Archvision rpcs not showing
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
1053 Aufrufe, 1 Antwort
Look at the images, the archvision rpcs are not showing. In shaded or hidden line they appears in a different way, but not in the realistic or rendering mode. Do you know why?
Thanks.
1 ANTWORT 1
Nachricht 2 von 2
aRcHiTeCt.JM
als Antwort auf: Anonymous
… hi
… did you update your model from a previous version ?
… that usually happens when you update from REVIT version to a newer version
… what you need to do is :
… click on one RPC and EDIT PROPERTIES
… then choose another person (or the same)
… and that’s it (repeat the process for the other ones)
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
