ramp siding
ramp siding
Message 1 of 54
ramp siding
How to make ramp siding (see attached) I don't want to use floor and add points, I need the ramp as generic family I already tried, I used extrusion but I have difficulties doing the two sides as shown in the screenshot. Any help appreciated. Thank you
Replies (53)
Message 2 of 54
Avaris.
Maybe the easiest way to construct is to make it in the massing environment.
-Draw triangles in all three baseplanes
-Connect every oblique line and create form
It is however also possible in a generic model family:
-Create one triangular solid
-Create two voids to cut the sides of the solid (you need an angular void to obtain your result)
Message 3 of 54
hello, thank you for your reply, i cannot open your file im using Revit 2018.
Message 4 of 54
Avaris.
Okay, here is a screenshot, follow these steps:
-Draw three points in floorplan, one at the intersection of axis and two at each of the axis.
-Go to 3D and Elevate the point created at the intersection.
-Draw reference lines in a chain and 3Dsnapping on (top bar)
-Select all reference lines and create form
-To make it parametric, create dimensions between axis and points you use to reference.
Message 5 of 54
aRcHiTeCt.JM
... you can create it as a MODEL IN-PLACE family
.... you need to use sweep blend and draw the requiered shape
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Message 6 of 54
Avaris.
Cheater 🙂
Then I would recommend to draw a litte rectangle in both sweeps below the reference line ánd create a void to cut off the material you don't need. Nonetheless, clever solution!
Message 7 of 54
Hello is there anyway you can show me in screencast tutorial on how to do the ramp with 2 siding on both sides as shown in my screenshot above so I can try to put parameter in massing. If can, If cannot its fine with me. Thank you
Message 8 of 54
aRcHiTeCt.JM
... hi @Anonymous
... go to level 1
... component
... model in place
.... choose generic model (or the one you need / want
.... click OK
.... rename it
... click ok
..... choose SWEPT BLEND
.... first ....Sketch path
... click ok
.... start the line on the top part to know where will be the first profile
... click ok
....go to the north elevation
... select profile 1
... and draw it the way you want
.... after finish click OK
.... now repeat the profile process for the second one
.... draw a thin rectangle
... click OK
.... now click OK... and finish your family
.... go to your 3dview
... done
aRcHiTeCt.JM
REVIT EXPERT ELITE
Message 9 of 54
@aRcHiTeCt.JMthank you for your step by step explanations . very much appreciated, but sorry to say that is not i wanted it to be. please file attached.
Message 10 of 54
Corsten.Au
Hi
Ramp can be sloped ONLY is ONE direction.. ( exception is circular ramp )
because of that constraint it will be impossible to model that portion.
You may use
1. Inplace family, and model that potion
2. Floor with " modify sub-elements"
3. Adaptive family with parameters
4. Use Floor for the ramp, and floor edge to model that.
5. use one single floor and " edit/modify  sub elements"
Floor - Modify sub elementsFloor - Modify sub elements
Corsten
Building Designer
Message 11 of 54
Why are you against using a floor with modified sub elements? It seems to be the best tool for this.
Message 12 of 54
Hi, I have already done that, but the ramp structure is embedded into floor slab which is not good for presentation for construction which not going to happen in reality. Thank you
Message 13 of 54
anyway, how i can make this one solid, i missing something , i tried but i cannot make it as solid. thanks you
Message 14 of 54
Corsten.Au
Make a solid geometry and cut solid using void ( that void needs to be in a plane tilted capturing 3 edges )
Corsten
Building Designer
Message 15 of 54
@Corsten.Aucan you please explain step by step procedure and  cut a section view based on my screenshot above. thank you
Message 16 of 54
Corsten.Au
Inplace Family - Extrusion by profileInplace Family - Extrusion by profileVoid - use Blend - Modelling - BaseVoid - use Blend - Modelling - BaseVoid - Modelling - topVoid - Modelling - topAdjust top and bottom void profile the get Plan right... Idea is to generate a tilted plane to cut the ramp...its easy to create in adaptive family but here its easy to create using Blend  optionAdjust top and bottom void profile the get Plan right... Idea is to generate a tilted plane to cut the ramp...its easy to create in adaptive family but here its easy to create using Blend option
Corsten
Building Designer
Message 17 of 54
Corsten.Au
Rather than create a solid outside the ramp profile - you need to create a void to cut from the ramp..Rather than create a solid outside the ramp profile - you need to create a void to cut from the ramp..changing that extrusion to void...changing that extrusion to void...
Corsten
Building Designer
Message 18 of 54
can post this file and family. or if possible screencast . i want to see. thank you
Message 19 of 54
Corsten.Au
I have posted 4 files.. to understand steps..
check out the 4th..
1. you need one void to get the PLAN profile right
2. another void at angle
https://www.dropbox.com/sh/cu3bmxkwoqe4mkh/AABVpFLPZlncSQTB8F4ts4s0a?dl=0
Corsten
Building Designer
Message 20 of 54
thank you @Corsten.Au supposed to be like this please see attached.
