Railing problem
6 REPLIES 6
277 Views, 6 Replies
Railing problem
Anyone help me why this. The top railing height not match.
And how can I make custom path for railing for top storey.
I tried edit path many times but it's not worked.
6 REPLIES 6
That's because you end the stairs with a tread, not a riser. Instead of that, change to end with riser, then draw a small landing on top.
Toan Nguyen
in reply to: ToanDN
Thanks. And how about railing at top floor.
See attack file for more detail.
Edit path and add a segment at the top landing.
Toan Nguyen
in reply to: ToanDN
I tried many time but it not worked. I can't sketch a line on top landing because I can not select endpoint 3d view, same on top floor view when I sketch on that.
Can you show me more detail?
chrisplyler
Try adding the segment when you are in a regular floor plan view of the top floor.
in reply to: chrisplyler
I tried many times. But it's not work.
Forma Design Contest
Technology Administrators
