quote door span
8 REPLIES 8
Message 1 of 9
teduardo240791
385 Views, 8 Replies
quote door span
Hello guys! Hope every one is safe and healf. So, I was trying to do a plant view that reproduce only walls core, I was sucessfull in that using VG resources. whoever now I cant quote door's span. I do not now why but revity quote did not work in spans of core walls ? Could you guys help me ?
8 REPLIES 8
Message 2 of 9
Is this what you mean?
Message 3 of 9
Yes, however it doesnot works when I am using walls core only.
My revit is in portugues, so Paredes = Walls; Camadas não principais = non-core layer. So a kept this option uncheked to do wall core views, however I can not quote door span.
Message 4 of 9
Works here.
...Is the Dimension Category under the Annotation Tab checked (e.g. turned ON)?
Message 5 of 9
It works because you already got the quotes. Try to quote with just core wall, it does not allowed to quote door span
Message 6 of 9
I'm telling you -- it works here.  You must be doing something wrong.  Post your file to test.
Message 7 of 9
I am sending my file. I am trying to quote a door span, there is a door I hide the door and want to quote just the span. Some pictures showing what I am truing to do.
Message 8 of 9
in reply to: barthbradley
Revit can't pull dimensions to and from a wall wrap. You need to dimension to a Ref. Plane or model the wall wrap.
Message 9 of 9
Thanks men!
Forma Design Contest
