"Elevation override" Parameter to replace Elevation parameter
danezeq
Message 1 of 47
danezeq
Hey.
I have a special case in which i need "Elevation override" Parameter which i created, to replace the regular Elevation parameter in schedules. **Only when Elevation override parameter entered**.
That should be done with a formula on schedule properties window, right?
Accepted solutions (3)
Replies (46)
Message 41 of 47
No. The file I just uploaded has all the family types and with the elevation fix. You need to close the family you have open and edit the one in the project.
Message 42 of 47
danezeq
you're right. my bad.
Message 43 of 47
danezeq
I think i am missing something about the placing of the edited family. both yours, and the nested family is hard to place.
Here i compare between the old family and the improved one: (the first is the old family)
https://www.youtube.com/watch?v=wE5Y5519M-E
after hitting space it allows me to places it, but yet, not on the right plane.
What has been changed in the family that changes the way it places?
Message 44 of 47
Set the Elevation to 0 when you placing them.
Message 45 of 47
danezeq
Tried that.
after lots of struggles it get placed correctly. (need to change placement method, change view, hit space a couple of times, etc..)
https://www.screencast.com/t/1vmWwZnyGKz
i'll try to keep work with it and see how it goes.
Message 46 of 47
If you place from a plan view, only change Elevation, not Elevation from level.  The open an elevation view and lock the bottom grip to the finish floor or level and change the Elevation to Level if necessary.  If you place in an elevation view then you can skip the 1st step.
Message 47 of 47
danezeq
I can get it to work after lots of attempts in one project, in other project nothing helps and it's kind of placing it inside the walls.
The practice of placing this family is different from the original family. there's no way to make it work like the original family? is that happening because of that "weak reference" that came up in the improved family?
