Hello guys! Hope every one is safe and healf. So, I was trying to do a plant view that reproduce only walls core, I was sucessfull in that using VG resources. whoever now I cant quote door's span. I do not now why but revity quote did not work in spans of core walls ? Could you guys help me ?
Solved by barthbradley. Go to Solution.
Yes, however it doesnot works when I am using walls core only.
My revit is in portugues, so Paredes = Walls; Camadas não principais = non-core layer. So a kept this option uncheked to do wall core views, however I can not quote door span.
Works here.
...Is the Dimension Category under the Annotation Tab checked (e.g. turned ON)?
It works because you already got the quotes. Try to quote with just core wall, it does not allowed to quote door span
I'm telling you -- it works here. You must be doing something wrong. Post your file to test.
I am sending my file. I am trying to quote a door span, there is a door I hide the door and want to quote just the span. Some pictures showing what I am truing to do.
Revit can't pull dimensions to and from a wall wrap. You need to dimension to a Ref. Plane or model the wall wrap.
