Rail extends past Post
PhilvK
Advisor Advisor
Message 1 of 10
PhilvK
As shown below, when I ‘space’ the end post of my rail system back 2” to sit on the stringer, the bottom rail sticks out. Is there a setting that corrects this?
Replies (9)
Message 2 of 10
Why don't you shorten the railing sketch line instead of moving the baluster?
Message 3 of 10
PhilvK
Thank you. Sometimes the most obvious answer is not apparent to me!
While I have your attention, when I re-sketch the railing, the rail is drawn flat on the ground. When I select ‘Pick New Host’, the stair doesn’t highlight to be selected.. Do you know why not?
Message 4 of 10
Alfredo_Medina
Maybe the sketch has moved slightly out of the stair in plan view. Try to move it inwards, and set the host again.
Message 5 of 10
PhilvK
Thank you . I am not sure if that was it, but it seems to be working now. I think there was a little operator error going on here.
Message 6 of 10
srooney
This solution does not work, as it shortens the calculation point for the upper rail extension, so the the extension is no longer the code distance from the nosing.  Checking the "post" property on the baluster type is supposed to trim the rail to the post, but this does not seem to work either.
Message 7 of 10
The solution addressed OP query specifically.   If you are not satisfied then create  a new thread to ask for your condition.  By the way, the rrail extension can be lengthen to any dimension you want to meet code.
Message 8 of 10
srooney
The question was directly pertinent to my problem, so no need to start another thread.
If you shorten the sketch line, and make the rail extension longer to account for this - the extension starts horizontally
at the end of the sketch line, so you will have too much horizontal.
The OP should at least be aware of this.
If this is the only "solution" on the forum, then the actual
solution as usual is for Autodesk to improve the railing tool, instead of us all having to make a work-around,
which is certainly not your problem.
Message 9 of 10
Message 10 of 10
TheMattatonAP
@ToanDN what were your settings to achieve this image? I share @srooney 's concern that pulling the sketch line back introduces inaccuracy in the extension.
