I don't know if this is a bug or a "feature" but I though I should post to see if people have ran into this.
I was trying to array a reference line in the front view of a family. It created the second instance of it but when I edited the array number the extra instances of the reference line were stacked at the same place as the original.
I found that if you try to host the reference line to a void or an extrusion that has it's sketch on another surface this behavior happens. I was able to create a extrusion from the reference level, host a reference line to one of it's vertical faces, and array it without any problems.
Almost sounds like a description of Array to Last and not to 2nd.
...or maybe Constrain?
Same issue with array to last. The additional arrays stack on the original reference line.
Behavior seems normal here...maybe you can upload the family which is giving you a hard time
