"Elevation override" Parameter to replace Elevation parameter
danezeq
3,324件の閲覧回数
46件の返信
メッセージ1/47
danezeq
Hey.
I have a special case in which i need "Elevation override" Parameter which i created, to replace the regular Elevation parameter in schedules. **Only when Elevation override parameter entered**.
That should be done with a formula on schedule properties window, right?
0 件のいいね
3,325件の閲覧回数
46件の返信
返信 (46)
メッセージ2/47
Ilic.Andrej
If I understood you well, you want to use "elevation override" as a condition (if elevation override is checked, use the custom value, otherwise use the actual value)
Create a calculated parameter and use this formula:
if(elevation override, overriden elevation, elevation)
...where "elevation override" is a yes/no project parameter and "overridden elevation" is a length project parameter.
After your work is done, just hide the schedule fields.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
0 件のいいね
メッセージ3/47
danezeq
Thanks. will it be possible to do it without the yes/no parameter? i mean if the Elevation override parameter has some value in it - that means "yes". if it's empty - it'll be "no".
0 件のいいね
メッセージ4/47
There may be another approach. Tell us the particulars about this "special case".  Also, post the family.
0 件のいいね
メッセージ5/47
Ilic.Andrej
you could try and use some other condition like:
if(overriden elevation>0,overriden elevation,elevation)
but I agree with @barthbradley . Tell us about the specific issue cause you might wanna avoid this nasty workaround.
Andrej Ilić
MSc Arch
0 件のいいね
メッセージ6/47
danezeq
That could be a bit difficult to phrase but i'll do my best 🙂
There are some areas on this project which are "off-levels". that is a half floor above the rest of the floor.
i need to place signs and state their elevation from floor. the constructor should install them according to my schedule.
The elevation number should express the distance from the floor, not from the level.
My first thought was to draw new levels which are in between the normal levels. (like "-3.5").
But then i found that there more special cases when the floor can be 10cm above the level. so i must find a more durable solution.
0 件のいいね
メッセージ7/47
解決済み
I think I mentioned this to you in your other thread.  The gist of it is to Nest your Face-Based Sign Family into a "unhosted" Family Template, place instance of Sign in  an Elevation View,  pull a dimension from the Sign to the Ref. Level and label the dimension with a SHARED Parameter. Then check "Work Plane Based" and uncheck "Always Vertical", load it into Project and place on a Host Work Plane in Plan View and use the Parameter to drive its elevation/offset above the Host Work Plane.
See 2019 RVT attachment.
メッセージ8/47
danezeq
Thanks @barthbradley
From your post i can learn that using this method i can skip that trick of using an elevation override parameter.
So i tried the family you've posted (thank you again!) and for some reason it placed wrongly: the elevation show as plan and plan symbol shows on elevation. Do i need to change any setting inside the family ?
0 件のいいね
メッセージ9/47
That's is by-design. I wrote above to "load it into Project and place on a Host Work Plane in Plan View".
0 件のいいね
メッセージ10/47
danezeq
@Ilic.Andreji'm trying your suggested formula and i get this inconsistent units error:
https://www.youtube.com/watch?v=ZYuz6LcYgSg
i hope im adding it to the right place.
@barthbradleyi'm getting some difficulties to use this method, i will try to explain the new problems it creates.
0 件のいいね
メッセージ11/47
Regarding your formula issue; try a neutralizer. Divide by one (/1) or Multiply by one (*1).
Regarding the issue with the family I provided; can you share what that issue is?
0 件のいいね
メッセージ13/47
martijn_pater
I was thinking to nest it in a two level based family template (apparently you can't schedule those top/bottom levels ootb though). But you can create a shared parameter for the elevation to bottom, dimension the upper ref level/bottom ref level and associate the shared parameter as instance reporting parameter.
edit:
more or less the same as given by @barthbradley in post #7 actually.
0 件のいいね
メッセージ14/47
Ilic.Andrej
its because every overridden elevation must have some default value added (like 0)
Andrej Ilić
MSc Arch
0 件のいいね
メッセージ15/47
danezeq
but the whole purpose of this parameter is to override the "elevation" only if there is a value inserted.
thus, in all other cases the override elevation parameter should be empty.
0 件のいいね
メッセージ16/47
martijn_pater
You can't check for an empty value (you would need an on/off parameter)... but it's still not really clear to me what you are trying to do...
0 件のいいね
メッセージ17/47
danezeq
@barthbradleyabout the "family inside family" solution:
it opens a lot of new issues to resolve like:
i cannot choose between all my types that i created, Then i've found that i can define the type as a parameter inside the family, so i AM able to choose type but i should create a new type in the "father" for each type in the "son"
and then - schedules wont recognize all the "sons" types.
When i place these "family inside family" types on plan, they baheve differently from the original types, they dont stick strictly with walls, like - they're not wall-mounted or something.
...and lot's of more changes. if i were to use this trick you've provided, i will attack you with tons of new questions about how to adjust this new family to my project needs and my way of work.
i think i should let it go this time and keep working with what i have.
Maybe i just need to build this family from scratch and somehow make it associate to the level correctly (the current family dont recognize the level - EVER) and then the Elevation parameter will work right.
0 件のいいね
メッセージ18/47
martijn_pater
Then you would have to add a parameter for the nested types. Select the nested sign geometry, go to label (top left) and add a type parameter. But a downside is that it populates the dropdown with all Generic model types ie. or in your case specialty equipment if I remember correctly. Or you'd have to nest it twice and work with visibility, but from what I remember you also have quite a lot of different signs/types... not really a good option then.
0 件のいいね
メッセージ19/47
danezeq
That's exactly what i did but then, schedules wont see them.
0 件のいいね
メッセージ20/47
martijn_pater
Did you make it a shared family? See link.
0 件のいいね
