Question Regarding Title Viewport Lines
alexisCTZENP
Message 1 of 21
alexisCTZENP
Working in some projects in Revit 2022 and noticing I'm unable to adjust the horizontal line on viewport title. Basically step number 4, I am unable to do. does anyone know why that might be the case or how I can get it to show? is there a way to create a new family with that setting? Thank you!
https://help.autodesk.com/view/RVT/2023/ENU/?guid=GUID-C14857FF-4907-4AF3-B111-1D926F7B166E
Replies (20)
Message 2 of 21
Select the viewport, NOT the view title, then you will see the grips adjust the line.
Message 3 of 21
alexisCTZENP
I did actually do that already, as did my coworker. We don't see the lines on either of our ends.
Message 4 of 21
Select the viewport, edit type:
Message 5 of 21
alexisCTZENP
also is checked. I'm wondering if there is some kind of internal setting we are unaware of... would you have suggestions on how to investigate this or know how to create a family with it as an option?
Message 6 of 21
Share the view title family here.
Message 7 of 21
alexisCTZENP
not permitted to unfortunately, do you happen to have any experience with creating these families to push me in the right direction? if not, I appreciate all your help!!
Message 8 of 21
Edit the family and make sure there is NO actual line.
Message 9 of 21
mhiserZFHXS
Is the viewport locked? That would prevent the grips from showing.
Message 10 of 21
alexisCTZENP
not sure how to check for this, it might be. do you know where I can look? Thanks!
Message 11 of 21
mhiserZFHXS
Click on it and check the pin/unpin tools under the modify tab. Or if it is pinned, a pin should show up toward the middle of the viewport.
Message 12 of 21
alexisCTZENP
that's actually greyed out. would there be a  setting within my company or in revit that would make it so that's not an option to change?
Message 13 of 21
mhiserZFHXS
Which one is grayed out? Pin and unpin are two separate tools. If the pin tool is grayed out, that means the item is pinned, so hit the unpin button above it.
Message 14 of 21
alexisCTZENP
both/all
Message 15 of 21
ravwood
Please try to edit the family in edit mode.
Message 16 of 21
alexisCTZENP
I did do that- wasn't able to locate a setting which would allow for the 'bubbles' to show up so I can drag within the project. I am able to change the length within the family itself but was wondering if there is some way to edit the family so it's adjustable in the project. want to understand the mechanism behidn it so I can potentially get it to show. Thanks in advance!!  If you aren't sure, I appreciate all your help 🙂
Message 17 of 21
Do you see any line in the family?
Message 18 of 21
alexisCTZENP
the line in the family is editable but I don't see a parameter or option which would allow for it to be editable within the project itself, if that makes sense. I'm used to being able to click and drag customizable within the project itself rather than needing to create a new family  -- can't tell if there is some missing parameter or some company wide setting, I'm not sure how to look for it either.
Message 19 of 21
I guess you missed my earlier response.  You cannot have any line in the family, the line is generated automatically in the project.  Delete it.
Message 20 of 21
alexisCTZENP
I did miss it- thank you!
