Reference Lines cannot be arrayed when hosted to certain extrusions/voids
3 REPLIES 3
crapai
224 Views, 3 Replies
I don't know if this is a bug or a "feature" but I though I should post to see if people have ran into this.
I was trying to array a reference line in the front view of a family. It created the second instance of it but when I edited the array number the extra instances of the reference line were stacked at the same place as the original.
I found that if you try to host the reference line to a void or an extrusion that has it's sketch on another surface this behavior happens. I was able to create a extrusion from the reference level, host a reference line to one of it's vertical faces, and array it without any problems.
3 REPLIES 3
in reply to: crapai
Almost sounds like a description of Array to Last and not to 2nd.
...or maybe Constrain?
crapai
in reply to: barthbradley
Same issue with array to last. The additional arrays stack on the original reference line.
RDAOU
in reply to: crapai
@crapai
Behavior seems normal here...maybe you can upload the family which is giving you a hard time
Forma Design Contest
