktopMFCApp::doStartupWarnings
'C 13-Sep-2016 16:02:50.234; 0:< License readyForUI
'C 13-Sep-2016 16:02:50.292; 0:< manage involvement
' 0:< ::1:: Delta VM: Avail -11 -> 134215932 MB, Used +1 -> 302 MB, Peak +1 -> 303 MB; RAM: Avail -4 -> 62286 MB, Used +3 -> 442 MB, Peak +3 -> 442 MB
' 0:< GUI Resource Usage GDI: Avail 9809, Used 191, User: Used 249108103369
'C 13-Sep-2016 16:02:50.386; 0:< manage debug modes
'C 13-Sep-2016 16:02:50.387; 0:< MFCApp::testGraphicsHardware
' 0:< Revit Graphics Information
' 0:< Current Mode : DirectX Hardware
' 0:< Use Hardware: ON
' 0:< Use Overlays : ON
' 0:< START CanUseHardware(forced)
' 1:<
'OGS Device Memory Size: 34704 MB
' 1:< ::1:: Delta VM: Avail -32889 -> 134183044 MB, Used +63 -> 366 MB, Peak +65 -> 368 MB; RAM: Avail -16 -> 62270 MB, Used +22 -> 465 MB, Peak +23 -> 466 MB
' 1:< GUI Resource Usage GDI: Avail 9808, Used 192, User: Used 249108103382
' 1:< DX Device: DirectX 11, Hardware
' 1:< DX Device: DirectX 11, WARP
'C 13-Sep-2016 16:02:50.720; 1:< START video card certification
' 1:<
'Current driver version: \Windows\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_90f801d8702dbf86\nvd3dumx,C:\Windows\System32\DriverStore\Fi:21.21.13.6926
'Certified driver(s): 9.18.13.3182
' 1:< VIDEO CARD ENVIRONMENT: CARD="NVIDIA Quadro K2000" ManufacturerID="10DE" DeviceID="0FFE" osID="8000" DRIVER="\Windows\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_90f801d8702dbf86\nvd3dumx,C:\Windows\System32\DriverStore\Fi:21.21.13.6926" DEVICE="DX11" FL_Caps="50" (Shader Model)
'C 13-Sep-2016 16:02:50.743; 1:< FINISH video card certification
' 0.357230 1:<<' 0:<
'Can use hardware=y
'Hardware support flags:
'FeatureLevelLow=n
'DrvOlderThanTested=y
'DrvNewerThanTested=n
'CardIsNotListed=n
'NotCertifiedEnv=n
'3GBSwitchIsOn=n
'SoftwareModeForced=n
' 0:< FINISH CanUseHardware(forced)
'C 13-Sep-2016 16:02:50.744; 0:< MFCApp::testMSAA
'C 13-Sep-2016 16:02:50.744; 0:< postConditionalWarnings
'C 13-Sep-2016 16:02:50.744; 0:< giveAtomRegistrationWarnings
'C 13-Sep-2016 16:02:50.744; 0:< warnings->consumeAll
'C 13-Sep-2016 16:02:50.745; 0:< Process result of DebugModes-Changed Task Dialog
'C 13-Sep-2016 16:02:50.745; 0:< isMaterialLibraryAvailable
'C 13-Sep-2016 16:02:50.745; 0:< start up warnings for AddIns
'C 13-Sep-2016 16:02:50.745; 0:< <-DesktopMFCApp::doStartupWarnings
' 0:< DBG_INFO: Resetting WPF rendering mode back to Revit default in Desktop Open Notification!: line 269 of RibbonAPI.cpp.
' 0:< Setting WPF rendering mode to SoftwareOnly
'C 13-Sep-2016 16:02:50.747; 0:< <-desktop InitNativeInstance
'C 13-Sep-2016 16:02:50.747; 0:< ->desktop InitManagedInstance
' 1:< ::1:: Delta VM: Avail -14 -> 134183031 MB, Used +3 -> 369 MB, Peak +3 -> 371 MB; RAM: Avail -18 -> 62253 MB, Used +10 -> 475 MB, Peak +10 -> 476 MB
' 1:< GUI Resource Usage GDI: Avail 9658, Used 342, User: Used 249108103383
' 1:< API_SUCCESS { Added pushbutton Id: 6447, name: , text: Modify, class: REX.AREXRevitMngr.Modifier, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Products\Revit\AREXRevitMngr.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6448, name: , text: Delete, class: REX.AREXRevitMngr.Remover, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Products\Revit\AREXRevitMngr.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6449, name: , text: Preferences, class: REX.AREXRevitMngr.Preferences, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Products\Revit\AREXRevitMngr.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6450, name: , text: Frame Generator, class: REX.DLTFrame3D.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Modeling\DLTFrame3D\DLTFrame3D.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6451, name: , text: Grids Generator, class: REX.DRevitGridGenerator.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Modeling\DRevitGridGenerator\DRevitGridGenerator.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6452, name: , text: Rafter Framing, class: REX.DRafterFraming.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Modeling\DRafterFraming\DRafterFraming.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6453, name: , text: Roof Trusses, class: REX.DRoofTrusses.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Modeling\DRoofTrusses\DRoofTrusses.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6454, name: , text: Wood Framing Walls, class: REX.ATimberFraming.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Modeling\ATimberFraming\ATimberFraming.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6455, name: , text: Automatic Reinforcement Generation, class: REX.DReinfAuto.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Reinforcement\DReinfAuto\DReinfAuto.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6456, name: , text: Beams, class: REX.DReinfBeam.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Reinforcement\DReinfBeam\DReinfBeam.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6457, name: , text: Columns, class: REX.DReinfColumn.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Reinforcement\DReinfColumn\DReinfColumn.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6458, name: , text: Continuous Footings, class: REX.DReinfFootingCont.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Reinforcement\DReinfFootingCont\DReinfFootingCont.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6459, name: , text: Interferences of Reinforcing Bars, class: REX.DReinfRebarCollisions.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Reinforcement\DReinfRebarCollisions\DReinfRebarCollisions.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6460, name: , text: Parapets, class: REX.DReinfParapet.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Reinforcement\DReinfParapet\DReinfParapet.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6461, name: , text: Pile Caps, class: REX.DReinfPileCap.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Reinforcement\DReinfPileCap\DReinfPileCap.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6462, name: , text: Piles, class: REX.DReinfPile.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Reinforcement\DReinfPile\DReinfPile.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6463, name: , text: Retaining Walls, class: REX.DReinfRetainingWall.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Reinforcement\DReinfRetainingWall\DReinfRetainingWall.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6464, name: , text: Slab Corners, class: REX.DReinfSlabCorner.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Reinforcement\DReinfSlabCorner\DReinfSlabCorner.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6465, name: , text: Slab Openings, class: REX.DReinfSlabOpening.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Reinforcement\DReinfSlabOpening\DReinfSlabOpening.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6466, name: , text: Spread Footings, class: REX.DReinfFootingSpread.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Reinforcement\DReinfFootingSpread\DReinfFootingSpread.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6467, name: , text: Wall Corners, class: REX.DReinfWallCorner.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Reinforcement\DReinfWallCorner\DReinfWallCorner.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6468, name: , text: Walls, class: REX.DReinfWall.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Reinforcement\DReinfWall\DReinfWall.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6469, name: , text: Compare Models, class: REX.DRevitModelsCompare.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Tools\DRevitModelsCompare\DRevitModelsCompare.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6470, name: , text: Element Positioning, class: REX.DElementsPositioning.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Tools\DElementsPositioning\DElementsPositioning.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6471, name: , text: Bridge - Concrete box girder, class: REX.DBridgesBoxGirder.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Bridges\DBridgesBoxGirder\DBridgesBoxGirder.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6472, name: , text: Bridge - Concrete slab, class: REX.DBridgesConcreteSlab.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Bridges\DBridgesConcreteSlab\DBridgesConcreteSlab.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6473, name: , text: Bridge - Concrete slab with girders, class: REX.DBridgesBeamsGirder.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Bridges\DBridgesBeamsGirder\DBridgesBeamsGirder.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6474, name: , text: Customization of bridge families, class: REX.DBridgesXml.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Bridges\DBridgesXml\DBridgesXml.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6475, name: , text: Documentation, class: REX.DBridgesDocumentation.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Bridges\DBridgesDocumentation\DBridgesDocumentation.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6476, name: , text: Export Revit Elements to AutoCAD Civil 3D, class: REX.DBridge.ExportSolids.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Bridges\DBridge.ExportSolids\DBridge.ExportSolids.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6477, name: , text: Integration with AutoCAD Civil3D, class: REX.DBridgeCivil3DConnector.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Bridges\DBridgeCivil3DConnector\DBridgeCivil3DConnectorx64.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6478, name: , text: Roads and Terrain, class: REX.DBridgeRoad.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Bridges\DBridgeRoad\DBridgeRoad.dll }
' 1:< ::1:: Delta VM: Avail -12 -> 134183019 MB, Used +1 -> 370 MB; RAM: Avail -4 -> 62250 MB, Used +2 -> 478 MB, Peak +1 -> 478 MB
' 1:< GUI Resource Usage GDI: Avail 9650, Used 350, User: Used 249108103383
' 1:< Third Party Updater 'AREXRevitStart: REXExtension: DReinfBeam' registered for all documents.
' 1:< Third Party Updater 'AREXRevitStart: REXExtension: DReinfColumn' registered for all documents.
' 1:< Third Party Updater 'AREXRevitStart: REXExtension: DReinfFootingSpread' registered for all documents.
' 1:< Third Party Updater 'AREXRevitStart: REXExtension: DReinfWall' registered for all documents.
' 1:< API_SUCCESS { Registering DocumentOpened event by application AREXRevitStart (c0566ed7-4309-4082-b3ba-ea6b7b4d292a). }
' 1:< API_SUCCESS { Registering DocumentCreated event by application AREXRevitStart (c0566ed7-4309-4082-b3ba-ea6b7b4d292a). }
' 1:< API_SUCCESS { Registering DisplayingOptionsDialog event by application AREXRevitStart (c0566ed7-4309-4082-b3ba-ea6b7b4d292a). }
' 1:< API_SUCCESS { Registering ViewActivated event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 1:< API_SUCCESS { Registering DocumentSynchronizingWithCentral event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 1:< API_SUCCESS { Registering DocumentSynchronizedWithCentral event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
'C 13-Sep-2016 16:02:53.521; 0:< <-desktop InitManagedInstance
' 0:< ::1:: Delta VM: Avail -56 -> 134182964 MB, Used +8 -> 379 MB, Peak +8 -> 380 MB; RAM: Avail -33 -> 62217 MB, Used +22 -> 501 MB, Peak +23 -> 502 MB
' 0:< GUI Resource Usage GDI: Avail 9623, Used 377, User: Used 249108103388
'C 13-Sep-2016 16:02:53.824; 0:< appPriv idle
' 0:< OPERATING SYSTEM INFORMATION:
' 0:< BuildNumber : 14393
' 0:< BuildType : Multiprocessor Free
' 0:< Caption : Microsoft Windows 10 Pro
' 0:< CodeSet : 1252
' 0:< CountryCode : 1
' 0:< FreePhysicalMemory : 63706804
' 0:< FreeSpaceInPagingFiles : 9961472
' 0:< FreeVirtualMemory : 73081704
' 0:< MaxProcessMemorySize : 137438953344
' 0:< OSLanguage : 1033
' 0:< OSType : 18
' 0:< ServicePackMajorVersion : 0
' 0:< ServicePackMinorVersion : 0
' 0:< TotalVirtualMemorySize : 76904144
' 0:< TotalVisibleMemorySize : 66942672
' 0:< Version : 10.0.14393
' 0:< Process affinity mask : FFF
' 0:< System affinity mask : FFF
' 0:< PROCESSOR INFORMATION:
' 0:< AddressWidth : 64
' 0:< Architecture : 9
' 0:< Availability : 3
' 0:< Caption : Intel64 Family 6 Model 79 Stepping 1
' 0:< CurrentClockSpeed : 3401
' 0:< DataWidth : 64
' 0:< Description : Intel64 Family 6 Model 79 Stepping 1
' 0:< Family : 179
' 0:< L2CacheSize : 1536
' 0:< Level : 6
' 0:< Manufacturer : GenuineIntel
' 0:< MaxClockSpeed : 3401
' 0:< Name : Intel(R) Core(TM) i7-6800K CPU @ 3.40GHz
' 0:< ProcessorType : 3
' 0:< Revision : 20225
' 0:< Role : CPU
' 0:< SocketDesignation : SOCKET 0
' 0:< StatusInfo : 3
' 0:< Version :
' 0:< VIDEO CONTROLLER INFORMATION:
' 0:< AdapterCompatibility : NVIDIA
' 0:< AdapterDACType : Integrated RAMDAC
' 0:< AdapterRAM : -2147483648
' 0:< Caption : NVIDIA Quadro K2000
' 0:< CurrentBitsPerPixel : 32
' 0:< CurrentHorizontalResolution : 1280
' 0:< CurrentNumberOfColors : 4294967296
' 0:< CurrentRefreshRate : 60
' 0:< CurrentVerticalResolution : 1024
' 0:< Description : NVIDIA Quadro K2000
' 0:< DriverDate : 20160830000000.000000-000
' 0:< DriverVersion : 21.21.13.6926
' 0:< MaxRefreshRate : 75
' 0:< MinRefreshRate : 56
' 0:< Monochrome : 0
' 0:< Name : NVIDIA Quadro K2000
' 0:< VideoArchitecture : 5
' 0:< VideoMemoryType : 2
' 0:< VideoModeDescription : 1280 x 1024 x 4294967296 colors
' 0:< VideoProcessor : Quadro K2000
' 0:< ::1:: Delta VM: Avail -6 -> 134182959 MB, Used +1 -> 380 MB, Peak +1 -> 381 MB; RAM: Avail -11 -> 62207 MB, Used +4 -> 505 MB, Peak +3 -> 505 MB
' 0:< GUI Resource Usage GDI: Avail 9614, Used 386, User: Used 249108103396
' 0:< PRINTER INFORMATION:
' 0:< Caption : Send To OneNote 2016
' 0:< Default : 0
' 0:< DeviceID : Send To OneNote 2016
' 0:< Direct : 0
' 0:< DriverName : Send to Microsoft OneNote 16 Driver
' 0:< EnableBIDI : 0
' 0:< EnableDevQueryPrint : 0
' 0:< HorizontalResolution : 600
' 0:< Local : -1
' 0:< Name : Send To OneNote 2016
' 0:< Network : 0
' 0:< PortName : nul:
' 0:< PrintJobDataType : RAW
' 0:< PrintProcessor : winprint
' 0:< RawOnly : 0
' 0:< Shared : 0
' 0:< SpoolEnabled : -1
' 0:< VerticalResolution : 600
' 0:< Caption : PDFCreator
' 0:< Default : -1
' 0:< DeviceID : PDFCreator
' 0:< Direct : 0
' 0:< DriverName : PDFCreator
' 0:< Local : -1
' 0:< Name : PDFCreator
' 0:< Network : 0
' 0:< PortName : pdfcmon
' 0:< RawOnly : 0
' 0:< Shared : 0
' 0:< Caption : Microsoft XPS Document Writer
' 0:< Default : 0
' 0:< DeviceID : Microsoft XPS Document Writer
' 0:< Direct : 0
' 0:< DriverName : Microsoft XPS Document Writer v4
' 0:< Local : -1
' 0:< Name : Microsoft XPS Document Writer
' 0:< Network : 0
' 0:< PortName : PORTPROMPT:
' 0:< RawOnly : 0
' 0:< Shared : 0
' 0:< Caption : Microsoft Print to PDF
' 0:< Default : 0
' 0:< DeviceID : Microsoft Print to PDF
' 0:< Direct : 0
' 0:< DriverName : Microsoft Print To PDF
' 0:< Local : -1
' 0:< Name : Microsoft Print to PDF
' 0:< Network : 0
' 0:< RawOnly : 0
' 0:< Shared : 0
' 0:< Caption : Fax
' 0:< Default : 0
' 0:< DeviceID : Fax
' 0:< Direct : 0
' 0:< DriverName : Microsoft Shared Fax Driver
' 0:< HorizontalResolution : 200
' 0:< Local : -1
' 0:< Name : Fax
' 0:< Network : 0
' 0:< PortName : SHRFAX:
' 0:< RawOnly : 0
' 0:< Shared : 0
' 0:< VerticalResolution : 200
' 0:< PRINTER CONFIGURATION INFORMATION:
' 0:< Color : 2
' 0:< Copies : 1
' 0:< Description : Send To OneNote 2016
' 0:< DriverVersion : 1539
' 0:< Orientation : 1
' 0:< PaperLength : 2794
' 0:< PaperSize : Letter 8 1/2 x 11 in
' 0:< PaperWidth : 2159
' 0:< PrintQuality : 600
' 0:< SpecificationVersion : 1025
' 0:< XResolution : 600
' 0:< YResolution : 600
' 0:< Color : 2
' 0:< Copies : 1
' 0:< Description : PDFCreator
' 0:< Color : 2
' 0:< Copies : 1
' 0:< Description : Microsoft XPS Document Writer
' 0:< Color : 2
' 0:< Copies : 1
' 0:< Description : Microsoft Print to PDF
' 0:< Color : 1
' 0:< Description : Fax
' 0:< DriverVersion : 1024
' 0:< Duplex : 0
' 0:< PrintQuality : 200
' 0:< XResolution : 200
' 0:< YResolution : 200
' 0:< ::1:: Delta VM: Avail +7 -> 134182967 MB, Used -4 -> 376 MB, Peak +0 -> 382 MB; RAM: Avail -13 -> 62195 MB, Used +1 -> 507 MB, Peak +2 -> 508 MB
' 0:< GUI Resource Usage GDI: Avail 9619, Used 381, User: Used 249108103397
'E 13-Sep-2016 16:03:06.795; 0:<
Jrn.AppButtonEvent 1 , "Application Menu is opening"
'E 13-Sep-2016 16:03:08.284; 0:<
Jrn.AppButtonEvent 0 , "Application Menu is closing"
'E 13-Sep-2016 16:03:08.317; 0:<
Jrn.Command "Ribbon" , "Quit the application; prompts to save projects , ID_APP_EXIT"
' 1:< ::4:: Delta VM: Avail +43 -> 134183011 MB, Used -6 -> 371 MB; RAM: Avail +118 -> 62313 MB, Used -8 -> 499 MB, Peak +2 -> 511 MB
' 1:< GUI Resource Usage GDI: Avail 9683, Used 317, User: Used 249108103300
' 1:< Revit worker 1 closed cleanly
' 0:< [00001aa8]QueueMinder stopped
'C 13-Sep-2016 16:03:08.774; 1:< logging finished virtualization services
'C 13-Sep-2016 16:03:08.774; 1:< logging finished worker services
'C 13-Sep-2016 16:03:08.774; 1:< logging erased queues
' 0.296081 1:<<
'C 13-Sep-2016 16:03:08.774; 0:< ->desktop ExitManagedInstance
'C 13-Sep-2016 16:03:08.797; 0:< <-desktop ExitManagedInstance
'C 13-Sep-2016 16:03:08.797; 0:< ->desktop ExitNativeInstance
' 0:< API_SUCCESS { Unregistering ViewActivated event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Unregistering DocumentClosing event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Unregistering DocumentClosed event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Unregistering DocumentChanged event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Unregistering DockableFrameVisibilityChanged event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Unregistering Idling event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Registering FabricationPartBrowserChanged event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Restoring command id 'ID_MEP_FABRICATION_SETTINGS' CanExecute implementation. }
' 0:< API_SUCCESS { API unregistering command Fabrication Settings CanExecute event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Restoring command id 'ID_MEP_FABRICATION_SETTINGS' Executed implementation. }
' 0:< API_SUCCESS { API unregistering command Fabrication Settings Executed event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Restoring command id 'ID_FABRICATION_PART_SHOW_SERVICE_IN_PART_BROWSER' CanExecute implementation. }
' 0:< API_SUCCESS { API unregistering command Show Service in Part Browser
'Show Service in Part Browser
'Show Service in Part Browser CanExecute event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Restoring command id 'ID_EXPORT_IFC' Executed implementation. }
' 0:< API_SUCCESS { API unregistering command Export to IAI IFC (Industry Foundation Classes) file format Executed event by application IFC override (e78da2e3-7e89-464c-97cd-2212c8be3fa8). }
' 0:< Third Party Updater 'Common: DrxUpdater' has been unregistered.
' 0:< API_SUCCESS { Unregistering ViewActivated event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Unregistering ApplicationClosing event by application Ribbon (c82755fa-ff61-5113-9a07-27b2127a13e5). }
' 0:< Third Party Updater 'Common: BrxUpdater' has been unregistered.
' 0:< API_SUCCESS { Restoring command id 'ID_TEAM' Executed implementation. }
' 0:< API_SUCCESS { API unregistering command Communicator Executed event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Restoring command id 'ID_TEAM' CanExecute implementation. }
' 0:< API_SUCCESS { API unregistering command Communicator CanExecute event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Unregistering DocumentOpened event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Unregistering DocumentCreated event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Unregistering DocumentSavedAs event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Unregistering DocumentSaved event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Unregistering ApplicationClosing event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Unregistering DocumentSynchronizingWithCentral event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Unregistering DocumentSynchronizedWithCentral event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< Third Party Updater 'Common: RrxUpdater' has been unregistered.
' 0:< API_SUCCESS { Unregistering DocumentClosed event by application External Tool (e0a2d7a5-030b-4d4e-8689-8406903ea241). }
' 0:< API_SUCCESS { Unregistering DocumentCreating event by application External Tool (e0a2d7a5-030b-4d4e-8689-8406903ea241). }
' 0:< API_SUCCESS { Unregistering DocumentClosing event by application External Tool (e0a2d7a5-030b-4d4e-8689-8406903ea241). }
' 0:< API_SUCCESS { Unregistering DocumentSaving event by application External Tool (e0a2d7a5-030b-4d4e-8689-8406903ea241). }
' 0:< API_SUCCESS { Unregistering DocumentSavingAs event by application External Tool (e0a2d7a5-030b-4d4e-8689-8406903ea241). }
' 0:< API_SUCCESS { Unregistering DocumentChanged event by application External Tool (e0a2d7a5-030b-4d4e-8689-8406903ea241). }
' 0:< API_SUCCESS { Unregistering ViewActivating event by application External Tool (e0a2d7a5-030b-4d4e-8689-8406903ea241). }
' 0:< API_SUCCESS { Unregistering DocumentSavedAs event by application CollaborateDB (bb3086be-63bb-44bd-99eb-d584c013cf2f). }
' 0:< API_SUCCESS { Unregistering DocumentOpened event by application CollaborateDB (bb3086be-63bb-44bd-99eb-d584c013cf2f). }
' 0:< API_SUCCESS { Unregistering DocumentClosing event by application CollaborateDB (bb3086be-63bb-44bd-99eb-d584c013cf2f). }
' 0:< Forcibly unregistering Updater with id:51c0be9b-07a8-443a-be8c-21db815b17e7
' 0:< Forcibly unregistering Updater with id:00000000-c00c-478e-9226-63d19d957aed
' 0:< Forcibly unregistering Updater with id:00000000-9a62-4ecd-adb1-9a93bf539620
' 0:< Forcibly unregistering Updater with id:00000000-7174-4309-88a1-27d09090ef6d
' 0:< Forcibly unregistering Updater with id:00000000-0a7a-49e7-bd08-6696111b3b53
' 0:< Forcibly unregistering Updater with id:649e613c-2d39-4a7b-9720-662750f5243e
' 0:< Forcibly removing all update triggers for all Updaters
' 0:< Unregistering all external services.
' 0:< ::4:: Delta VM: Avail +68 -> 134183080 MB, Used -58 -> 313 MB; RAM: Avail +2 -> 62316 MB, Used -4 -> 496 MB
' 0:< GUI Resource Usage GDI: Avail 9689, Used 311, User: Used 249108103290
' 0:< Exception occurred
'C 13-Sep-2016 16:03:09.099; 0:< ExceptionCode=0xc0000005 ExceptionFlags=0x00000000 ExceptionAddress=00007FFF8357A0A0
' 0:< System (MB) [Available / Total ] [Revit Memory Usage (MB) ]
' 0:< RAM Statistics: 62316 / 65373 496=InUse 511=Peak
' 0:< VM Statistics: 134183081 / 134217727 313=InUse 382=Peak
' 0:< Unconverted MessageBox "An unrecoverable error has occurred. The program will now be terminated. All of your data has been recently saved, so there is no need to create recovery files."
' 0:< ::4:: Delta VM: Avail -26 -> 134183054 MB, Used 313 MB; RAM: Avail -7 -> 62309 MB, Used 496 MB
' 0:< GUI Resource Usage GDI: Avail 9686, Used 314, User: Used 249108103283
'H 13-Sep-2016 16:03:10.342; 0:<
Jrn.Data "MessageBox" _
, "IDOK", "An unrecoverable error has occurred. The program will now be terminated. All of your data has been recently saved, so there is no need to create recovery files."
'C 13-Sep-2016 16:03:10.342; 0:< program terminated:initialize>
Message 6 of 12
' 0:< Initial VM: Avail 134217444 MB, Used 13 MB, Peak 13; RAM: Avail 63225 MB, Used 48 MB, Peak 13
' 0:< GUI Resource Usage GDI: Avail 9995, Used 5, User: Used 3
'C 13-Sep-2016 16:02:32.515; 0:< started recording journal file
' Build: 20160720_1515(x64)
' Branch: RELEASE_2017_RTM
Dim Jrn
Set Jrn = CrsJournalScript
'C 13-Sep-2016 16:02:32.530; 0:< ->desktop InitApplication
'C 13-Sep-2016 16:02:32.531; 0:< <-desktop InitApplication
'C 13-Sep-2016 16:02:32.531; 0:< ->desktop InitNativeInstance
' 0:< Options::loadOptions: m_strDataLibraryLocations=Imperial Library=C:\ProgramData\Autodesk\RVT 2017\Libraries\US Imperial\,Imperial Detail Library=C:\ProgramData\Autodesk\RVT 2017\Libraries\US Imperial\Detail Items, Roombook Library=C:\ProgramData\Autodesk\RVT 2017\Libraries\US Imperial\Roombook Library, Areabook Library=C:\ProgramData\Autodesk\RVT 2017\Libraries\US Imperial\Areabook Library, Buildingbook Library=C:\ProgramData\Autodesk\RVT 2017\Libraries\US Imperial\Buildingbook Library (defaultLib==\Library)
' 0:< ::0:: Delta VM: Avail -24 -> 134217420 MB, Used +4 -> 18 MB, Peak +4 -> 18 MB; RAM: Avail -59 -> 63167 MB, Used +11 -> 60 MB, Peak +11 -> 60 MB
' 0:< GUI Resource Usage GDI: Avail 9980, Used 20, User: Used 249108103196
'C 13-Sep-2016 16:02:33.641; 0:< License initialization complete
' 0:< License version: 17.3.26.0
' 0:< ::0:: Delta VM: Avail -173 -> 134217247 MB, Used +31 -> 49 MB, Peak +33 -> 52 MB; RAM: Avail -85 -> 63082 MB, Used +49 -> 109 MB, Peak +49 -> 109 MB
' 0:< GUI Resource Usage GDI: Avail 9980, Used 20, User: Used 249108103220
' 0:< SystemSettings:
' 0:< 12=multiCoreCharacteristic
' 0:< true=isDotNetInstalled
' 0:< 4.6.01586(394802)=dotNetInstalledVersionString
' 0:< false=isProcessUserModeExceptionPolicyDisabledForCallbackFilter
' 0:< ::0:: Delta VM: Avail -18 -> 134217230 MB, Used +8 -> 58 MB, Peak +5 -> 58 MB; RAM: Avail -15 -> 63068 MB, Used +15 -> 124 MB, Peak +15 -> 124 MB
' 0:< GUI Resource Usage GDI: Avail 9973, Used 27, User: Used 249108103233
'C 13-Sep-2016 16:02:34.299; 0:< manage licensing
' 0:< ::0:: Delta VM: Avail -51 -> 134217180 MB, Used +5 -> 63 MB, Peak +12 -> 70 MB; RAM: Avail -151 -> 62917 MB, Used +14 -> 139 MB, Peak +19 -> 143 MB
' 0:< GUI Resource Usage GDI: Avail 9973, Used 27, User: Used 249108103237
' 0:< License mode: Standalone
' 0:< Type: Standalone - Locked
' 0:< Usage: Commercial
' 0:< Behavior: Extendable
' 0:< Expiration: Saturday, October 07, 2017
' 0:< ::0:: Delta VM: Avail -568 -> 134216613 MB, Used +35 -> 99 MB, Peak +29 -> 99 MB; RAM: Avail -44 -> 62874 MB, Used +35 -> 174 MB, Peak +30 -> 174 MB
' 0:< GUI Resource Usage GDI: Avail 9940, Used 60, User: Used 249108103250
' 0:< ::0:: Delta VM: Avail -156 -> 134216457 MB, Used +69 -> 169 MB, Peak +69 -> 169 MB; RAM: Avail -256 -> 62619 MB, Used +93 -> 267 MB, Peak +92 -> 267 MB
' 0:< GUI Resource Usage GDI: Avail 9838, Used 162, User: Used 249108103345
' 0:< Autodesk Revit 2017
' 0:< 64-bit load point = C:\Program Files\Autodesk\Revit 2017
' 0:< this journal = C:\Users\tople\AppData\Local\Autodesk\Revit\Autodesk Revit 2017\Journals\journal.0021.txt
' 0:< ::0:: Delta VM: Avail -9 -> 134216448 MB, Used +1 -> 170 MB, Peak +1 -> 170 MB; RAM: Avail -16 -> 62604 MB, Used +4 -> 271 MB, Peak +4 -> 271 MB
' 0:< Journal Init
'C 13-Sep-2016 16:02:40.969; 0:< Log Summary
' 0:< .Count
' 0:< ...PendingMessages = 48
' 0:< .Marshalling
' 0:< ...CompactCaching = 1 (Enabled)
' 0:< .ThreadPool
' 0:< ...ActivePoolSize = 26
' 0:< ...ConfiguredPoolSize = automatic
' 0:< ...ParallelCores = 12
' 0:< ...RequestedPoolSize = automatic
' 0:< .Tuning
' 0:< ...ElemTable = 1 (Serial except when multithreaded)
'H 13-Sep-2016 16:02:40.969; 0:<
Jrn.Data "JournalDefaultTemplate" _
, "Construction Template=$AllUsersAppData\Templates\US Imperial\Construction-Default.rte, Architectural Template=$AllUsersAppData\Templates\US Imperial\default.rte, Structural Template=$AllUsersAppData\Templates\US Imperial\Structural Analysis-Default.rte, Mechanical Template=$AllUsersAppData\Templates\US Imperial\Mechanical-Default.rte"
'H 13-Sep-2016 16:02:40.970; 0:<
Jrn.Data "JournalDefaultViewDiscipline" _
, "Coordination"
Jrn.Directive "Version" _
, "2017.000", "2.153"
Jrn.Directive "Username" _
, "tople@mc-atl.com"
Jrn.Directive "CategoryDisciplineFilter" _
, -1
Jrn.Directive "DisciplineOption" _
, 7677
'H 13-Sep-2016 16:02:40.971; 0:<
Jrn.Directive "TabDisplayOptions" _
, "StayOnModifyInProject", 0
, "StayOnModifyInFamily", 1
, "ActiveCtOnSelection", 1
Jrn.Directive "AllowLinkSelection" _
, 1
Jrn.Directive "AllowFaceSelection" _
, 0
Jrn.Directive "AllowUnderlaySelection" _
, 0
Jrn.Directive "AllowPinnedSelection" _
, 1
Jrn.Directive "ThinLinesEnabled" _
, 0
'C 13-Sep-2016 16:02:40.981; 1:< logging master created MasterQueue Session6132_P0MasterQueue
'C 13-Sep-2016 16:02:40.982; 1:< logging started queue minder
'C 13-Sep-2016 16:02:40.982; 1:< logging started worker services
' 0:< ::0:: Delta VM: Avail -18 -> 134216431 MB, Used +0 -> 171 MB, Peak +1 -> 172 MB; RAM: Avail -14 -> 62590 MB, Used +1 -> 273 MB, Peak +5 -> 277 MB
' 0:< GUI Resource Usage GDI: Avail 9835, Used 165, User: Used 249108103344
' 0:< API_SUCCESS { Registered an external service: Name(NavisWorks Draw Service); VendorId(ADSK); ServiceId(e454a471-b9f3-4cb7-96b1-bab4cf7742a6) }
' 0:< API_SUCCESS { Registered an external service: Name(External Resource Service); VendorId(ADSK); ServiceId(b3892e5f-9161-4bbc-958a-c8ef75e94e96) }
' 0:< API_SUCCESS { Registered an external service: Name(NavisworksExportService); VendorId(ADSK); ServiceId(a9bdf0fd-2632-429e-bc35-50ebc2b824d2) }
' 0:< API_SUCCESS { Registered an external service: Name(Code Checking Parameter Service); VendorId(ADSK); ServiceId(de6db8de-dea6-40bd-9503-4ffe62ff6143) }
' 0:< API_SUCCESS { Registered an external service: Name(FramingProfileService); VendorId(ADSK); ServiceId(b2f816c0-6493-4537-8067-78a4e67f559e) }
' 0:< API_SUCCESS { Registered an external service: Name(Modify Connection Parameters Service); VendorId(ADSK); ServiceId(e9c0f948-320e-4e7f-a573-10755555305d) }
' 0:< API_SUCCESS { Registered an external service: Name(Connection Type Changed Service); VendorId(ADSK); ServiceId(e31c3100-9cab-4303-b85b-4171703ce1c4) }
' 0:< API_SUCCESS { Registered an external service: Name(SteelConnectionsService); VendorId(ADSK); ServiceId(282385f9-9627-4057-8b74-826d019f103c) }
' 0:< API_SUCCESS { Registered an external service: Name(Section Type Parameter Service); VendorId(ADSK); ServiceId(c42c9b55-c491-4611-97e9-9e617958e13e) }
' 0:< API_SUCCESS { Registered an external service: Name(Internal Forces Service); VendorId(ADSK); ServiceId(a97444aa-af8d-4a1e-af1f-fa7b77b368ee) }
' 0:< API_SUCCESS { Registered an external service: Name(IFC Export Service); VendorId(ADSK); ServiceId(d8b95737-f943-414c-9ad7-86785bf1acbc) }
' 0:< API_SUCCESS { Registered an external server: Name(Revit IFC Exporter); VendorId(ADSK); ServerId(ef8d0493-7f36-42b5-b9aa-8aaac716482b); ServiceId(d8b95737-f943-414c-9ad7-86785bf1acbc) }
' 0:< API_SUCCESS { Registered an external service: Name(IFC Import Service); VendorId(ADSK); ServiceId(98d317e2-e943-4cc0-a3da-2edf32a5d942) }
' 0:< API_SUCCESS { Registered an external server: Name(Revit IFC Importer); VendorId(ADSK); ServerId(660a7370-f6d6-43c8-8456-6b2eea785110); ServiceId(98d317e2-e943-4cc0-a3da-2edf32a5d942) }
' 0:< API_SUCCESS { Registered an external service: Name(Duct Fitting/Accessory Pressure Drop Calculator); VendorId(ADSK); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external service: Name(Pipe Fitting/Accessory Pressure Drop Calculator); VendorId(ADSK); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Registered an external service: Name(Duct Pressure Drop Calculator); VendorId(ADSK); ServiceId(8c707bd6-ecd6-4150-a0df-bd6c85dd9bb0) }
' 0:< API_SUCCESS { Registered an external service: Name(Pipe Pressure Drop Calculator); VendorId(ADSK); ServiceId(62d13e0c-9fe1-4d8e-a0c7-1f93d24cf3f3) }
' 0:< API_SUCCESS { Registered an external service: Name(Plumbing Flow Calculator); VendorId(ADSK); ServiceId(bf0da776-5307-4747-8285-f358e92a90d0) }
' 0:< API_SUCCESS { Registered an external service: Name(External Resource UI Service); VendorId(ADSK); ServiceId(1fe75ba7-79d4-45f6-8e31-c1b83d4476a9) }
' 0:< API_SUCCESS { Registered an external service: Name(Point Cloud Snapping Service); VendorId(ADSK); ServiceId(aaa05780-790c-43dc-bc41-1c2150227f45) }
' 0:< API_SUCCESS { Registered an external service: Name(Duct fitting and accessory pressure drop UI service); VendorId(ADSK); ServiceId(52009bda-c817-4aef-aa31-36dc3742516e) }
' 0:< API_SUCCESS { Registered an external service: Name(Pipe fitting and accessory pressure drop UI service); VendorId(ADSK); ServiceId(1931b323-1d29-4083-b1ce-bfdcddd011af) }
' 0:< ::0:: Delta VM: Avail -40 -> 134216392 MB, Used +18 -> 189 MB, Peak +17 -> 189 MB; RAM: Avail -109 -> 62482 MB, Used +14 -> 287 MB, Peak +9 -> 287 MB
' 0:< GUI Resource Usage GDI: Avail 9835, Used 165, User: Used 249108103346
' 0.168375 1:<<:initialize>
' 0:< ::0:: Delta VM: Avail -223 -> 134216169 MB, Used +68 -> 257 MB, Peak +68 -> 258 MB; RAM: Avail -145 -> 62337 MB, Used +90 -> 378 MB, Peak +90 -> 378 MB
' 0:< To make IFC server work.
' 0:< API_SUCCESS { Registered an external server: Name(Revit Default DB Server); VendorId(ADSK); ServerId(bd4f0f53-394a-4468-b37e-1e7949013382); ServiceId(b3892e5f-9161-4bbc-958a-c8ef75e94e96) }
' 0:< API_SUCCESS { Starting External DB Application: KeynoteDBServer, Class: KeynoteDBServer.ServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit 2017\AddIns\Keynote\KeynoteDBServer.dll }
' 0:< API_SUCCESS { Registered an external server: Name(Plumbing Fixture Flow); VendorId(ADSK); ServerId(56121d7d-e1d7-42a3-bed8-f4d1d32058c8); ServiceId(bf0da776-5307-4747-8285-f358e92a90d0) }
' 0:< API_SUCCESS { Registered an external server: Name(Simplified Colebrook Equation); VendorId(ADSK); ServerId(ea275fb1-5d7b-47d6-b828-bf856df9bfd5); ServiceId(62d13e0c-9fe1-4d8e-a0c7-1f93d24cf3f3) }
' 0:< API_SUCCESS { Registered an external server: Name(Altshul-Tsal Equation); VendorId(ADSK); ServerId(042a10e0-8d24-46a4-9596-d192b3125d0c); ServiceId(8c707bd6-ecd6-4150-a0df-bd6c85dd9bb0) }
' 0:< API_SUCCESS { Registered an external server: Name(Haaland Equation); VendorId(USERADDIN); ServerId(2e9a77c0-62a0-4693-9442-33312be60ad7); ServiceId(8c707bd6-ecd6-4150-a0df-bd6c85dd9bb0) }
' 0:< API_SUCCESS { Registered an external server: Name(Haaland Equation); VendorId(USERADDIN); ServerId(58ea1b7c-2fca-453f-9ab9-7a3b9927ecc1); ServiceId(62d13e0c-9fe1-4d8e-a0c7-1f93d24cf3f3) }
' 0:< API_SUCCESS { Registered an external server: Name(Colebrook Equation); VendorId(USERADDIN); ServerId(e395a0ec-48a4-4255-b957-afbb3d73cb67); ServiceId(8c707bd6-ecd6-4150-a0df-bd6c85dd9bb0) }
' 0:< API_SUCCESS { Registered an external server: Name(Colebrook Equation); VendorId(USERADDIN); ServerId(0875f550-6141-4e34-a6b7-547cf9cfda01); ServiceId(62d13e0c-9fe1-4d8e-a0c7-1f93d24cf3f3) }
' 0:< API_SUCCESS { Starting External DB Application: StraightSegmentCalculationServersApp, Class: StraightSegmentCalculationServers.ServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit 2017\AddIns\MEPCalculation\StraightSegmentCalculationServers.dll }
' 0:< API_SUCCESS { Registered an external server: Name(Not Defined); VendorId(ADSK); ServerId(76eff5da-2e71-45f7-b940-cc5716328ba0); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external server: Name(Coefficient from ASHRAE Table); VendorId(ADSK); ServerId(8baf7d75-8b9b-46d0-b8ce-3ad1c19e6b19); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external server: Name(Specific Coefficient); VendorId(ADSK); ServerId(5a598293-1504-46cc-a9c0-de55c82848b9); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external server: Name(Specific Loss); VendorId(ADSK); ServerId(46245996-eebb-4536-ac17-9c1cd917d8cf); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external server: Name(Not Defined); VendorId(ADSK); ServerId(61e7b8e1-16d1-4fe4-82f0-327af736323f); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Registered an external server: Name(K Coefficient from Table); VendorId(ADSK); ServerId(51dd5e98-a9dd-464b-b286-4a37953610bf); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Registered an external server: Name(Specific Coefficient); VendorId(ADSK); ServerId(32d58662-b467-4f7b-b728-f6ad7b7ba5e3); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Registered an external server: Name(Specific Loss); VendorId(ADSK); ServerId(16f4f7be-0ac0-461d-a9a4-1d3511cd280e); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Starting External DB Application: FittingAndAccessoryCalculationServers, Class: FittingAndAccessoryCalculationServers.ServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit 2017\AddIns\MEPCalculation\FittingAndAccessoryCalculationServers.dll }
' 0:< API_SUCCESS { Registered an external server: Name(SteelConnectionsServer); VendorId(ADSK); ServerId(9c209d4a-ec98-460f-bfde-38f17a3443b4); ServiceId(282385f9-9627-4057-8b74-826d019f103c) }
' 0:< API_SUCCESS { Registered an external server: Name(FramingProfileServer); VendorId(ADSK); ServerId(54e490cd-8809-4dbb-84dd-dc0bc6cb1712); ServiceId(b2f816c0-6493-4537-8067-78a4e67f559e) }
' 0:< API_SUCCESS { Starting External DB Application: ExternalResourceDBServer, Class: RvtSteelConnectionsDB.SteelConnectionDBApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit 2017\AddIns\SteelConnections\RvtSteelConnectionsDB.dll }
' 0:< ::0:: Delta VM: Avail -7 -> 134216163 MB, Used +2 -> 260 MB, Peak +3 -> 261 MB; RAM: Avail -12 -> 62325 MB, Used +10 -> 388 MB, Peak +10 -> 388 MB
' 0:< API_SUCCESS { Registering DocumentOpening event by application CollaborateDB (bb3086be-63bb-44bd-99eb-d584c013cf2f). }
' 0:< API_SUCCESS { Registering DocumentSavedAs event by application CollaborateDB (bb3086be-63bb-44bd-99eb-d584c013cf2f). }
' 0:< API_SUCCESS { Registering DocumentOpened event by application CollaborateDB (bb3086be-63bb-44bd-99eb-d584c013cf2f). }
' 0:< API_SUCCESS { Registering DocumentClosing event by application CollaborateDB (bb3086be-63bb-44bd-99eb-d584c013cf2f). }
' 0:< API_SUCCESS { Starting External DB Application: CollaborateDB, Class: Autodesk.Revit.UI.Collaborate.CollaborateDBApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\A360 Collaboration for Revit 2017\CollaborateDB.dll }
' 0:< ::0:: Delta VM: Avail -26 -> 134216137 MB, Used +8 -> 269 MB, Peak +8 -> 270 MB; RAM: Avail -11 -> 62315 MB, Used +12 -> 401 MB, Peak +12 -> 401 MB
' 0:< GUI Resource Usage GDI: Avail 9835, Used 165, User: Used 249108103350
' 0:< API_SUCCESS { Registering ApplicationClosing event by application RaaS (d4f6554b-5d68-4a13-beec-4a0647c34408). }
' 0:< API_SUCCESS { Replacing command id 'ID_PHOTO_RENDER_IN_CLOUD' Executed implementation with implementation from application 'RaaS' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\RaaSForRevit\RaaSApplication.dll'. }
' 0:< API_SUCCESS { API registering command Executed event by application RaaS (d4f6554b-5d68-4a13-beec-4a0647c34408). }
' 0:< API_SUCCESS { Replacing command id 'ID_PHOTO_RENDER_IN_CLOUD' CanExecute implementation with implementation from application 'RaaS' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\RaaSForRevit\RaaSApplication.dll'. }
' 0:< API_SUCCESS { API registering command CanExecute event by application RaaS (d4f6554b-5d68-4a13-beec-4a0647c34408). }
' 0:< API_SUCCESS { Replacing command id 'ID_PHOTO_RENDER_GALLERY' Executed implementation with implementation from application 'RaaS' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\RaaSForRevit\RaaSApplication.dll'. }
' 0:< API_SUCCESS { Replacing command id 'ID_PHOTO_RENDER_GALLERY' CanExecute implementation with implementation from application 'RaaS' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\RaaSForRevit\RaaSApplication.dll'. }
' 0:< API_SUCCESS { Starting External Application: RaaS, Class: Autodesk.RaaS.RevitAddin.EApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: RaaSApplication.dll }
'H 13-Sep-2016 16:02:46.220; 0:<
Jrn.Directive "IdleTimeTaskSymbol" _
, "0.ExternalEvent"
' 0:< API_SUCCESS { Starting External Application: AutoLoad, Class: AutoLoader.AutoLoader, Vendor : ADSK(), Assembly: AutoLoader.dll }
' 0:< API_SUCCESS { Registering ViewActivated event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Registering DocumentClosing event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Registering DocumentClosed event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Registering DocumentChanged event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Registering DockableFrameVisibilityChanged event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
'H 13-Sep-2016 16:02:46.325; 0:<
, "1.OnIdleTask"
' 0:< API_SUCCESS { Registering Idling event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_FABRICATION_SETTINGS' CanExecute implementation with implementation from application 'FabPartBrowserApplication' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\FabricationPartBrowser\FabricationPartBrowser.dll'. }
' 0:< API_SUCCESS { API registering command Fabrication Settings CanExecute event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_FABRICATION_SETTINGS' Executed implementation with implementation from application 'FabPartBrowserApplication' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\FabricationPartBrowser\FabricationPartBrowser.dll'. }
' 0:< API_SUCCESS { API registering command Fabrication Settings Executed event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Replacing command id 'ID_FABRICATION_PART_SHOW_SERVICE_IN_PART_BROWSER' CanExecute implementation with implementation from application 'FabPartBrowserApplication' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\FabricationPartBrowser\FabricationPartBrowser.dll'. }
' 0:< API_SUCCESS { API registering command Show Service in Part Browser
' 0:< API_SUCCESS { Starting External Application: FabPartBrowserApplication, Class: FabricationPartBrowser.FabPartBrowserApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: FabricationPartBrowser.dll }
' 0:< API_SUCCESS { Registered an external server: Name(Duct not defined pressure drop UI server); VendorId(ADSK); ServerId(607992d7-359d-4593-b497-8aa238e2c564); ServiceId(52009bda-c817-4aef-aa31-36dc3742516e) }
' 0:< API_SUCCESS { Registered an external server: Name(Duct specific coefficient pressure drop UI server); VendorId(ADSK); ServerId(9641a039-441e-42e2-93a6-c0e2177cc23c); ServiceId(52009bda-c817-4aef-aa31-36dc3742516e) }
' 0:< API_SUCCESS { Registered an external server: Name(Duct specific loss pressure drop UI server); VendorId(ADSK); ServerId(d3b5e81d-9b8c-40da-8efb-99dd37fda611); ServiceId(52009bda-c817-4aef-aa31-36dc3742516e) }
' 0:< API_SUCCESS { Registered an external server: Name(Duct coefficient from table pressure drop UI server); VendorId(ADSK); ServerId(25fa8de2-67c4-47d1-91f6-bd6f0803a5ed); ServiceId(52009bda-c817-4aef-aa31-36dc3742516e) }
' 0:< API_SUCCESS { Registered an external server: Name(Pipe not defined pressure drop UI server); VendorId(ADSK); ServerId(62917391-e14d-4897-ad0c-05342d71e4f9); ServiceId(1931b323-1d29-4083-b1ce-bfdcddd011af) }
' 0:< API_SUCCESS { Registered an external server: Name(Pipe specific coefficient pressure drop UI server); VendorId(ADSK); ServerId(247265b6-7b71-4147-97c6-cc52b39c12aa); ServiceId(1931b323-1d29-4083-b1ce-bfdcddd011af) }
' 0:< API_SUCCESS { Registered an external server: Name(Pipe specific loss pressure drop UI server); VendorId(ADSK); ServerId(5978b92a-3f0b-4691-bbc8-caf2fae20a71); ServiceId(1931b323-1d29-4083-b1ce-bfdcddd011af) }
' 0:< API_SUCCESS { Registered an external server: Name(Pipe K coefficient from table pressure drop UI server); VendorId(ADSK); ServerId(cda19b6f-fbd5-4725-a0ce-f159bf5d02fe); ServiceId(1931b323-1d29-4083-b1ce-bfdcddd011af) }
' 0:< API_SUCCESS { Starting External Application: FittingAndAccessoryCalculationUIServers, Class: FittingAndAccessoryCalculationUIServers.ServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: FittingAndAccessoryCalculationUIServers.dll }
' 0:< API_SUCCESS { Replacing command id 'ID_EXPORT_IFC' Executed implementation with implementation from application 'IFC override' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\IFCExporterUI\IFCExportUI.dll'. }
' 0:< API_SUCCESS { API registering command Export to IAI IFC (Industry Foundation Classes) file format Executed event by application IFC override (e78da2e3-7e89-464c-97cd-2212c8be3fa8). }
' 0:< API_SUCCESS { Starting External Application: IFC override, Class: BIM.IFC.Export.UI.IFCCommandOverrideApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: IFCExportUI.dll }
' 0:< API_SUCCESS { Starting External Application: Import Shape, Class: ImportShape.ImportShape, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: ImportShape.dll }
' 0:< API_SUCCESS { Registered an external server: Name(Revit Default UI Server.); VendorId(ADSK); ServerId(3ffc688a-bb2e-4145-90ab-9443da02aef6); ServiceId(1fe75ba7-79d4-45f6-8e31-c1b83d4476a9) }
' 0:< API_SUCCESS { Starting External Application: KeynoteUIServer, Class: KeynoteUIServer.ServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: KeynoteUIServer.dll }
' 0:< API_SUCCESS { Registered an external server: Name(Internal Forces Server); VendorId(ADSK); ServerId(a97444aa-af8d-4a1e-af1f-fa7b77b368ee); ServiceId(a97444aa-af8d-4a1e-af1f-fa7b77b368ee) }
' 0:< API_SUCCESS { Starting External Application: Member Forces, Class: MemberForcesUI.ServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: MemberForces.dll }
' 0:< API_SUCCESS { Replacing command id 'ID_NUMBERING_REINF_PARTITIONS' Executed implementation with implementation from application 'Object Numbering' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\ObjectNumbering\ObjectNumberingUI.dll'. }
' 0:< API_SUCCESS { API registering command Executed event by application Object Numbering (32b5860a-aec9-4df7-96b0-07168b27446e). }
' 0:< API_SUCCESS { Replacing command id 'ID_NUMBERING_REINF_PARTITIONS' CanExecute implementation with implementation from application 'Object Numbering' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\ObjectNumbering\ObjectNumberingUI.dll'. }
' 0:< API_SUCCESS { API registering command CanExecute event by application Object Numbering (32b5860a-aec9-4df7-96b0-07168b27446e). }
' 0:< API_SUCCESS { Starting External Application: Object Numbering, Class: BIM.Numbering.UI.NumberingUIApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: ObjectNumberingUI.dll }
' 0:< API_SUCCESS { Registered an external server: Name(PointCloudSnappingServer); VendorId(ADSK); ServerId(85f4b666-8811-4e3d-9ed4-3d2ae4cd2e4c); ServiceId(aaa05780-790c-43dc-bc41-1c2150227f45) }
' 0:< Third Party Updater 'PointCloudSnappingServer: Snapping Pipe Updater' registered for all documents.
' 0:< API_SUCCESS { Starting External Application: PointCloudSnappingServer, Class: PointCloudSnappingServer.Application, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: PointCloudSnappingServer.dll }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_DUCT_PRESSURE_LOSS_REPORT' CanExecute implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { API registering command Duct Pressure Loss Report CanExecute event by application PressureLossReport (b00d3753-d3bc-4255-9c97-e389de87a5d6). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_DUCT_PRESSURE_LOSS_REPORT' Executed implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { API registering command Duct Pressure Loss Report Executed event by application PressureLossReport (b00d3753-d3bc-4255-9c97-e389de87a5d6). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_PIPE_PRESSURE_LOSS_REPORT' CanExecute implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { API registering command Pipe Pressure Loss Report CanExecute event by application PressureLossReport (b00d3753-d3bc-4255-9c97-e389de87a5d6). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_PIPE_PRESSURE_LOSS_REPORT' Executed implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { API registering command Pipe Pressure Loss Report Executed event by application PressureLossReport (b00d3753-d3bc-4255-9c97-e389de87a5d6). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_SELECT_DUCT_PRESSURE_LOSS_REPORT' CanExecute implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_SELECT_DUCT_PRESSURE_LOSS_REPORT' Executed implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_SELECT_PIPE_PRESSURE_LOSS_REPORT' CanExecute implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_SELECT_PIPE_PRESSURE_LOSS_REPORT' Executed implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { Starting External Application: PressureLossReport, Class: PressureLossReport.PressureLossReportApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: PressureLossReport.dll }
' 0:< API_SUCCESS { Registered an external server: Name(SectionTypeParameterServer); VendorId(ADSK); ServerId(1b91ce46-ddb4-44ec-a942-d45efadde353); ServiceId(c42c9b55-c491-4611-97e9-9e617958e13e) }
' 0:< API_SUCCESS { Starting External Application: Structural Section Properties, Class: SectionProperties.ServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: SectionProperties.dll }
' 0:< ::0:: Delta VM: Avail -38 -> 134216100 MB, Used +4 -> 273 MB, Peak +4 -> 274 MB; RAM: Avail -9 -> 62306 MB, Used +8 -> 409 MB, Peak +8 -> 410 MB
' 0:< GUI Resource Usage GDI: Avail 9831, Used 169, User: Used 249108103351
' 0:< API_SUCCESS { Registering DocumentCreated event by application Common (4e6988f3-7c3a-41a6-aa31-511fa8f0f451). }
' 0:< API_SUCCESS { Registering DocumentOpened event by application Common (4e6988f3-7c3a-41a6-aa31-511fa8f0f451). }
' 0:< API_SUCCESS { Registering DocumentSaving event by application Common (4e6988f3-7c3a-41a6-aa31-511fa8f0f451). }
' 0:< API_SUCCESS { Registering DocumentSavingAs event by application Common (4e6988f3-7c3a-41a6-aa31-511fa8f0f451). }
' 0:< API_SUCCESS { Registering DocumentSynchronizedWithCentral event by application Common (4e6988f3-7c3a-41a6-aa31-511fa8f0f451). }
' 0:< API_SUCCESS { Registering DocumentSynchronizingWithCentral event by application Common (4e6988f3-7c3a-41a6-aa31-511fa8f0f451). }
' 0:< API_SUCCESS { Registering DocumentClosing event by application Common (4e6988f3-7c3a-41a6-aa31-511fa8f0f451). }
' 0:< API_SUCCESS { Registering DocumentChanged event by application Common (4e6988f3-7c3a-41a6-aa31-511fa8f0f451). }
' 0:< API_SUCCESS { Registering FileExporting event by application Common (4e6988f3-7c3a-41a6-aa31-511fa8f0f451). }
' 0:< API_SUCCESS { Registering FileExported event by application Common (4e6988f3-7c3a-41a6-aa31-511fa8f0f451). }
' 0:< API_SUCCESS { Registering ViewActivated event by application Common (4e6988f3-7c3a-41a6-aa31-511fa8f0f451). }
' 0:< Third Party Updater 'Common: DrxUpdater' registered for all documents.
' 0:< API_SUCCESS { Starting External Application: Common, Class: Adsk.DrxApplication.DrxCommonApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Areabook\Program\DrxCommon.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6400, name: , text: Calculate Areas, class: Adsk.DrxApplication.DrxAreaCalculationCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Areabook\Program\AreaCalculation.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6401, name: , text: Edit Room, class: Adsk.DrxApplication.DrxRoomEditCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Areabook\Program\AreaCalculation.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6402, name: , text: Add/Edit Floor Area, class: Adsk.DrxApplication.DrxFloorAreaAddCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Areabook\Program\AreaCalculation.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6403, name: , text: Add Room Group, class: Adsk.DrxApplication.DrxRoomGroupAddCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Areabook\Program\AreaCalculation.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6404, name: , text: Edit Room Group, class: Adsk.DrxApplication.DrxRoomGroupEditCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Areabook\Program\AreaCalculation.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6405, name: , text: Calculation Settings, class: Adsk.DrxApplication.DrxAreaCalculationOptionsCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Areabook\Program\AreaCalculation.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6406, name: , text: Edit Room Assignment Type, class: Adsk.DrxApplication.DrxRoomAssignmentsEditCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Areabook\Program\AreaCalculation.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6407, name: , text: Hide/Show Areabook IDs, class: Adsk.DrxApplication.DrxAreaToggleIDsCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Areabook\Program\AreaCalculation.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6408, name: , text: Set language, class: Adsk.DrxApplication.DrxChangeUILanguageCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Areabook\Program\AreaCalculation.dll }
' 0:< API_SUCCESS { Starting External Application: Area Calculation International, Class: Adsk.DrxApplication.DrxAreaCalculationApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Areabook\Program\AreaCalculation.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6409, name: , text: Batch Print, class: Revit.PrintHarness.PrintHarnessAPI, assembly: C:\Program Files\Autodesk\Batch Print for Revit 2017\BatchPrint.dll }
' 0:< API_SUCCESS { Starting External Application: Batch Print Application, Class: Revit.PrintHarness.PrintHarnessApplication, Vendor : ADSK(Autodesk, subscription.autodesk.com), Assembly: C:\Program Files\Autodesk\Batch Print for Revit 2017\BatchPrint.dll }
' 0:< API_SUCCESS { Registering ViewActivated event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Replacing command id 'ID_COLLABORATE' Executed implementation with implementation from application 'Collaborate' dll 'C:\Program Files\Autodesk\A360 Collaboration for Revit 2017\Collaborate.dll'. }
' 0:< API_SUCCESS { API registering command Collaborate Executed event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Replacing command id 'ID_COLLABORATE' CanExecute implementation with implementation from application 'Collaborate' dll 'C:\Program Files\Autodesk\A360 Collaboration for Revit 2017\Collaborate.dll'. }
' 0:< API_SUCCESS { API registering command Collaborate CanExecute event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Replacing command id 'ID_COLLABORATE_360' Executed implementation with implementation from application 'Collaborate' dll 'C:\Program Files\Autodesk\A360 Collaboration for Revit 2017\Collaborate.dll'. }
' 0:< API_SUCCESS { API registering command Executed event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Replacing command id 'ID_COLLABORATE_360' CanExecute implementation with implementation from application 'Collaborate' dll 'C:\Program Files\Autodesk\A360 Collaboration for Revit 2017\Collaborate.dll'. }
' 0:< API_SUCCESS { API registering command CanExecute event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Starting External Application: Collaborate, Class: Autodesk.Revit.UI.Collaborate.CollaborateApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\A360 Collaboration for Revit 2017\Collaborate.dll }
' 0:< API_SUCCESS { Replacing command id 'ID_COLLABORATE_BROWSER' Executed implementation with implementation from application 'CollaborateBrowser' dll 'C:\Program Files\Autodesk\A360 Collaboration for Revit 2017\CollaborateBrowser.dll'. }
' 0:< API_SUCCESS { API registering command A360 Projects Executed event by application CollaborateBrowser (901c7e33-857c-4c9c-846c-8f971c7cf72a). }
' 0:< API_SUCCESS { Replacing command id 'ID_COLLABORATE_BROWSER' CanExecute implementation with implementation from application 'CollaborateBrowser' dll 'C:\Program Files\Autodesk\A360 Collaboration for Revit 2017\CollaborateBrowser.dll'. }
' 0:< API_SUCCESS { API registering command A360 Projects CanExecute event by application CollaborateBrowser (901c7e33-857c-4c9c-846c-8f971c7cf72a). }
' 0:< API_SUCCESS { Starting External Application: CollaborateBrowser, Class: Autodesk.Revit.UI.CollaborateBrowser.CollaborateBrowserApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\A360 Collaboration for Revit 2017\CollaborateBrowser.dll }
'C 13-Sep-2016 16:02:47.415; 0:< Loading bcg.dll: Autodesk.Bcg, Version=1.7.3.0, Culture=neutral, PublicKeyToken=d672471c03b2c408
'C 13-Sep-2016 16:02:47.500; 0:< SkyscraperClientHost: Initialize Success: True
' 0:< API_SUCCESS { Starting External Application: SkyscraperClientHostApplication, Class: SkyscraperClientHost.SkyscraperClientHostApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\A360 Collaboration for Revit 2017\SkyscraperClientHost.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6410, name: , text: Transmit a model, class: eTransmitForRevit.eTransmitCommand, assembly: C:\Program Files\Autodesk\eTransmit for Revit 2017\eTransmitForRevit.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6411, name: , text: Help, class: eTransmitForRevit.eTransmitHelp, assembly: C:\Program Files\Autodesk\eTransmit for Revit 2017\eTransmitForRevit.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6412, name: , text: About, class: eTransmitForRevit.eTransmitAbout, assembly: C:\Program Files\Autodesk\eTransmit for Revit 2017\eTransmitForRevit.dll }
' 0:< API_SUCCESS { Starting External Application: eTransmit for Revit, Class: eTransmitForRevit.eTransmitApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\eTransmit for Revit 2017\eTransmitForRevit.dll }
' 0:< ::0:: Delta VM: Avail -12 -> 134216088 MB, Used +2 -> 275 MB, Peak +1 -> 276 MB; RAM: Avail +0 -> 62307 MB, Used +4 -> 414 MB, Peak +4 -> 414 MB
' 0:< API_SUCCESS { Added pushbutton Id: 6413, name: , text: Check, class: BIMStandardsManager.Command, assembly: C:\Program Files\Autodesk\Revit Model Review 2017\ModelReview.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6414, name: , text: Manage, class: BIMStandardsManager.CommandConfig, assembly: C:\Program Files\Autodesk\Revit Model Review 2017\ModelReview.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6415, name: , text: View, class: BIMStandardsManager.CommandReview, assembly: C:\Program Files\Autodesk\Revit Model Review 2017\ModelReview.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6416, name: , text: About..., class: BIMStandardsManager.CommandAbout, assembly: C:\Program Files\Autodesk\Revit Model Review 2017\ModelReview.dll }
' 0:< ::0:: Delta VM: Avail 134216088 MB, Used 275 MB; RAM: Avail +10 -> 62317 MB, Used -11 -> 403 MB
' 0:< GUI Resource Usage GDI: Avail 9827, Used 173, User: Used 249108103351
' 0:< API_SUCCESS { Starting External Application: Model Review, Class: BIMStandardsManager.ExternalApp, Vendor : ADSK(Autodesk, subscription.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit Model Review 2017\ModelReview.dll }
' 0:< API_SUCCESS { Registering DocumentOpened event by application Model Review Events (1469753f-186d-4dc2-b0e9-431b302e62f9). }
' 0:< API_SUCCESS { Registering DocumentSaving event by application Model Review Events (1469753f-186d-4dc2-b0e9-431b302e62f9). }
' 0:< API_SUCCESS { Registering DocumentSavingAs event by application Model Review Events (1469753f-186d-4dc2-b0e9-431b302e62f9). }
' 0:< API_SUCCESS { Registering DocumentSynchronizingWithCentral event by application Model Review Events (1469753f-186d-4dc2-b0e9-431b302e62f9). }
' 0:< API_ERROR { Starting External Application: Model Review Events, Class: BIMStandardsManager.CommandEventsApp, Vendor : ADSK(Autodesk, subscription.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit Model Review 2017\ModelReview.dll }
' 0:< API_SUCCESS { Registering ApplicationInitialized event by application AREXRevitStart (26a4f622-eb0a-4829-a9c3-9194b77a7fe4). }
' 0:< API_SUCCESS { Starting External Application: AREXRevitStart, Class: REX.AREXRevitStart.AREXRevitStart, Vendor : ADSK(), Assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Products\Revit\AREXRevitStart.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6417, name: , text: Revit DB Link, class: Revit.Addon.RevitDBLink.CS.Command, assembly: C:\Program Files\Autodesk\Revit DB Link 2017\RevitDBLink.dll }
' 0:< API_SUCCESS { Starting External Application: RevitDBLink, Class: Revit.Addon.RevitDBLink.CS.App, Vendor : ADSK(Autodesk, subscription.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit DB Link 2017\RevitDBLink.dll }
' 0:< API_SUCCESS { Registering ApplicationInitialized event by application AREXRevitStart (c0566ed7-4309-4082-b3ba-ea6b7b4d292a). }
' 0:< API_SUCCESS { Registering ApplicationInitialized event by application AREXRevitStart (1aa95c7e-ebf6-4205-b465-993f7efdc2e1). }
' 0:< API_SUCCESS { Added pushbutton Id: 6418, name: , text: Launch SNU, class: SpaceNaming.Command, assembly: C:\Program Files\Autodesk\Space Naming Utility for Revit MEP 2017\SpaceNaming.dll }
' 0:< API_SUCCESS { Starting External Application: Space Naming Utility Application, Class: SpaceNaming.Command, Vendor : ADSK(Autodesk, subscription.autodesk.com), Assembly: C:\Program Files\Autodesk\Space Naming Utility for Revit MEP 2017\SpaceNaming.dll }
' 0:< API_SUCCESS { Registering ApplicationInitialized event by application AREXRevitStart (be4833f0-363a-4442-82f9-fc2805b4220f). }
' 0:< API_SUCCESS { Registering DocumentOpened event by application Worksharing Monitor Application (04e9bc6c-9b81-4c82-a31a-7559fe7a1579). }
' 0:< API_SUCCESS { Registering DocumentClosing event by application Worksharing Monitor Application (04e9bc6c-9b81-4c82-a31a-7559fe7a1579). }
' 0:< API_SUCCESS { Registering DocumentSaved event by application Worksharing Monitor Application (04e9bc6c-9b81-4c82-a31a-7559fe7a1579). }
' 0:< API_SUCCESS { Registering DocumentSavedAs event by application Worksharing Monitor Application (04e9bc6c-9b81-4c82-a31a-7559fe7a1579). }
' 0:< API_SUCCESS { Starting External Application: Worksharing Monitor Application, Class: WorkSharingLib.ExternalApplication, Vendor : ADSK(Autodesk, subscription.autodesk.com), Assembly: C:\Program Files\Autodesk\Worksharing Monitor for Revit 2017\WorkSharingLib.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6419, name: , text: Launch WSM, class: WorksharingCommand.WorksharingCommand, assembly: C:\Program Files\Autodesk\Worksharing Monitor for Revit 2017\WorkSharingCommand.dll }
' 0:< API_SUCCESS { Starting External Application: Worksharing Monitor Launch App, Class: WorksharingCommand.WorksharingApp, Vendor : ADSK(Autodesk, subscription.autodesk.com), Assembly: C:\Program Files\Autodesk\Worksharing Monitor for Revit 2017\WorkSharingCommand.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6420, name: , text: Glue, class: BIM360RevitAddin.GlueItCommand, assembly: C:\ProgramData\Autodesk\Revit\Addins\2017\BIM360Glue\BIM360GlueRevit2017Addin.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6421, name: , text: Clash
'Pinpoint, class: BIM360RevitAddin.GluePinPointCommand, assembly: C:\ProgramData\Autodesk\Revit\Addins\2017\BIM360Glue\BIM360GlueRevit2017Addin.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6422, name: , text: Equipment
'Properties, class: BIM360RevitAddin.EquipmentCommand, assembly: C:\ProgramData\Autodesk\Revit\Addins\2017\BIM360Glue\BIM360GlueRevit2017Addin.dll }
' 0:< ::0:: Delta VM: Avail -26 -> 134216062 MB, Used +12 -> 287 MB, Peak +22 -> 298 MB; RAM: Avail -13 -> 62304 MB, Used +19 -> 423 MB, Peak +17 -> 432 MB
' 0:< GUI Resource Usage GDI: Avail 9819, Used 181, User: Used 249108103359
' 0:< API_SUCCESS { Registering ApplicationInitialized event by application Ribbon (c82755fa-ff61-5113-9a07-27b2127a13e5). }
' 0:< API_SUCCESS { Registering ApplicationClosing event by application Ribbon (c82755fa-ff61-5113-9a07-27b2127a13e5). }
' 0:< API_SUCCESS { Starting External Application: Ribbon, Class: BIM360RevitAddin.HorizontalRibbon, Vendor : BIM360(Autodesk, Inc, www.autodesk.com), Assembly: BIM360Glue/BIM360GlueRevit2017Addin.dll }
' 0:< API_SUCCESS { Registering FailuresProcessing event by application Common (053ba6e7-1d1a-41e4-8529-c7cde73336e8). }
' 0:< API_SUCCESS { Registering DocumentCreated event by application Common (053ba6e7-1d1a-41e4-8529-c7cde73336e8). }
' 0:< API_SUCCESS { Registering DocumentOpened event by application Common (053ba6e7-1d1a-41e4-8529-c7cde73336e8). }
' 0:< API_SUCCESS { Registering DocumentSaving event by application Common (053ba6e7-1d1a-41e4-8529-c7cde73336e8). }
' 0:< API_SUCCESS { Registering DocumentSavingAs event by application Common (053ba6e7-1d1a-41e4-8529-c7cde73336e8). }
' 0:< API_SUCCESS { Registering DocumentSynchronizedWithCentral event by application Common (053ba6e7-1d1a-41e4-8529-c7cde73336e8). }
' 0:< API_SUCCESS { Registering DocumentSynchronizingWithCentral event by application Common (053ba6e7-1d1a-41e4-8529-c7cde73336e8). }
' 0:< API_SUCCESS { Registering DocumentClosing event by application Common (053ba6e7-1d1a-41e4-8529-c7cde73336e8). }
' 0:< API_SUCCESS { Registering DocumentChanged event by application Common (053ba6e7-1d1a-41e4-8529-c7cde73336e8). }
' 0:< API_SUCCESS { Registering DialogBoxShowing event by application Common (053ba6e7-1d1a-41e4-8529-c7cde73336e8). }
' 0:< API_SUCCESS { Registering FileExporting event by application Common (053ba6e7-1d1a-41e4-8529-c7cde73336e8). }
' 0:< API_SUCCESS { Registering FileExported event by application Common (053ba6e7-1d1a-41e4-8529-c7cde73336e8). }
' 0:< API_SUCCESS { Registering ViewActivated event by application Common (053ba6e7-1d1a-41e4-8529-c7cde73336e8). }
' 0:< Third Party Updater 'Common: BrxUpdater' registered for all documents.
' 0:< API_SUCCESS { Starting External Application: Common, Class: Adsk.BrxApplication.BrxCommonApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Buildingbook\Program\BrxCommon.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6423, name: , text: Calculate Building Part Quantities, class: Adsk.BrxApplication.BrxBuildingBookCalculationCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Buildingbook\Program\BuildingBook.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6424, name: , text: Calculation Settings, class: Adsk.BrxApplication.BrxBuildingBookCalcOptCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Buildingbook\Program\BuildingBook.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6425, name: , text: Quantity IDs: Show All, class: Adsk.BrxApplication.BrxShowQIDsCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Buildingbook\Program\BuildingBook.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6426, name: , text: Quantity IDs: Hide All, class: Adsk.BrxApplication.BrxHideQIDsCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Buildingbook\Program\BuildingBook.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6427, name: , text: Material IDs: Show All, class: Adsk.BrxApplication.BrxShowMaterialIDsCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Buildingbook\Program\BuildingBook.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6428, name: , text: Material IDs: Hide All, class: Adsk.BrxApplication.BrxHideMaterialIDsCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Buildingbook\Program\BuildingBook.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6429, name: , text: Hide/Show IDs by Category, class: Adsk.BrxApplication.BrxHideShowByCategoryCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Buildingbook\Program\BuildingBook.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6430, name: , text: Select Building Parts by ID, class: Adsk.BrxApplication.BrxBuildingBookSelectByQIDCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Buildingbook\Program\BuildingBook.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6431, name: , text: Purge discontinued versions data, class: Adsk.BrxApplication.BrxPurgeBPQ2014Cmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Buildingbook\Program\BuildingBook.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6432, name: , text: Set language, class: Adsk.BrxApplication.BrxChangeUILanguageCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Buildingbook\Program\BuildingBook.dll }
' 0:< API_SUCCESS { Starting External Application: BuildingBook International, Class: Adsk.BrxApplication.BrxBuildingBookApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Buildingbook\Program\BuildingBook.dll }
' 0:< ::0:: Delta VM: Avail -11 -> 134216052 MB, Used -2 -> 286 MB; RAM: Avail -1 -> 62303 MB, Used 423 MB
' 0:< API_SUCCESS { Registering ApplicationInitialized event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Registering DocumentOpened event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Registering DocumentCreated event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Registering DocumentSavedAs event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Registering DocumentSaved event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Registering DocumentClosed event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Registering ApplicationClosing event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Replacing command id 'ID_TEAM' Executed implementation with implementation from application 'Communicator for Autodesk Revit' dll 'C:\ProgramData\Autodesk\Revit\Addins\2017\Communicator\SmartMonkey.dll'. }
' 0:< API_SUCCESS { API registering command Communicator Executed event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Replacing command id 'ID_TEAM' CanExecute implementation with implementation from application 'Communicator for Autodesk Revit' dll 'C:\ProgramData\Autodesk\Revit\Addins\2017\Communicator\SmartMonkey.dll'. }
' 0:< API_SUCCESS { API registering command Communicator CanExecute event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Starting External Application: Communicator for Autodesk Revit, Class: Autodesk.Revit.SmartMonkeyPlugin.SmartMonkeyApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: Communicator\SmartMonkey.dll }
' 0:< API_SUCCESS { Registering Idling event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Registering ViewActivated event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Registering ViewActivating event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Registering DocumentClosing event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Registering DocumentClosed event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Registering DocumentOpened event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Replacing command id 'ID_VISUAL_PROGRAMMING_DYNAMO' CanExecute implementation with implementation from application 'Dynamo For Revit' dll 'C:\Program Files\Dynamo 0.9\Revit_2017\DynamoRevitVersionSelector.dll'. }
' 0:< API_SUCCESS { API registering command Launch Dynamo
'Dynamo CanExecute event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
'Dynamo BeforeExecuted event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Replacing command id 'ID_VISUAL_PROGRAMMING_DYNAMO' Executed implementation with implementation from application 'Dynamo For Revit' dll 'C:\Program Files\Dynamo 0.9\Revit_2017\DynamoRevitVersionSelector.dll'. }
'Dynamo Executed event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< Third Party Updater 'Dynamo For Revit: Sun and Shadow Settings Updater' registered for all documents.
' 0:< API_SUCCESS { Registering DocumentChanged event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Starting External Application: Dynamo For Revit, Class: Dynamo.Applications.VersionLoader, Vendor : ADSK(Dynamo), Assembly: C:\Program Files\Dynamo 0.9\Revit_2017\DynamoRevitVersionSelector.dll }
' 0:< API_SUCCESS { Replacing command id 'ID_VIEWS_FOR_A360' Executed implementation with implementation from application 'Views For A360' dll 'C:\ProgramData\Autodesk\Revit\Addins\2017\.\ExportViewSelectorAddin\ExportViewSelectorAddin.dll'. }
' 0:< API_SUCCESS { API registering command Views For A360 Executed event by application Views For A360 (78bd1446-1817-4842-8075-591b0424acaa). }
' 0:< API_SUCCESS { Replacing command id 'ID_VIEWS_FOR_A360' CanExecute implementation with implementation from application 'Views For A360' dll 'C:\ProgramData\Autodesk\Revit\Addins\2017\.\ExportViewSelectorAddin\ExportViewSelectorAddin.dll'. }
' 0:< API_SUCCESS { API registering command Views For A360 CanExecute event by application Views For A360 (78bd1446-1817-4842-8075-591b0424acaa). }
' 0:< API_SUCCESS { Starting External Application: Views For A360, Class: Autodesk.Revit.Addin.ExportViewSelector.ExportViewSelectorApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: .\ExportViewSelectorAddin\ExportViewSelectorAddin.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6433, name: , text: Convert RFA
'to FormIt 360, class: RFAToAXMAddon.RFAToAXMCommand, assembly: C:\Program Files\Autodesk\FormIt 360 Converter For Revit 2017\FormIt360ConversionAddon\RFAToAXMAddon.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6434, name: , text: Convert SKP
'to FormIt 360, class: RFAToAXMAddon.SketchUpToAXMCommand, assembly: C:\Program Files\Autodesk\FormIt 360 Converter For Revit 2017\FormIt360ConversionAddon\RFAToAXMAddon.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6435, name: , text: Import FormIt 360
'to RVT, class: AXMImportorAddon.AXMImportorCommand, assembly: C:\Program Files\Autodesk\FormIt 360 Converter For Revit 2017\FormIt360ConversionAddon\AXMImportorAddon.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6436, name: , text: Reload Families, class: AXMImportorAddon.ReloadFamiliesCommand, assembly: C:\Program Files\Autodesk\FormIt 360 Converter For Revit 2017\FormIt360ConversionAddon\AXMImportorAddon.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6437, name: , text: About FormIt 360, class: FormItConverter.FormIt360Link, assembly: C:\Program Files\Autodesk\FormIt 360 Converter For Revit 2017\FormIt360ConversionAddon\FormItConverterRibbon.dll }
' 0:< API_SUCCESS { Starting External Application: FormIt Conversion, Class: FormItConverter.Ribbon, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\FormIt 360 Converter For Revit 2017\FormIt360ConversionAddon\FormItConverterRibbon.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6438, name: , text: Import Autodesk Fabrication Job File, class: MEPFabricationOpenJob.ImportJobCommand, assembly: C:\Program Files\Autodesk\Fabrication 2017\Revit Extension for Fabrication\MEPFabricationOpenJob.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6439, name: , text: Export Autodesk Fabrication Job File, class: MEPFabricationOpenJob.ExportJobCommand, assembly: C:\Program Files\Autodesk\Fabrication 2017\Revit Extension for Fabrication\MEPFabricationOpenJob.dll }
' 0:< API_SUCCESS { Starting External Application: Revit Extension for Fabrication, Class: MEPFabricationOpenJob.Application, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Fabrication 2017\Revit Extension for Fabrication\MEPFabricationOpenJob.dll }
' 0:< API_SUCCESS { Registering DocumentCreated event by application Common (3a77a84e-3f0d-4f84-be7f-a7ecc7f3f708). }
' 0:< API_SUCCESS { Registering DocumentOpened event by application Common (3a77a84e-3f0d-4f84-be7f-a7ecc7f3f708). }
' 0:< API_SUCCESS { Registering DocumentSaving event by application Common (3a77a84e-3f0d-4f84-be7f-a7ecc7f3f708). }
' 0:< API_SUCCESS { Registering DocumentSavingAs event by application Common (3a77a84e-3f0d-4f84-be7f-a7ecc7f3f708). }
' 0:< API_SUCCESS { Registering DocumentSynchronizedWithCentral event by application Common (3a77a84e-3f0d-4f84-be7f-a7ecc7f3f708). }
' 0:< API_SUCCESS { Registering DocumentSynchronizingWithCentral event by application Common (3a77a84e-3f0d-4f84-be7f-a7ecc7f3f708). }
' 0:< API_SUCCESS { Registering DocumentClosing event by application Common (3a77a84e-3f0d-4f84-be7f-a7ecc7f3f708). }
' 0:< API_SUCCESS { Registering DocumentChanged event by application Common (3a77a84e-3f0d-4f84-be7f-a7ecc7f3f708). }
' 0:< API_SUCCESS { Registering DialogBoxShowing event by application Common (3a77a84e-3f0d-4f84-be7f-a7ecc7f3f708). }
' 0:< API_SUCCESS { Registering FileExporting event by application Common (3a77a84e-3f0d-4f84-be7f-a7ecc7f3f708). }
' 0:< API_SUCCESS { Registering FileExported event by application Common (3a77a84e-3f0d-4f84-be7f-a7ecc7f3f708). }
' 0:< API_SUCCESS { Registering ViewActivated event by application Common (3a77a84e-3f0d-4f84-be7f-a7ecc7f3f708). }
' 0:< Third Party Updater 'Common: RrxUpdater' registered for all documents.
' 0:< API_SUCCESS { Starting External Application: Common, Class: Adsk.RrxApplication.RrxCommonApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Roombook\Program\RrxCommon.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6440, name: , text: Calculate Room Quantities, class: Adsk.RrxApplication.RrxCalculationStyleCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Roombook\Program\RoomBookInternational.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6441, name: , text: Calculation Settings, class: Adsk.RrxApplication.RrxCalculationOptionsCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Roombook\Program\RoomBookInternational.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6442, name: , text: Apply Surface Materials to Rooms, class: Adsk.RrxApplication.RrxApplyMaterialStyleCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Roombook\Program\RoomBookInternational.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6443, name: , text: Edit Surface Materials, class: Adsk.RrxApplication.RrxMaterialStyleCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Roombook\Program\RoomBookInternational.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6444, name: , text: Hide/Show Quantity IDs, class: Adsk.RrxApplication.RrxCalculationToggleQIDCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Roombook\Program\RoomBookInternational.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6445, name: , text: Hide/Show Finish IDs, class: Adsk.RrxApplication.RrxCalculationToggleFinishSymCmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Roombook\Program\RoomBookInternational.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6446, name: , text: Set language, class: Adsk.RrxApplication.RrxChangeUILanguageRBICmd, assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Roombook\Program\RoomBookInternational.dll }
' 0:< API_SUCCESS { Starting External Application: RoomBook International, Class: Adsk.RrxApplication.RrxRoomBookInternationalApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Roombook Areabook Buildingbook for Revit 2017\Roombook\Program\RoomBookInternational.dll }
' 0:< API_SUCCESS { Registering DocumentClosed event by application External Tool (e0a2d7a5-030b-4d4e-8689-8406903ea241). }
' 0:< API_SUCCESS { Registering DocumentCreating event by application External Tool (e0a2d7a5-030b-4d4e-8689-8406903ea241). }
' 0:< API_SUCCESS { Registering DocumentClosing event by application External Tool (e0a2d7a5-030b-4d4e-8689-8406903ea241). }
' 0:< API_SUCCESS { Registering DocumentSaving event by application External Tool (e0a2d7a5-030b-4d4e-8689-8406903ea241). }
' 0:< API_SUCCESS { Registering DocumentSavingAs event by application External Tool (e0a2d7a5-030b-4d4e-8689-8406903ea241). }
' 0:< API_SUCCESS { Registering DocumentChanged event by application External Tool (e0a2d7a5-030b-4d4e-8689-8406903ea241). }
' 0:< API_SUCCESS { Registering ViewActivating event by application External Tool (e0a2d7a5-030b-4d4e-8689-8406903ea241). }
' 0:< API_SUCCESS { Registered an external server: Name(ModifyConnectionParametersServer); VendorId(ADSK); ServerId(d81402f0-e558-4434-89a8-30ec1f52a4d0); ServiceId(e9c0f948-320e-4e7f-a573-10755555305d) }
' 0:< API_SUCCESS { Registered an external server: Name(ConnectionTypeChangedServer); VendorId(ADSK); ServerId(43229eb0-f06b-49a9-b404-ff52ae5842ad); ServiceId(e31c3100-9cab-4303-b85b-4171703ce1c4) }
' 0:< API_SUCCESS { Starting External Application: External Tool, Class: RvtSteelConnectionsUI.SteelConnection, Vendor : Autodesk(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Steel Connections for Revit\RvtSteelConnectionsUI.dll }
' 0:< ::0:: Delta VM: Avail -12 -> 134216041 MB, Used +4 -> 290 MB; RAM: Avail -4 -> 62299 MB, Used +3 -> 427 MB
' 0:< GUI Resource Usage GDI: Avail 9816, Used 184, User: Used 249108103360
'C 13-Sep-2016 16:02:50.025; 0:< ->processShellCommand
'E 13-Sep-2016 16:02:50.026; 0:<
Jrn.Command "Internal" , "Show or hide recent files , ID_STARTUP_PAGE"
' 0:< ::1:: Delta VM: Avail -99 -> 134215943 MB, Used +10 -> 301 MB, Peak +2 -> 301 MB; RAM: Avail -11 -> 62289 MB, Used +11 -> 439 MB, Peak +7 -> 439 MB
' 0:< GUI Resource Usage GDI: Avail 9809, Used 191, User: Used 249108103370
'C 13-Sep-2016 16:02:50.233; 0:< <-processShellCommand
'C 13-Sep-2016 16:02:50.234; 0:< ->DesktopMFCApp::doStartupWarnings
'C 13-Sep-2016 16:02:50.234; 0:< License readyForUI
'C 13-Sep-2016 16:02:50.292; 0:< manage involvement
' 0:< ::1:: Delta VM: Avail -11 -> 134215932 MB, Used +1 -> 302 MB, Peak +1 -> 303 MB; RAM: Avail -4 -> 62286 MB, Used +3 -> 442 MB, Peak +3 -> 442 MB
' 0:< GUI Resource Usage GDI: Avail 9809, Used 191, User: Used 249108103369
'C 13-Sep-2016 16:02:50.386; 0:< manage debug modes
'C 13-Sep-2016 16:02:50.387; 0:< MFCApp::testGraphicsHardware
' 0:< Revit Graphics Information
' 0:< Current Mode : DirectX Hardware
' 0:< Use Hardware: ON
' 0:< Use Overlays : ON
' 0:< START CanUseHardware(forced)
' 1:<
'OGS Device Memory Size: 34704 MB
' 1:< ::1:: Delta VM: Avail -32889 -> 134183044 MB, Used +63 -> 366 MB, Peak +65 -> 368 MB; RAM: Avail -16 -> 62270 MB, Used +22 -> 465 MB, Peak +23 -> 466 MB
' 1:< GUI Resource Usage GDI: Avail 9808, Used 192, User: Used 249108103382
' 1:< DX Device: DirectX 11, Hardware
' 1:< DX Device: DirectX 11, WARP
'C 13-Sep-2016 16:02:50.720; 1:< START video card certification
' 1:<
'Current driver version: \Windows\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_90f801d8702dbf86\nvd3dumx,C:\Windows\System32\DriverStore\Fi:21.21.13.6926
'Certified driver(s): 9.18.13.3182
' 1:< VIDEO CARD ENVIRONMENT: CARD="NVIDIA Quadro K2000" ManufacturerID="10DE" DeviceID="0FFE" osID="8000" DRIVER="\Windows\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_90f801d8702dbf86\nvd3dumx,C:\Windows\System32\DriverStore\Fi:21.21.13.6926" DEVICE="DX11" FL_Caps="50" (Shader Model)
'C 13-Sep-2016 16:02:50.743; 1:< FINISH video card certification
' 0.357230 1:<<' 0:<
'Can use hardware=y
'Hardware support flags:
'FeatureLevelLow=n
'DrvOlderThanTested=y
'DrvNewerThanTested=n
'CardIsNotListed=n
'NotCertifiedEnv=n
'3GBSwitchIsOn=n
'SoftwareModeForced=n
' 0:< FINISH CanUseHardware(forced)
'C 13-Sep-2016 16:02:50.744; 0:< MFCApp::testMSAA
'C 13-Sep-2016 16:02:50.744; 0:< postConditionalWarnings
'C 13-Sep-2016 16:02:50.744; 0:< giveAtomRegistrationWarnings
'C 13-Sep-2016 16:02:50.744; 0:< warnings->consumeAll
'C 13-Sep-2016 16:02:50.745; 0:< Process result of DebugModes-Changed Task Dialog
'C 13-Sep-2016 16:02:50.745; 0:< isMaterialLibraryAvailable
'C 13-Sep-2016 16:02:50.745; 0:< start up warnings for AddIns
'C 13-Sep-2016 16:02:50.745; 0:< <-DesktopMFCApp::doStartupWarnings
' 0:< DBG_INFO: Resetting WPF rendering mode back to Revit default in Desktop Open Notification!: line 269 of RibbonAPI.cpp.
' 0:< Setting WPF rendering mode to SoftwareOnly
'C 13-Sep-2016 16:02:50.747; 0:< <-desktop InitNativeInstance
'C 13-Sep-2016 16:02:50.747; 0:< ->desktop InitManagedInstance
' 1:< ::1:: Delta VM: Avail -14 -> 134183031 MB, Used +3 -> 369 MB, Peak +3 -> 371 MB; RAM: Avail -18 -> 62253 MB, Used +10 -> 475 MB, Peak +10 -> 476 MB
' 1:< GUI Resource Usage GDI: Avail 9658, Used 342, User: Used 249108103383
' 1:< API_SUCCESS { Added pushbutton Id: 6447, name: , text: Modify, class: REX.AREXRevitMngr.Modifier, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Products\Revit\AREXRevitMngr.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6448, name: , text: Delete, class: REX.AREXRevitMngr.Remover, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Products\Revit\AREXRevitMngr.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6449, name: , text: Preferences, class: REX.AREXRevitMngr.Preferences, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Products\Revit\AREXRevitMngr.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6450, name: , text: Frame Generator, class: REX.DLTFrame3D.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Modeling\DLTFrame3D\DLTFrame3D.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6451, name: , text: Grids Generator, class: REX.DRevitGridGenerator.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Modeling\DRevitGridGenerator\DRevitGridGenerator.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6452, name: , text: Rafter Framing, class: REX.DRafterFraming.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Modeling\DRafterFraming\DRafterFraming.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6453, name: , text: Roof Trusses, class: REX.DRoofTrusses.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Modeling\DRoofTrusses\DRoofTrusses.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6454, name: , text: Wood Framing Walls, class: REX.ATimberFraming.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Modeling\ATimberFraming\ATimberFraming.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6455, name: , text: Automatic Reinforcement Generation, class: REX.DReinfAuto.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Reinforcement\DReinfAuto\DReinfAuto.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6456, name: , text: Beams, class: REX.DReinfBeam.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Reinforcement\DReinfBeam\DReinfBeam.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6457, name: , text: Columns, class: REX.DReinfColumn.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Reinforcement\DReinfColumn\DReinfColumn.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6458, name: , text: Continuous Footings, class: REX.DReinfFootingCont.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Reinforcement\DReinfFootingCont\DReinfFootingCont.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6459, name: , text: Interferences of Reinforcing Bars, class: REX.DReinfRebarCollisions.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Reinforcement\DReinfRebarCollisions\DReinfRebarCollisions.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6460, name: , text: Parapets, class: REX.DReinfParapet.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Reinforcement\DReinfParapet\DReinfParapet.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6461, name: , text: Pile Caps, class: REX.DReinfPileCap.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Reinforcement\DReinfPileCap\DReinfPileCap.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6462, name: , text: Piles, class: REX.DReinfPile.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Reinforcement\DReinfPile\DReinfPile.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6463, name: , text: Retaining Walls, class: REX.DReinfRetainingWall.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Reinforcement\DReinfRetainingWall\DReinfRetainingWall.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6464, name: , text: Slab Corners, class: REX.DReinfSlabCorner.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Reinforcement\DReinfSlabCorner\DReinfSlabCorner.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6465, name: , text: Slab Openings, class: REX.DReinfSlabOpening.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Reinforcement\DReinfSlabOpening\DReinfSlabOpening.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6466, name: , text: Spread Footings, class: REX.DReinfFootingSpread.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Reinforcement\DReinfFootingSpread\DReinfFootingSpread.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6467, name: , text: Wall Corners, class: REX.DReinfWallCorner.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Reinforcement\DReinfWallCorner\DReinfWallCorner.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6468, name: , text: Walls, class: REX.DReinfWall.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Reinforcement\DReinfWall\DReinfWall.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6469, name: , text: Compare Models, class: REX.DRevitModelsCompare.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Tools\DRevitModelsCompare\DRevitModelsCompare.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6470, name: , text: Element Positioning, class: REX.DElementsPositioning.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Tools\DElementsPositioning\DElementsPositioning.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6471, name: , text: Bridge - Concrete box girder, class: REX.DBridgesBoxGirder.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Bridges\DBridgesBoxGirder\DBridgesBoxGirder.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6472, name: , text: Bridge - Concrete slab, class: REX.DBridgesConcreteSlab.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Bridges\DBridgesConcreteSlab\DBridgesConcreteSlab.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6473, name: , text: Bridge - Concrete slab with girders, class: REX.DBridgesBeamsGirder.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Bridges\DBridgesBeamsGirder\DBridgesBeamsGirder.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6474, name: , text: Customization of bridge families, class: REX.DBridgesXml.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Bridges\DBridgesXml\DBridgesXml.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6475, name: , text: Documentation, class: REX.DBridgesDocumentation.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Bridges\DBridgesDocumentation\DBridgesDocumentation.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6476, name: , text: Export Revit Elements to AutoCAD Civil 3D, class: REX.DBridge.ExportSolids.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Bridges\DBridge.ExportSolids\DBridge.ExportSolids.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6477, name: , text: Integration with AutoCAD Civil3D, class: REX.DBridgeCivil3DConnector.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Bridges\DBridgeCivil3DConnector\DBridgeCivil3DConnectorx64.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6478, name: , text: Roads and Terrain, class: REX.DBridgeRoad.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2017\Modules\Bridges\DBridgeRoad\DBridgeRoad.dll }
' 1:< ::1:: Delta VM: Avail -12 -> 134183019 MB, Used +1 -> 370 MB; RAM: Avail -4 -> 62250 MB, Used +2 -> 478 MB, Peak +1 -> 478 MB
' 1:< GUI Resource Usage GDI: Avail 9650, Used 350, User: Used 249108103383
' 1:< Third Party Updater 'AREXRevitStart: REXExtension: DReinfBeam' registered for all documents.
' 1:< Third Party Updater 'AREXRevitStart: REXExtension: DReinfColumn' registered for all documents.
' 1:< Third Party Updater 'AREXRevitStart: REXExtension: DReinfFootingSpread' registered for all documents.
' 1:< Third Party Updater 'AREXRevitStart: REXExtension: DReinfWall' registered for all documents.
' 1:< API_SUCCESS { Registering DocumentOpened event by application AREXRevitStart (c0566ed7-4309-4082-b3ba-ea6b7b4d292a). }
' 1:< API_SUCCESS { Registering DocumentCreated event by application AREXRevitStart (c0566ed7-4309-4082-b3ba-ea6b7b4d292a). }
' 1:< API_SUCCESS { Registering DisplayingOptionsDialog event by application AREXRevitStart (c0566ed7-4309-4082-b3ba-ea6b7b4d292a). }
' 1:< API_SUCCESS { Registering ViewActivated event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 1:< API_SUCCESS { Registering DocumentSynchronizingWithCentral event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 1:< API_SUCCESS { Registering DocumentSynchronizedWithCentral event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
'C 13-Sep-2016 16:02:53.521; 0:< <-desktop InitManagedInstance
' 0:< ::1:: Delta VM: Avail -56 -> 134182964 MB, Used +8 -> 379 MB, Peak +8 -> 380 MB; RAM: Avail -33 -> 62217 MB, Used +22 -> 501 MB, Peak +23 -> 502 MB
' 0:< GUI Resource Usage GDI: Avail 9623, Used 377, User: Used 249108103388
'C 13-Sep-2016 16:02:53.824; 0:< appPriv idle
' 0:< OPERATING SYSTEM INFORMATION:
' 0:< BuildNumber : 14393
' 0:< BuildType : Multiprocessor Free
' 0:< Caption : Microsoft Windows 10 Pro
' 0:< CodeSet : 1252
' 0:< CountryCode : 1
' 0:< FreePhysicalMemory : 63706804
' 0:< FreeSpaceInPagingFiles : 9961472
' 0:< FreeVirtualMemory : 73081704
' 0:< MaxProcessMemorySize : 137438953344
' 0:< OSLanguage : 1033
' 0:< OSType : 18
' 0:< ServicePackMajorVersion : 0
' 0:< ServicePackMinorVersion : 0
' 0:< TotalVirtualMemorySize : 76904144
' 0:< TotalVisibleMemorySize : 66942672
' 0:< Version : 10.0.14393
' 0:< Process affinity mask : FFF
' 0:< System affinity mask : FFF
' 0:< PROCESSOR INFORMATION:
' 0:< AddressWidth : 64
' 0:< Architecture : 9
' 0:< Availability : 3
' 0:< Caption : Intel64 Family 6 Model 79 Stepping 1
' 0:< CurrentClockSpeed : 3401
' 0:< DataWidth : 64
' 0:< Description : Intel64 Family 6 Model 79 Stepping 1
' 0:< Family : 179
' 0:< L2CacheSize : 1536
' 0:< Level : 6
' 0:< Manufacturer : GenuineIntel
' 0:< MaxClockSpeed : 3401
' 0:< Name : Intel(R) Core(TM) i7-6800K CPU @ 3.40GHz
' 0:< ProcessorType : 3
' 0:< Revision : 20225
' 0:< Role : CPU
' 0:< SocketDesignation : SOCKET 0
' 0:< StatusInfo : 3
' 0:< Version :
' 0:< VIDEO CONTROLLER INFORMATION:
' 0:< AdapterCompatibility : NVIDIA
' 0:< AdapterDACType : Integrated RAMDAC
' 0:< AdapterRAM : -2147483648
' 0:< Caption : NVIDIA Quadro K2000
' 0:< CurrentBitsPerPixel : 32
' 0:< CurrentHorizontalResolution : 1280
' 0:< CurrentNumberOfColors : 4294967296
' 0:< CurrentRefreshRate : 60
' 0:< CurrentVerticalResolution : 1024
' 0:< Description : NVIDIA Quadro K2000
' 0:< DriverDate : 20160830000000.000000-000
' 0:< DriverVersion : 21.21.13.6926
' 0:< MaxRefreshRate : 75
' 0:< MinRefreshRate : 56
' 0:< Monochrome : 0
' 0:< Name : NVIDIA Quadro K2000
' 0:< VideoArchitecture : 5
' 0:< VideoMemoryType : 2
' 0:< VideoModeDescription : 1280 x 1024 x 4294967296 colors
' 0:< VideoProcessor : Quadro K2000
' 0:< ::1:: Delta VM: Avail -6 -> 134182959 MB, Used +1 -> 380 MB, Peak +1 -> 381 MB; RAM: Avail -11 -> 62207 MB, Used +4 -> 505 MB, Peak +3 -> 505 MB
' 0:< GUI Resource Usage GDI: Avail 9614, Used 386, User: Used 249108103396
' 0:< PRINTER INFORMATION:
' 0:< Caption : Send To OneNote 2016
' 0:< Default : 0
' 0:< DeviceID : Send To OneNote 2016
' 0:< Direct : 0
' 0:< DriverName : Send to Microsoft OneNote 16 Driver
' 0:< EnableBIDI : 0
' 0:< EnableDevQueryPrint : 0
' 0:< HorizontalResolution : 600
' 0:< Local : -1
' 0:< Name : Send To OneNote 2016
' 0:< Network : 0
' 0:< PortName : nul:
' 0:< PrintJobDataType : RAW
' 0:< PrintProcessor : winprint
' 0:< RawOnly : 0
' 0:< Shared : 0
' 0:< SpoolEnabled : -1
' 0:< VerticalResolution : 600
' 0:< Caption : PDFCreator
' 0:< Default : -1
' 0:< DeviceID : PDFCreator
' 0:< Direct : 0
' 0:< DriverName : PDFCreator
' 0:< Local : -1
' 0:< Name : PDFCreator
' 0:< Network : 0
' 0:< PortName : pdfcmon
' 0:< RawOnly : 0
' 0:< Shared : 0
' 0:< Caption : Microsoft XPS Document Writer
' 0:< Default : 0
' 0:< DeviceID : Microsoft XPS Document Writer
' 0:< Direct : 0
' 0:< DriverName : Microsoft XPS Document Writer v4
' 0:< Local : -1
' 0:< Name : Microsoft XPS Document Writer
' 0:< Network : 0
' 0:< PortName : PORTPROMPT:
' 0:< RawOnly : 0
' 0:< Shared : 0
' 0:< Caption : Microsoft Print to PDF
' 0:< Default : 0
' 0:< DeviceID : Microsoft Print to PDF
' 0:< Direct : 0
' 0:< DriverName : Microsoft Print To PDF
' 0:< Local : -1
' 0:< Name : Microsoft Print to PDF
' 0:< Network : 0
' 0:< RawOnly : 0
' 0:< Shared : 0
' 0:< Caption : Fax
' 0:< Default : 0
' 0:< DeviceID : Fax
' 0:< Direct : 0
' 0:< DriverName : Microsoft Shared Fax Driver
' 0:< HorizontalResolution : 200
' 0:< Local : -1
' 0:< Name : Fax
' 0:< Network : 0
' 0:< PortName : SHRFAX:
' 0:< RawOnly : 0
' 0:< Shared : 0
' 0:< VerticalResolution : 200
' 0:< PRINTER CONFIGURATION INFORMATION:
' 0:< Color : 2
' 0:< Copies : 1
' 0:< Description : Send To OneNote 2016
' 0:< DriverVersion : 1539
' 0:< Orientation : 1
' 0:< PaperLength : 2794
' 0:< PaperSize : Letter 8 1/2 x 11 in
' 0:< PaperWidth : 2159
' 0:< PrintQuality : 600
' 0:< SpecificationVersion : 1025
' 0:< XResolution : 600
' 0:< YResolution : 600
' 0:< Color : 2
' 0:< Copies : 1
' 0:< Description : PDFCreator
' 0:< Color : 2
' 0:< Copies : 1
' 0:< Description : Microsoft XPS Document Writer
' 0:< Color : 2
' 0:< Copies : 1
' 0:< Description : Microsoft Print to PDF
' 0:< Color : 1
' 0:< Description : Fax
' 0:< DriverVersion : 1024
' 0:< Duplex : 0
' 0:< PrintQuality : 200
' 0:< XResolution : 200
' 0:< YResolution : 200
' 0:< ::1:: Delta VM: Avail +7 -> 134182967 MB, Used -4 -> 376 MB, Peak +0 -> 382 MB; RAM: Avail -13 -> 62195 MB, Used +1 -> 507 MB, Peak +2 -> 508 MB
' 0:< GUI Resource Usage GDI: Avail 9619, Used 381, User: Used 249108103397
'E 13-Sep-2016 16:03:06.795; 0:<
Jrn.AppButtonEvent 1 , "Application Menu is opening"
'E 13-Sep-2016 16:03:08.284; 0:<
Jrn.AppButtonEvent 0 , "Application Menu is closing"
'E 13-Sep-2016 16:03:08.317; 0:<
Jrn.Command "Ribbon" , "Quit the application; prompts to save projects , ID_APP_EXIT"
' 1:< ::4:: Delta VM: Avail +43 -> 134183011 MB, Used -6 -> 371 MB; RAM: Avail +118 -> 62313 MB, Used -8 -> 499 MB, Peak +2 -> 511 MB
' 1:< GUI Resource Usage GDI: Avail 9683, Used 317, User: Used 249108103300
' 1:< Revit worker 1 closed cleanly
' 0:< [00001aa8]QueueMinder stopped
'C 13-Sep-2016 16:03:08.774; 1:< logging finished virtualization services
'C 13-Sep-2016 16:03:08.774; 1:< logging finished worker services
'C 13-Sep-2016 16:03:08.774; 1:< logging erased queues
' 0.296081 1:<<
'C 13-Sep-2016 16:03:08.774; 0:< ->desktop ExitManagedInstance
'C 13-Sep-2016 16:03:08.797; 0:< <-desktop ExitManagedInstance
'C 13-Sep-2016 16:03:08.797; 0:< ->desktop ExitNativeInstance
' 0:< API_SUCCESS { Unregistering ViewActivated event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Unregistering DocumentClosing event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Unregistering DocumentClosed event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Unregistering DocumentChanged event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Unregistering DockableFrameVisibilityChanged event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Unregistering Idling event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Registering FabricationPartBrowserChanged event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Restoring command id 'ID_MEP_FABRICATION_SETTINGS' CanExecute implementation. }
' 0:< API_SUCCESS { API unregistering command Fabrication Settings CanExecute event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Restoring command id 'ID_MEP_FABRICATION_SETTINGS' Executed implementation. }
' 0:< API_SUCCESS { API unregistering command Fabrication Settings Executed event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Restoring command id 'ID_FABRICATION_PART_SHOW_SERVICE_IN_PART_BROWSER' CanExecute implementation. }
' 0:< API_SUCCESS { API unregistering command Show Service in Part Browser
'Show Service in Part Browser
'Show Service in Part Browser CanExecute event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Restoring command id 'ID_EXPORT_IFC' Executed implementation. }
' 0:< API_SUCCESS { API unregistering command Export to IAI IFC (Industry Foundation Classes) file format Executed event by application IFC override (e78da2e3-7e89-464c-97cd-2212c8be3fa8). }
' 0:< Third Party Updater 'Common: DrxUpdater' has been unregistered.
' 0:< API_SUCCESS { Unregistering ViewActivated event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Unregistering ApplicationClosing event by application Ribbon (c82755fa-ff61-5113-9a07-27b2127a13e5). }
' 0:< Third Party Updater 'Common: BrxUpdater' has been unregistered.
' 0:< API_SUCCESS { Restoring command id 'ID_TEAM' Executed implementation. }
' 0:< API_SUCCESS { API unregistering command Communicator Executed event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Restoring command id 'ID_TEAM' CanExecute implementation. }
' 0:< API_SUCCESS { API unregistering command Communicator CanExecute event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Unregistering DocumentOpened event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Unregistering DocumentCreated event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Unregistering DocumentSavedAs event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Unregistering DocumentSaved event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Unregistering ApplicationClosing event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Unregistering DocumentSynchronizingWithCentral event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Unregistering DocumentSynchronizedWithCentral event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< Third Party Updater 'Common: RrxUpdater' has been unregistered.
' 0:< API_SUCCESS { Unregistering DocumentClosed event by application External Tool (e0a2d7a5-030b-4d4e-8689-8406903ea241). }
' 0:< API_SUCCESS { Unregistering DocumentCreating event by application External Tool (e0a2d7a5-030b-4d4e-8689-8406903ea241). }
' 0:< API_SUCCESS { Unregistering DocumentClosing event by application External Tool (e0a2d7a5-030b-4d4e-8689-8406903ea241). }
' 0:< API_SUCCESS { Unregistering DocumentSaving event by application External Tool (e0a2d7a5-030b-4d4e-8689-8406903ea241). }
' 0:< API_SUCCESS { Unregistering DocumentSavingAs event by application External Tool (e0a2d7a5-030b-4d4e-8689-8406903ea241). }
' 0:< API_SUCCESS { Unregistering DocumentChanged event by application External Tool (e0a2d7a5-030b-4d4e-8689-8406903ea241). }
' 0:< API_SUCCESS { Unregistering ViewActivating event by application External Tool (e0a2d7a5-030b-4d4e-8689-8406903ea241). }
' 0:< API_SUCCESS { Unregistering DocumentSavedAs event by application CollaborateDB (bb3086be-63bb-44bd-99eb-d584c013cf2f). }
' 0:< API_SUCCESS { Unregistering DocumentOpened event by application CollaborateDB (bb3086be-63bb-44bd-99eb-d584c013cf2f). }
' 0:< API_SUCCESS { Unregistering DocumentClosing event by application CollaborateDB (bb3086be-63bb-44bd-99eb-d584c013cf2f). }
' 0:< Forcibly unregistering Updater with id:51c0be9b-07a8-443a-be8c-21db815b17e7
' 0:< Forcibly unregistering Updater with id:00000000-c00c-478e-9226-63d19d957aed
' 0:< Forcibly unregistering Updater with id:00000000-9a62-4ecd-adb1-9a93bf539620
' 0:< Forcibly unregistering Updater with id:00000000-7174-4309-88a1-27d09090ef6d
' 0:< Forcibly unregistering Updater with id:00000000-0a7a-49e7-bd08-6696111b3b53
' 0:< Forcibly unregistering Updater with id:649e613c-2d39-4a7b-9720-662750f5243e
' 0:< Forcibly removing all update triggers for all Updaters
' 0:< Unregistering all external services.
' 0:< ::4:: Delta VM: Avail +68 -> 134183080 MB, Used -58 -> 313 MB; RAM: Avail +2 -> 62316 MB, Used -4 -> 496 MB
' 0:< GUI Resource Usage GDI: Avail 9689, Used 311, User: Used 249108103290
' 0:< Exception occurred
'C 13-Sep-2016 16:03:09.099; 0:< ExceptionCode=0xc0000005 ExceptionFlags=0x00000000 ExceptionAddress=00007FFF8357A0A0
' 0:< System (MB) [Available / Total ] [Revit Memory Usage (MB) ]
' 0:< RAM Statistics: 62316 / 65373 496=InUse 511=Peak
' 0:< VM Statistics: 134183081 / 134217727 313=InUse 382=Peak
' 0:< Unconverted MessageBox "An unrecoverable error has occurred. The program will now be terminated. All of your data has been recently saved, so there is no need to create recovery files."
' 0:< ::4:: Delta VM: Avail -26 -> 134183054 MB, Used 313 MB; RAM: Avail -7 -> 62309 MB, Used 496 MB
' 0:< GUI Resource Usage GDI: Avail 9686, Used 314, User: Used 249108103283
'H 13-Sep-2016 16:03:10.342; 0:<
Jrn.Data "MessageBox" _
, "IDOK", "An unrecoverable error has occurred. The program will now be terminated. All of your data has been recently saved, so there is no need to create recovery files."
'C 13-Sep-2016 16:03:10.342; 0:< program terminated:initialize>
Message 7 of 12
Revit_Whisperer
In addition to my previous questions please also provide the following:
  • What type of computer do you have?  HP laptop, Surface, tower etc...
  • Can you run Revit in Viewer mode?
  • What antivirus do you have installed?
  • Was the OS upgraded?  If so, when?
  • Have you emptied the Temp directory to see if that resolves?
Please attach the journal file.
Message 8 of 12
andrea.kikuchi
Autodesk Support
Autodesk Support
Hi @Anonymous,
In addition to the information provided by @Revit_Whisperer, can you tell me if you are using C4R at all?
Thanks!
Andrea K
Technical Support Specialist
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Message 9 of 12
Matt__W
I've heard of this happening on Windows 10 Anniversary machines and haven't found an answer yet myself. I just posted this in the MEP forum hoping to get some feedback.
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
Message 10 of 12
BIMologist_
@Anonymous
@Matt__W
So I analyzed your Log and another users
Here are the commonalities
Both have K2000 and driver
'Certified driver(s): 21.21.13.xxxx (the last digits are different. )
The current one is around 'Current driver version: 10.18.XXX.XXXX
Seems like you may have Microfsoft drivers . Cant tell what the diff is between mine and yours (I..e 10. vs 21.) the Certified Hardware site mentions [10.18.13.5456]
http://usa.autodesk.com/adsk/servlet/syscert/card?siteID=123112&catID=18254205&id=18844534&product=131&os=524288&hw=287
NVIDIA Driver Release - Quadro Desktop/Quadro Notebook 354.56 Windows 10 64bit [10.18.13.5456]
Also your says
'DrvOlderThanTested=y  mine it is N
1. Go to NVIDIA's website and DOWNLOAD the latest driver for your K2000
When you download it, before installing (I know they are not certified, but lets go with those for the time being.
UNINSTALL the older driver
When you install the new one
Select Customize and select CLEAN install
Addins
2. Both are running BIM360 Addin
C4R and communicator (but I am running it too)
BATCH Print
I have c4R and communicator as well
Both are crashing
at ' 0:< Unregistering all external services.
You get killed here and the normal should be somewhat like this
' 0:< ::2:: Delta VM: Avail +95 -> 134183007 MB, Used -45 -> 358 MB; RAM: Avail +44 -> 8976 MB, Used -13 -> 555 MB
' 0:< GUI Resource Usage GDI: Avail 9749, Used 251, User: Used 622770258014
'C 12-Oct-2016 16:36:16.106;   0:< License cleanup complete: 0, 0
' 0:< Journal Exit
or this
'C 11-Oct-2016 11:40:40.664;   0:< Protein : Unload plug-ins
'C 11-Oct-2016 11:40:40.664;   0:< Protein : Release Plugins
' 0:< ::34:: Delta VM: Avail +4 -> 134215675 MB, Used -12 -> 455 MB; RAM: Avail +7 -> 11534 MB, Used +4 -> 436 MB
' 0:< GUI Resource Usage GDI: Avail 9154, Used 846, User: Used 970662609231
'C 11-Oct-2016 11:40:40.670;   0:< Protein : Release Renderer Module
'C 11-Oct-2016 11:40:40.670;   0:< Protein : Release Plugins
'C 11-Oct-2016 11:40:40.670;   0:< Protein : Destroy RenderingAsset Library Manager
'C 11-Oct-2016 11:40:40.679;   0:< Protein : ProteinSdkManager has been destroyed successfully
' 0:< ::34:: Delta VM: Avail +54 -> 134215729 MB, Used -43 -> 412 MB; RAM: Avail +3 -> 11538 MB, Used +1 -> 437 MB
' 0:< GUI Resource Usage GDI: Avail 9159, Used 841, User: Used 970662609206
'C 11-Oct-2016 11:40:40.743;   0:< License cleanup complete: 0, 0
' 0:< Journal Exit
Try it out let me know
BIMologist
- Nauman Mysorewala
Did you find this post
helpful? Feel free to like this post.
Did your question get successfully answered? Then click
on the ACCEPT SOLUTION button.
Message 11 of 12
Just to repeat what I said in another thread with the same problem, thanks to Nauman I solved it by replacing the driver with an OLDER version. Here is the full excerpt (again thanks Nauman for your diagnosis):
"I had the same problem and managed to fix it by installing an OLDER version of the graphics card driver. We have the Quadro K600 running driver 21.21.xx.xxx and had to install version 10.18.13.5362. Now the exact driver version doesn't matter I think but it's got to be the older one 10.18.xx.xxxx as I believe this was Autodesk certified before. If you right click on your Windows start button -> Device Manager -> Display Adapters -> Double click on your graphics card and go to Drivers Tab, it'll tell you what version you're running.
Give it a try. You'll have to source your own driver as it's different for every card. For mine specifically, I used Nvidia 353.62-notebook-win10-64bit.
Hopes this helps. I tried all the other addons/C4R stuff and it didn't solve it but this method did on 2 machines in our office.
 *edit - Someone mentioned updating your driver to the latest one - I tired that first and it didn't work. Go backwards!"
Message 12 of 12
I have spent a better part of a day trying to figure out the solution to this unrecoverable error issue and rolling back the NVIDIA driver worked! Thank you so much.
