Text parameter functionality
3 ANTWORTEN 3
Nachricht 1 von 4
407 Aufrufe, 3 Antworten
I love all the changes Revit 17 has brought us, but one of the features I want most is still conspicuously missing. That is functionality for text parameters and using text as a qualifier in and/or/if statements
My current dilemma is that I am trying to build a code data sheet that automatically fills itself out based on construction and occupancy type. So if we type in 2B as a construction type it automatically fills in fire rating requirements in a separate table. Unfortunately, Text cant be used as a qualifier and just gets recognized as a different parameter. What I WANT to build is like below. Essentially, revit would look for specific text situations as the parameter value and return either a # or the last value of the string(0 in this case)
IF(CONSTRUCTION TYPE = "1A" , 3 , IF(CONSTRUCTION TYPE = "1B", 2 , IF(CONSTRUCTION TYPE = "2A", 1 , IF(CONSTRUCTION TYPE = "2B" , 0 , IF(CONSTRUCTION TYPE= "3A" , 1 , IF(CONSTRUCTION TYPE= "3B" , 0 , IF(CONSTRUCTION TYPE= "5A" , 1 ,0)))))))
AUTODESK OVERLORDS! HEAR MY PRAYERS!
3 ANTWORTEN 3
Nachricht 2 von 4
Alfredo_Medina
als Antwort auf: Anonymous
What if Construction Type is a number?
Then, if that number parameter is this, the other parameter is that
1.1 = "1A"
1.2 = "1B"
2.1 = "2A"
2.2 = "2B"
3.1 = "3A"
3.2 = "3B"
5.1 = "5A"
Nachricht 3 von 4
It sounds like an easy job for key schedules.
Nachricht 4 von 4
This is only good for some cases.
However, in lot of other cases where the condition is based on a text value, and the text value is unpredictable, text evaluation functionality is definitely required.
For example, I need a model text on a switchboard family to show the switchboard name, say "DB-1". I can use a text parameter e.g. DBName for user to input the switchboard name. Here comes the problem - Revit model text doesn't accept blank text. Then the family needs to be able to check if the input text is blank: If DBName is a blank text,  set the model text to a default text value such as "DB", otherwise equal to DBName. i.e. formulas like below are required:
ModelText = if (DBName="", "DB", DBName)
or
ModelText = if (IsBlank(DBName), "DB", DBName)
Unfortunately, Revit still hasn't provided such simple basic functionality.
Is there any work around? Any help is appreciated.
