Can Room Names be linked to View Titles?
1 ANTWORT 1
Nachricht 1 von 2
jim3thornton
612 Aufrufe, 1 Antwort
We are renumbering our stairs  ...
Which in turn means we need to rename the titles of each drawing.
We can easily rename the Stair (Room Name) and it will update in all plans.
But now we must manually rename the Stair Name on all stair plans and sections.
Is it possible to attach a <room name reference> in the future rather than having to manually rename each of these instances?
1 ANTWORT 1
Nachricht 2 von 2
HermanSolomon
als Antwort auf: jim3thornton
Hi Jim3thornton,
According to my knowledge, it is not possible as Revit's title block families only contains labels for sheets, not rooms. I would recommend creating a View List schedule showing the sheet name and view names. Even though one can only change the View Names through the schedule, and not visa-versa, it should make the vetting of your stair views to which sheet they have been placed on a bit easier.
It could (And I'm definitely not an expert on this) be possible using Dynamo? Maybe some of the Dynamo experts could provide some insight?
Herman
http://revitrecess.blogspot.com/
